Results 1 to 4 of 4
Thread: Ampeg V4 Tube Retainers
    Nov 2017
    25
    Received: 7/0
    Given: 1/0
    0
    Hi there,
    Has anyone ever found replacement power tube retainers for an old model Ampeg V4? I'm working on one that is missing three of the four bear trap style retainers, and I can't find any replacements that fit. The mounting holes for the sockets and retainers are spaced more closely than everything I can find - the distance between the holes is about 1.3", everything I've found is 1.5". I've sourced replacement sockets that drop-in fine, just can't find the retainers, and I'd prefer them to the spring type. Obviously I could drill new holes and install larger modern sockets etc., just trying to keep this as easy as possible.
    Matt
    Stray Cap DrGonz78's Avatar
    Oct 2011
    Scottsdale, AZ
    2,173
    Blog Entries
    1
    Received: 364/5
    Given: 262/0
    11
    You might have already checked fliptops. If not these might do the job but I would contact them first to check sizing.
    https://www.fliptops.net/catalog/p-1...or-power-tubes
    Supporting Member nevetslab's Avatar
    Apr 2010
    Burbank, CA
    1,840
    Received: 665/1
    Given: 1,507/1
    11
    I'd just replace them with the spring-based hold-down clamps. I have a growing collection of bear-trap clamps that I've removed, and with sockets that DO grip the power tube pins as well as the bases, they're fine. But, I come across so many amps, particularly those with the chassis' inverted & the tubes are hanging down, that I get issues with some of the tubes as they age. I do go one step further when I install the hold-down clamps. I install hi temp silicone rubber tubing over the spring/clamp legs to keep that metal joint off the glass, tubing on the wings, and slit a smaller dia tubing to fit into the 7/8" or 1" ID in the top of the clamp, so the tubes are well shock-mounted.
Name:	Bassman 135-10.jpg
ID:	56287 Click image for larger version.
Name:	Bassman 135-11.jpg
ID:	56288 Click image for larger version.
ID:	56289 Click image for larger version.
ID:	56290 Click image for larger version.
Name:	Install Grommet-1.jpg
ID:	56291 Click image for larger version.
Name:	Install Grommet-2.jpg
ID:	56292Click image for larger version.
Name:	Grommet Installed-1.jpg
    The tubing I use comes from McMaster-Carr....smaller size for grommet is 3/32" ID x 7/32" OD, P/N 3038K12 and the larger size for the spring/flap & wings is 3/16" ID x 5/16" OD, P/N 3038K14....10ft min qty
    Maybe this is overkill, but, it has cut down the tube glass breakage in our large rental inventory now over the years. I first began using this on 6550's and KT-88 power tubes used in Ampeg SVT's with great success.
    1 Not allowed! Not allowed!
    Feb 2010
    12,030
    Received: 1,795/24
    Given: 4,615/11
    23
    The funny thing is, if you want to go for 6550's you will have to cut the bear trap style stock retainers off.
    So that's another reason to go for the spring type. I can understand wanting to keep it stock though. For what it's worth, with those lovely shock mounts, you don't need retainers (if sockets are nice and tight). The pair I cut off (for reason above) have no issues with loose tubes.
    It does about 90W with a pair of 6550's.
    Last edited by g1; 12-09-2019 at 08:42 PM. Reason: of course the tubes hang upside down, wake up g
  1. 6V6 Retainers?
    By big_teee in forum Build Your Amp
    Last Post: 05-12-2016, 11:05 PM
  2. Ampeg Based Tube Preamp
    By blown240 in forum Music Electronics
    Last Post: 11-02-2011, 05:42 PM
  3. Ampeg V4 eating tube s
    By Marc in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-19-2011, 04:33 AM
  4. Embarassing question about tube retainers.
    By thadjanus in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-24-2010, 07:31 AM
  5. 5881 tube retainers
    By Diablo in forum Tubes (Valves)
    Last Post: 12-19-2008, 02:48 PM
