Page 1 of 2 12 LastLast
Results 1 to 35 of 37
Thread: Voice of Music Amp - VM 160
  1. #1
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    Ok. I know I have a problem. The first step to recovery is to admit the problem. I'm a vintage tube amp addict! Here is my latest acquisition. Appears to be about 1952 Voice of Music Model 160 amp. Its not a guitar amp, but it looks like a good candidate. Here are the pics as it arrived.
ID:	56730 Click image for larger version.
ID:	56731 Click image for larger version.
    3 Not allowed! Not allowed!
  2. #2
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    More pics.
ID:	56733 Click image for larger version.
ID:	56734 Click image for larger version.
    0 Not allowed! Not allowed!
  3. #3
    "Thermionic Apocalypse" -JT nickb's Avatar
    Join Date
    Dec 2009
    Location
    Devon, UK
    Posts
    3,812
    Thumbs Up/Down
    Received: 942/1
    Given: 693/1
    Rep Power
    14
    Could make a guitar amp with some mods.
    Schematic:
    1 Not allowed! Not allowed!
  4. #4
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    Quote Originally Posted by nickb View Post
    Schematic:
    Thanks for the schematic! Besides replacing the input jacks with 1/4", what mods would you suggest?
  5. #5
    Join Date
    Dec 2009
    Location
    Devon, UK
    Posts
    3,812
    Thumbs Up/Down
    Received: 942/1
    Given: 693/1
    Rep Power
    14
    I'd cascade the mic input through a tone stack and then to the phono input. Maybe add a cathode bypass cap to to mic input for less hum and more gain. Also add a further RC filter stage in the power supply to feed the mic input.
  6. #6
    Bent Member Chuck H's Avatar
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,465
    Thumbs Up/Down
    Received: 3,084/5
    Given: 3,725/0
    Rep Power
    32
    FWIW I built a little 2x6v6 amp from the guts of a VOM phonograph. It sounded remarkably better than you might expect from the 300Vp and that tiny OT. It actually had a great low end and literally perfect , classic, definition of the model BF Fender clean tone. And because of the low-ish plate voltage it would move very gracefully into thick, cello like clipping. The cabinet I made for it was pretty crappy and I'd built the rest of the circuit from scrap components PTP and all squeezed into the tiny chassis. So I decided to tear it down for a proper build of the same circuit some time. So I still have the transformers. My PT is a stand up whereas yours is a lay down (Z mount?). But the OT looks like the same one I have. I don't think you'll be disappointed
    2 Not allowed! Not allowed!
    "Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
  7. #7
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    Quote Originally Posted by Chuck H View Post
    That's what I'm thinking. The cabinet on this one looks pretty decent. Its cleaning up real nice. I really like the way the amp chassis slide out and can sit on the side. Very cool.
  8. #8
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    Heres the underside of the chassis. Comes with a schematic too!
ID:	56761 Click image for larger version.
  9. #9
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    33,470
    Thumbs Up/Down
    Received: 2,534/7
    Given: 0/0
    Rep Power
    57
    The schematic looks good but hard to see. Do you have a scanner? My printers are also scanners, for example. A pdf scan might be easier to work with. Unless it is the same as the one posted up in post #3?
    It looks like someone already replaced a filter cap, but that orange one has a date code of 1973, so evven it is getting old. meanwhile I would be surprised if all those paper caps didn't need replacement. Probably leaky by now. Note the resistors are all 20%, and even then likely drifted, but frankly that probably doesn't matter much. Just don't expect a "100k" resistor to measure 100k.
    But looks good and clean.
  10. #10
    Join Date
    Dec 2008
    Posts
    834
    Thumbs Up/Down
    Received: 50/1
    Given: 24/1
    Rep Power
    12
    What looks like a Sprague black tubular capacitor would not be original either if the amp is from the early 1950s.
    At this point in history, it's not unusual to be doing a 2nd refurbishment of amps from this era.
  11. #11
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    Quote Originally Posted by Enzo View Post
    Here is a scan of the schematic. Not much better though.
    VM160.pdf
  12. #12
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    Quote Originally Posted by Rhodesplyr View Post
    The can cap and the sprague look like replacements. The values are also double of the schematic values. 40mf instead of 20.
  13. #13
    Join Date
    May 2006
    Location
    Posts
    33,470
    Thumbs Up/Down
    Received: 2,534/7
    Given: 0/0
    Rep Power
    57
    You're right, not much better. But a have to say thanks for doing it.
  14. #14
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    Ok. One more time. This time I took a pic of the schematic with a better camera.
  15. #15
    Stray Cap DrGonz78's Avatar
    Join Date
    Oct 2011
    Location
    Scottsdale, AZ
    Posts
    2,227
    Blog Entries
    1
    Thumbs Up/Down
    Received: 402/5
    Given: 308/0
    Rep Power
    11
    Quote Originally Posted by tigerzilly View Post
    Picture seems a bit dark so lighted it up a tad.
  16. #16
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    Got the new caps in and replaced one tube socket. The amp had a three prong plug, but only two conductor wire. Replaced the power cord and grounded. Amp powered up and passes good signal. Plugged a guitar into the 1/4" microphone jack. Decent sound with fair volume. The original 10" speaker has some buzzing . Got it running through a 12" and it sounds much better.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	56974   Click image for larger version.
  17. #17
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,465
    Thumbs Up/Down
    Received: 3,084/5
    Given: 3,725/0
    Rep Power
    32
    Please make these changes and let us know how it works out
  18. #18
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    I presume that change will make it more guitar friendly. Any thoughts on Jensen P10S alnico speaker? It gonna need a recone. Is the speaker worth saving?
  19. #19
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,465
    Thumbs Up/Down
    Received: 3,084/5
    Given: 3,725/0
    Rep Power
    32
    Jensen's "S" model was a step below their "R" line. I have no idea what the real world difference is between the p10s and the p10r, but the p10r is the more desirable speaker. That being the case you wouldn't really be money ahead to recone it. And being as this will never be a collectible amp I wouldn't be concerned about preserving the original speaker for it either. But it's probably a perfectly good sounding speaker and if you did have it reconed it would probably get "R" parts anyway.?. I think the magnet was the same on both speakers. So in this light I'd probably look into the cost of a recone vs. say, a new Weber or something and then go with the cheaper option.
  20. #20
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    I can get a Jensen MOD for $35. Recone is $65. I can store the original Jensen away in the unlikely event it adds value.
  21. #21
    Member HaroldBrooks's Avatar
    Join Date
    Mar 2019
    Posts
    337
    Thumbs Up/Down
    Received: 184/0
    Given: 1,013/0
    Rep Power
    2
    Here's what you amp 'problem' reminds me of...
    https://www.youtube.com/watch?v=URSnFwRGw_I
    You came to the right place for help... if you never want to get better that is !
    THAT FUTURE GUITAR AMP LOOKS GOOD TO ME !
    " Things change, not always for the better. " - Leo_Gnardo
  22. #22
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,465
    Thumbs Up/Down
    Received: 3,084/5
    Given: 3,725/0
    Rep Power
    32
    I've never tried the MOD, but I've read that it's designed for a very wide and flat frequency response for modeling amps that simulate different cabinet types. And that doesn't sound great to me for a basic toob amp. $65 bucks seems like a good price for what will basically be a new speaker. And if I'm right, the magnets are the same AND they recone with "r" parts you'd be getting what amounts to a new p10r for $65.
  23. #23
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    The P10S appears to be a 9 watt speaker. The amp according to the schematic is 8 watts. Seems it would be nice to have a little more margin above the amps power rating. Will R parts give the speaker more power handling.
    I have used the Jensen MOD in the past. No complaints at all.
    I started making those changes you recommend. I need to order the 2.2uf cap. The 1M and 47k resistors are in.
  24. #24
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,465
    Thumbs Up/Down
    Received: 3,084/5
    Given: 3,725/0
    Rep Power
    32
    The changes work in tandem, not individually. The operation of the tube is altered from grid leak to cathode bias. The 1.5k cathode resistor in place of the 4.7k will increase signal sensitivity at the input and run the tube at a higher idle current. This is when you need the 1M grid load resistor instead of the 4.7M that was in there. You could use any capacitor value over 470n for the capacitor parallel to the 1.5k cathode resistor. I think a value of 2.2u or smaller is best because there's really no high pass filtration like most guitar amps. A partial bypass on that stage will boost above a frequency dictated by it's value. Smaller = higher frequency knee. Anything over 3.3uf is basically all audible frequencies boosted.
  25. #25
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,465
    Thumbs Up/Down
    Received: 3,084/5
    Given: 3,725/0
    Rep Power
    32
    More searching didn't reveal a direct comparison between the s and r models for the 10", but I did find the 12" s and r side by side in a catalog page. It's probable the the magnet on the p10s is smaller than the r, but the voice coil diameter is likely the same. So, putting r parts on the speaker (if that's what can happen) won't up it's output, but power handling is about heat. So I would think that the heavier gauge voice coil might up it's power rating. Also, modern adhesives do a lot for power handling too. But I'm no speaker expert. I can't actually find vintage catalog info on the p10r.?. It's interesting the a modern p10r is rated at 25W but the in the vintage catalog a p12r is only rated for 14W (the p12s is rated for 13W). With this info on hand I would have to guess that an actual vintage p10r was probably a 10W speaker (the p10s being rated at 9W). Not 25W like a modern p10r. But I don't know. But the point is that I don't think the wattage will be a problem. If four 10W p10r speakers could live in a cranked up Bassman I think your p10s will be fine in your amp. Especially considering any upgrade possible with the recone. But I'm out of my depth now.
  26. #26
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    I got the 2.2mf cap and finished the recommended mod to the input. Also got the new Jensen speaker. Its sounds really good. Only issue now is vibration from the handle on top of the speaker cabinet. That may have been what I was hearing when I decided to put in a new speaker.
ID:	57323   Click image for larger version.
  27. #27
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    I bought a roll of neoprene foam with adhesive on one side for my boat to seal the hatch. The extra has been serving me well for solving cabinet and chassis vibration issues. Works on the handle too.
  28. #28
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    I discovered the best reason for keeping the old speaker. The amp won't fit in the cabinet with the new speaker. The. 5Y3GT is bumping up against the new speaker magnet before the amp is slid all the way back in.
  29. #29
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    So back in with the old speaker. I doped up the rips and the outer edge of the cone. The new Jensen was louder and sounded good. The old P10S has early breakup with a more distinct sound. The handle rattle gave it the offensive noise. At least now the amp fits back in the cabinet as it should.
ID:	57336   Click image for larger version.
ID:	57337   Click image for larger version.
  30. #30
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,465
    Thumbs Up/Down
    Received: 3,084/5
    Given: 3,725/0
    Rep Power
    32
    The standard fix for cone tears is layers of tissue and water resistant carpenters glue. The fix for edge surrounds is the heaviest tissue you can get and rubber cement. You seem to have done well enough as it is. And yes, the speaker depth thing can be annoying. The last amp I sent off my bench has the 5y3 just slightly inside the gap of the speaker frame. I had to rotate the speaker a quarter turn to achieve this and fortunately the cone doesn't whack on the rectifier tube BUT... I knew this going in and I checked the mounting depth of the new speaker before purchase. Figuring it might come to that. So you live and learn.
    The MOD speaker is expressly said to NOT have a distinct tone. It's touted for modeling amps that include cabinet simulation so it's whole point is to have the frequency response to imitate most anything when certain frequencies are nulled rather than added. If you get my meaning. But people seem to like it well enough in several non modeling amps as well. Too bad it doesn't fit, but it's not a bad speaker to have on hand for a future project. So there's that.
    Glad you like the circuit changes.
  31. #31
    Supporting Member The Dude's Avatar
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,926
    Thumbs Up/Down
    Received: 1,693/2
    Given: 1,218/1
    Rep Power
    18
    Part question- part suggestion: Looking at your first post, I notice the chassis of the amp doesn't sit all the way back or flush with the rear of the cabinet. I'm attaching a picture to show the area I'm talking about. See the red dot. If you cut that board under the chasssis to allow the whole chassis to go back a bit so the face plate meets the rear of the cabinet, would that give you enough room for your new speaker? I obviously can't know without measuring, but it could be an option if it will work.
    In other words, cut off that piece of wood on this line so that the chassis is further away from the speaker. Maybe that gets you enough room?
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  32. #32
    Join Date
    May 2006
    Location
    Posts
    33,470
    Thumbs Up/Down
    Received: 2,534/7
    Given: 0/0
    Rep Power
    57
    Or get one of those plug in solid state rectifiers, they are short. If all that is in the way is the recto tube...
  33. #33
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,465
    Thumbs Up/Down
    Received: 3,084/5
    Given: 3,725/0
    Rep Power
    32
    And maybe find a way to touch up the paint loss (from cleaning?) of the VM logo
  34. #34
    Old Timer olddawg's Avatar
    Join Date
    Dec 2007
    Location
    La Jolla CA, Kapaa Kauai
    Posts
    3,312
    Thumbs Up/Down
    Received: 489/6
    Given: 56/1
    Rep Power
    16
    Might also raise the B+ a bit and you may like the amp better. A couple of diodes soldered under the socket would be cheaper.
  35. #35
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    132
    Thumbs Up/Down
    Received: 74/0
    Given: 48/0
    Rep Power
    0
    I learned that the old speaker sounds pretty damn good! And yes I do like the circuit change. Thanks for taking the time to provide a revised schematic!
    I had a friend over today and I recorded him playing through the VM. He was loving the tone. Here are some clips.
    Attached Files Attached Files
Thread Information
Users Browsing this Thread
  1. Voice of Music Model 1450
    By Brad1 in forum Mods & Tweaks
    Last Post: 09-25-2017, 08:32 PM
  2. Voice of Music 722 conversion
    By Foxfire in forum Conversion Projects
    Last Post: 02-27-2012, 05:19 PM
  3. Voice of Music 8810 catastrophe
    By bluzmn in forum Music Electronics
    Last Post: 01-11-2011, 04:30 PM
  4. Voice of Music Model 700 (1955)
    By baddog in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-10-2008, 01:59 PM
  5. Check out my Voice of Music 162!!
    By Regis in forum Vintage Amps
    Last Post: 07-22-2006, 11:03 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
