Results 1 to 6 of 6
Thread: Two failed pickups in two Epiphones this week
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    2,651
    Received: 639/0
    Given: 113/0
    10
    I currently have two Epiphone acoustics in, AJ-220SCE and AJ-200SCE with the same problem. Loud hum that I believe is the Nanoflex under saddle pickup failure, made by Shadow Electronics. One guitar also has a NanoMag magnetic pickup that also appears to be dead. If I plug in a spare mini plug into either input jack I can get noise at the 1/4" output jack, so it appears the preamp is functioning. I had already ordered a replacement NanoFlex from Shadow that is on the way, so I will be able to confirm both guitars in a few days.
    Just seems odd to have two of the same failed pickups in at the same time. Methinks this may be a product prone to failure, and only one source for replacement that I can see. I would steer clear of the Epis with Shadow pickups now.
    1 Not allowed! Not allowed!
    Jan 2013
    Cape Coral, FL
    2,651
    Received: 639/0
    Given: 113/0
    10
    And a third one in this week, same issue.
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    6,889
    Received: 1,785/21
    Given: 1,460/0
    14
    Quote Originally Posted by Randall View Post
    That, or get your Epi at a bargain price, figuring in the eventual cost of having to replace the pickup & maybe the whole p/u & preamp system.
    Hmm, a third one within a week? As Arlo said, that's a movement!
    Enjoy. Every. Sandwich.
    Jan 2013
    Cape Coral, FL
    2,651
    Received: 639/0
    Given: 113/0
    10
    And it just gets worse, the latest replacement version is fixed at a 90 degree angle with a smaller male plug. You have to drill out the hole in the guitar, which is at about a 45 degree angle, to get the new fixed arrangement installed from the top. Not so bad, except this replacement does not work. Original pickup measures 675 ohms, this new one is open. Called Traveller Guitars about it, got voice mail. Still waiting for a call back.
    Jan 2013
    Cape Coral, FL
    2,651
    Received: 639/0
    Given: 113/0
    10
    Never did get a call back, but I did get someone from the seller, Traveler Guitars, on the line finally. Turns out what they sent doesn't work with this preamp. I still think an open reading says it's faulty, but they can have it back. The direct replacement is out of stock coming from China, and under the present world circumstances there is no real idea when they will be fulfilled.
    Not real impressed at this point.
    May 2010
    Sioux Falls, SD
    6,904
    Received: 1,681/2
    Given: 1,210/1
    18
    Perhaps it's a piezo pickup and it's supposed to read open?
  1. Looking for .195" Humbucker Slugs (For Epiphones)
    By ZRGuitarPickups in forum Tools and Coil Winding Gear
    Last Post: 11-07-2018, 12:54 AM
  2. Replies: 3
    Last Post: 08-13-2017, 05:47 PM
  3. Deluxe Reverb FAILED at gig
    By Steve Casas in forum Repair and Restoration
    Last Post: 01-11-2010, 08:32 PM
  4. Deluxe Reverb FAILED at gig!
    By Steve Casas in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-05-2009, 11:35 PM
