Results 1 to 10 of 10
Thread: Strange switch behaviour
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    2,569
    Received: 607/0
    Given: 109/0
    10
    I'm looking at a Dr Z amp that runs four 6V6s, and has a Hi/Lo switch that switches a grid on each pair from either signal or 100K to ground. It was making a fair bit of noise in the Hi power position, so I got some deoxit in there. While I was investigating, I found the center tab measured a short to one side of the switch in one position, and 190K ohms to the same point in the other position. This true for all four cases, 190K to either side when in the off position, for both switches. Just to be sure I lifted the most accessable connection to the center lug, and the same is true. I realize switches go bad, but the same resistance in all four cases?
    Before I replace this switch, is there such a thing as a resistive DPDT switch? So strange.
    Dec 2008
    Wernersville, PA
    13,074
    Received: 609/3
    Given: 314/0
    28
    It seems to me that what you are reading is two grid resistors in series.
    1 Not allowed! Not allowed!
    Jan 2013
    Cape Coral, FL
    2,569
    Received: 607/0
    Given: 109/0
    10
    "It seems to me that what you are reading is two grid resistors in series."
    No, I really don't thinks so. The grid resistors are 1.2K, and I don't see a path for any series connection. Plus, the center wiper, or common, whatever it is called, is disconected. Another thing I just realized, the two outside terminals of the switch measure 189K and 190K across each of them respectively.
    May 2010
    Sioux Falls, SD
    6,717
    Received: 1,515/1
    Given: 1,122/1
    17
    Do you have a schematic so we can see what's going on in the circuit?
    Cheshire, UK
    2,307
    Received: 614/4
    Given: 314/0
    16
    Perhaps it's like this?
    2 Not allowed! Not allowed!
    Feb 2010
    12,380
    Received: 2,032/24
    Given: 5,182/11
    24
    Might as well just disconnect completely and measure.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,983
    Received: 2,274/7
    55
    I THINK he meant two of the 100k resistors in series. As in perhaps the grid return resistors. I could imagine two resistors to ground, and when the switch opens measuring resistor to resistor yields 200k, 190k close enough, the fact that they go to ground in the middle doesn't change that. Possible?
    Cheshire, UK
    2,307
    Received: 614/4
    Given: 314/0
    16
    This would make it 190k
    Jan 2013
    Cape Coral, FL
    2,569
    Received: 607/0
    Given: 109/0
    10
    It is wired like the one in post #5 if you change the leftmost 100K to 90K. It's a Dr Z so no schematic. I was reluctant to do much disconnecting given the immaculate wiring and red marker dots on every solder point, but once I did the switch acted normally, so it seems I actually have no problem here.
    I still really am not seeing why I get 190K across the switch with it all connected.
    edit: Oh wait, light bulb goes off, now I get it. The 100K and 90K are connected at ground putting them in series, but being grounded really doesn't have anything to do with it. DOH.
    Attached Images Attached Images
    Dec 2009
    Canada
    342
    Received: 180/0
    Given: 6/0
    11
    This may be the schematic (reverse engineered). I don't remember where I found it.
    https://music-electronics-forum.com/...1&d=1578431216
Name:	Dr Z Remedy.gif
  1. Strange guitar pickup behaviour
    By plithner in forum Guitar Tech
    Last Post: 09-24-2019, 11:07 PM
  2. 5E3 tone pot strange behaviour
    By Bluefinger in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-17-2017, 11:34 PM
  3. Peavey Vypyr 100 strange behaviour
    By Nyqusit5 in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-14-2016, 07:53 AM
  4. Replies: 25
    Last Post: 03-27-2016, 11:47 PM
  5. Presence control strange behaviour
    By GainFreak in forum Debugging Your Build
    Last Post: 09-20-2012, 05:09 PM
