Results 1 to 9 of 9
Thread: Blown Transformer on 2006 Carvin V3
    New Member
    Jan 2020
    5
    0
    Unhappy Blown Transformer on 2006 Carvin V3
    I have the original version of the Carvin V3 Head. I believe it's power transformer went out because I measure 5 ohms between hot and return of the IEC when I flip the mains "on" while unplugged. 6A circuit breaker inline tells me I know the transformer should be at a minimum 20 ohms (the circuit breaker flips off within 1 second of turning the amp on). I looked up the V3 schematic and found the transformer to be 15-10714. That's all the information I can find on it. Does anybody know this transformer by another name, who makes it, how to get a replacement, was it proprietary to carvin, any information about it? Thanks.
    Supporting Member
    Mar 2018
    Germany
    3,235
    Received: 2,358/1
    Given: 1,342/2
    8
    I think you are mixing up DCR and primary impedance. Such low primary DCR values are not uncommon with PTs.
    Does the circuit breaker trip with all secondary wires disconnected?
    - Own Opinions Only -
    New Member
    Jan 2020
    5
    0
    Yeah it still trips even with the secondary wires' connector unplugged from the PCB, so that leaves me to the IEC, power transformer, or circuit breaker. I guess you have a good point that I shouldn't have jumped to the power transformer from the low DCR since this is AC current which will have more resistance from the 'inductor'. Any other troubleshooting tips? Thanks!
    Jan 2011
    NorCal
    487
    Received: 105/10
    Given: 118/0
    10
    You can test transformers using the neon bulb trick:
    https://www.premierguitar.com/articl...ormer-tester-1
    http://amps.monkeymatic.com
    Supporting Member
    Aug 2017
    Portland, OR
    874
    Received: 319/1
    Given: 135/2
    3
    This appears to be a pretty simple tube PT, no low voltage windings for op amps or anything, no tube rectifier heaters either.
    Maybe something like the Edcore XPWR002? https://www.edcorusa.com/xpwr002
    New Member
    Jan 2020
    5
    0
    Quote Originally Posted by xtian View Post
    So I don't have a neon bulb; however, I do have a multimeter. Using a 9V battery in the same manner he used the 6V battery, the secondary coil (700V to 120V input) only jumped to 1V each time. The highest I could get it to jump was to 4V. I would expect somewhere in the 60V range for a 7:1 turn transformer using this trick. Thanks for the idea, but I'm still left thinking the transformer is toast. Here are some pictures. Looks a little....liquidy... on the top there.
    https://i.imgur.com/2q0eAD5.jpg
    https://i.imgur.com/PoM6pCB.jpg
    New Member
    Jan 2020
    5
    0
    Thanks for the tip about edcore. I found this one https://www.tubeampdoctor.com/en/mai...nmQaCyv0E2Pek0 which shows 400mA at 345V and 7.5A at 6.3V. Assuming that website is correct, it looks like edcore does have an option to meet that: https://www.edcorusa.com/xpwr127?fbc...th-iu8XDuPIjcc Not sure how I feel about the 8 week lead time though.
    Supporting Member
    Mar 2018
    Germany
    3,235
    Received: 2,358/1
    Given: 1,342/2
    8
    You can't replace the neon with a multimeter. The principle is magnetic (self) induction and works similar to a spark coil. Disconnecting the battery interrupts the current and produces a large but short flyback voltage spike that overcomes the ignition voltage of the neon lamp. Other than a neon discharge lamp a meter conducts all the time and thus prevents a large voltage spike. Also meters are much too slow. The neon lamp doesn't conduct below its ignition voltage of 60V to 80V and reacts very fast.
    But I agree your PT looks toasted.
    There are other methods to test a transformer. Do you have a bulb limiter? Or some other PT that delivers heater voltage?
    New Member
    Jan 2020
    5
    0
    You can't replace the neon with a multimeter. The principle of the test is based on (self) induction. Disconnecting the battery interrupts the current and produces a large but short flyback voltage spike that overcomes the ignition voltage of the neon lamp. Other than a neon discharge lamp a meter conducts all the time and thus prevents a large voltage spike. Also it's too slow. The neon lamp doesn't conduct below its ignition voltage of 60V to 80V and reacts very fast.
    I see your points on a multimeter vs the bulb. I don't have a bulb limiter either, nor other PT unless I pull one out of my Dr Z. I put this PT back in the carvin and turned it on again, just to make sure the problem continued to be repeatable and of course it was. This time I paid attention to the LEDs which always flash on immediately with power. The breaker popper after about 1 second, but during that 1 second, no LEDs turn on, the lamp bulb doesn't turn on, nothing even flickers. I'm fairly confident the PT isn't working at all.
  1. Very low volume, farty overdrive. Blown transformer?
    By Triocd in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-20-2017, 07:53 PM
  2. Carvin DCM600 Toroid Transformer
    By Vraulysson in forum Other Amps
    Last Post: 05-06-2017, 12:28 AM
  3. Carvin Sx-200 blown switching power supply
    By DGstrat in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-11-2015, 12:46 PM
  4. Teisco Checkmate 20 blown power transformer
    By Zouto in forum Vintage Amps
    Last Post: 03-02-2012, 03:19 PM
  5. Power Transformer Blown?
    By Tim C. in forum 5 E 3
    Last Post: 10-07-2008, 02:34 PM
Tags for this Thread
