With the clips to 1/4" jack you lose some shielding you would have with a real cable, but this is just for testing, not usage.
Blues Deluxe Reissue-No Sound
But really, you have the HP unit, why not take a moment and complete the instrument? Make up a cord with 1/4" male on one end and a connector to match the HP on the other. In your case a dual banana plug. You know you are going to need it again and again. I always had a couple such cables on my bench rack.
Got a guitar cord with a bad end? Clip that end off and wire a banana plug there. Two minute job.
I had a few more that were the same but with zip cord for use as speaker cables. Good for connecting amps and cabs to my speaker/load patch panel on my bench.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostBut really, you have the HP unit, why not take a moment and complete the instrument? Make up a cord with 1/4" male on one end and a connector to match the HP on the other. In your case a dual banana plug. You know you are going to need it again and again. I always had a couple such cables on my bench rack.
Manufacturers often specify very low signal levels, like 4mV or 6mV input signal. Such low levels ensure that each following stage is operated within its linear range and stage gains can be exactly determinated and verified from the ratios of output to input voltages.
With large input signals the gain of a stage typically changes (mostly drops) even without actual clipping. Also DC voltages shift.Last edited by Helmholtz; 01-17-2020, 02:28 PM.- Own Opinions Only -
If the amp clips then the AC voltage measurements would be very difficult for a manufacturer to specify. The easier and more consistent way to do this is to ensure that the test voltages are easily reproducible and this means keeping everything clean.
Also, different meters can give wildly different RMS readings for a distorted AC waveform.
Originally posted by Mick Bailey View PostIf the amp clips then the AC voltage measurements would be very difficult for a manufacturer to specify. The easier and more consistent way to do this is to ensure that the test voltages are easily reproducible and this means keeping everything clean.
I would love to get this amps volume to increase today...I have another observation that may or may not help solve this mystery. Neither the bright or the channel select switches are working. Could this be related to the low volume issue? Ive cleaned both switches but no improvement. If either switch is broken, would that prevent the volume from increasing?
Originally posted by Perkinsman View PostI’ve been going over power supply voltages. Can someone tell me whether D13 cathode should read .7? It looks like +17 on the schematic. If this diode is bad, would it prevent the volume from this increasing?- Own Opinions Only -
Originally posted by Helmholtz View PostD13 and D14 are 16V zeners. What are DC voltages at TP45/TP46?
