Results 1 to 9 of 9
Thread: 1979 Fender Princeton Non-Reverb
    Twobie
    Dec 2019
    4
    0
    I'm looking for a schematic and/or layout for a 1979 Princeton NR. I think this amp is much like the Princeton Reverb W/Boost model, but without reverb or boost. I have earlier Princeton schematics, but accurate drawings would be a little more helpful in getting this modded amp back to where it was originally.
    Senior Member vintagekiki's Avatar
    Jul 2006
    1,726
    Received: 301/2
    Given: 272/0
    16
    Who does not know and knows that he does not know - teach him Confucius)
    Who knows and does not know that he knows - wake him Confucius)
    Twobie
    Dec 2019
    4
    0
    AA964 and AB1270 are close and likely what I'll be using for reference. I was hoping someone might have a link to schematics for the last production year(s) of the silverface Princeton NR. This amp has a 3 way ground switch for example. I'm not sure what other differences I might find. I'm really not sure there's any documentation floating around that is specific to this particular circuit.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,663
    Received: 2,126/7
    55
    Three way, like center off?
    Jul 2006
    1,726
    Received: 301/2
    Given: 272/0
    16
    Quote Originally Posted by lestratele View Post
    If you looked at schematics AA964, you would see that it has a 3 way ground switch (for example)
    http://ampwares.com/schematics/princeton_aa964.pdf
    Look to the left for Princeton. What exactly is your model
    http://thevintagesound.com/ffg/
    1)
    https://www.schematicsunlimited.com/f/fender
    fender princeton 5b2 schem [44 KB]
    fender princeton 5b2 schematic [31 KB]
    fender princeton 5c2 schematic [27 KB]
    fender princeton 5d2 layout [44 KB]
    fender princeton 5d2 schem [79 KB]
    fender princeton 5d2 schematic [33 KB]
    fender princeton 5e2 layout [51 KB]
    fender princeton 5e2 schem [83 KB]
    fender princeton 5e2 schematic [29 KB]
    fender princeton 5f2 amplifier schematic [47 KB]
    fender princeton 5f2 layout [50 KB]
    fender princeton 5f2 schem [81 KB]
    fender princeton 5f2 schematic [30 KB]
    fender princeton 5f2a layout [43 KB]
    fender princeton 5f2a schem [79 KB]
    fender princeton 5f2a schematic [34 KB]
    fender princeton 6g2 layout [59 KB]
    fender princeton 6g2 schem [105 KB]
    fender princeton 6g2 schematic [44 KB]
    fender princeton 65 dsp guitar amplifier schematic [1015 KB]
    fender princeton 65 guitar amplifier schematic [272 KB]
    fender princeton 112 plus guitar amplifier schematic [302 KB]
    fender princeton 650 guitar amplifier schematic [1005 KB]
    fender princeton aa964 layout [55 KB]
    fender princeton aa964 schem [101 KB]
    fender princeton aa964 schematic [45 KB]
    fender princeton chorus dsp guitar amplifier schematic [1 MB]
    fender princeton rev boostpedal [71 KB]
    fender princeton reverb aa1164 layout [49 KB]
    fender princeton reverb aa1164 schem [91 KB]
    fender princeton reverb aa1164 schematic [40 KB]
    fender princetonreverb b1270 schematic [66 KB]
    fender princeton rev gz34 aa1164 [2 MB]
    fender princeton rev ii boost [85 KB]
    fender princeton schematic [43 KB]
    https://www.tdpri.com/threads/the-fender-princeton-non-reverb-thread.123326/
    The Fender Princeton (non-reverb) Thread
    32,663
    Received: 2,126/7
    55
    I only see a two way switch. It selects one side or the other side of the mains for the ground cap. It doesn't indicate center off or a third position as far as I can see.
    Twobie
    Dec 2019
    4
    0
    Thank you for the links vintagekiki. Believe it or not, this amp is not listed in any of the links. The schematic designated "fender princeton rev boostpedal" appears to be the correct vintage, but I have a non-reverb amp with no pull boost.
    Yes Enzo, the ground switch is center off.
    The power transformer in this amp is a 010020, indicated in the boostpedal schematic as an "alternate hook up". The rectifier is a 5U4.
    Jul 2006
    1,726
    Received: 301/2
    Given: 272/0
    16
    Fender PT 010020 is dual primary transformer (connected in parallel for 120V, series for 240V) used in Import/Export amp (like princeton B1270)
    For first aid, compare layout from schematic princeton aa964 (page 2) with your princeton NR. Any differences in value of parts, enter to layout, and will get schematic of your princeton NR.
    http://ampwares.com/schematics/PRINCETON_REVERB_AB1270.pdf
    Twobie
    Dec 2019
    4
    0
    Yep, looks like the way to go.
  1. 1979 Fender Super Six Reverb Restoration
    By Wittgenstein in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-03-2019, 06:53 PM
  2. Fender 65 Princeton Reverb --Reverb Circuit Send failure
    By nevetslab in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-13-2019, 12:00 AM
  3. 1979 Fender Silverface Super Reverb bias too cold...
    By '66Cuda in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-30-2016, 05:12 PM
  4. 1979 Fender Pro Reverb Master Volume
    By Shawnobi in forum Schematic Requests
    Last Post: 12-11-2013, 11:01 PM
  5. 1979 Fender Twin Reverb - can't turn off reverb
    By pro1911a1 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-02-2009, 03:40 PM
