New tubes, the filaments light up, speakers connected but no sound. I don't know these amps, any experts out there?
Blackstar ht40 No Sound
It should output to phones in standby to verify the preamp side. If the amp is stuck in standby there will be a larger than usual negative voltage on the output tube grids of around -90v, The MOSFET PI on these amps can fail due to leakage between pins. If one side is gone the output is low-volume and distorted. If both, then no sound. When they begin to fail it sounds like bad output tubes. Check the gate voltages on both MOSFETS. If bad you'll see tens of volts.
Originally posted by Perkinsman View PostUpdate: turns out the owner had disassembled the top cab screws & didn’t support the head. It dropped & cracked a power tube. I removed the tube socket (very tight) & replaced the tubes but no sound, just filaments lighting. What would be the likely suspects?
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
No headphone or line out but there is an effects return/send but I’m not sure how to test. I ran an external test speaker into the Fx send & guitar into the input but still nothing. I tested voltages on both preamp tubes & power tubes & while I’m getting ac to light filaments, I get very low dc voltages in mv range.
Originally posted by Perkinsman View PostAlso tried attaching the speaker to the speaker output & the guitar into the Fx send, nothing.
try this Plug guitar into FX return and play do you get sound at speaker?
Nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by Perkinsman View PostNothing either way
We will start at the power supply Page 3 check F1 and F2 and F5.
Then at TP9 you should see 3.3v
TP11 +12.6v and TP12 -12.6v
Then go back to Micks post #4.
Originally posted by nosaj View PostIn that case it's time to get dirty. Here is the schematichttp://dealers.korgusa.com/svcfiles/...0schematic.pdf
nosajOriginally posted by Mick Bailey View PostIt should output to phones in standby to verify the preamp side. If the amp is stuck in standby there will be a larger than usual negative voltage on the output tube grids of around -90v, The MOSFET PI on these amps can fail due to leakage between pins. If one side is gone the output is low-volume and distorted. If both, then no sound. When they begin to fail it sounds like bad output tubes. Check the gate voltages on both MOSFETS. If bad you'll see tens of volts.Originally posted by Perkinsman View PostThanks nosaj...I’ve got to wait until later today or tomorrow to get back on it.
V3&V4 grids -76.6
I’m not sure which ones are mosfets, can you please tell me their number.
