Voice of Music Amp - VM 160
I'd cascade the mic input through a tone stack and then to the phono input. Maybe add a cathode bypass cap to to mic input for less hum and more gain. Also add a further RC filter stage in the power supply to feed the mic input.Experience is something you get, just after you really needed it.
FWIW I built a little 2x6v6 amp from the guts of a VOM phonograph. It sounded remarkably better than you might expect from the 300Vp and that tiny OT. It actually had a great low end and literally perfect , classic, definition of the model BF Fender clean tone. And because of the low-ish plate voltage it would move very gracefully into thick, cello like clipping. The cabinet I made for it was pretty crappy and I'd built the rest of the circuit from scrap components PTP and all squeezed into the tiny chassis. So I decided to tear it down for a proper build of the same circuit some time. So I still have the transformers. My PT is a stand up whereas yours is a lay down (Z mount?). But the OT looks like the same one I have. I don't think you'll be disappointed"Take two placebos, works twice as well." Enzo
The schematic looks good but hard to see. Do you have a scanner? My printers are also scanners, for example. A pdf scan might be easier to work with. Unless it is the same as the one posted up in post #3?
It looks like someone already replaced a filter cap, but that orange one has a date code of 1973, so evven it is getting old. meanwhile I would be surprised if all those paper caps didn't need replacement. Probably leaky by now. Note the resistors are all 20%, and even then likely drifted, but frankly that probably doesn't matter much. Just don't expect a "100k" resistor to measure 100k.
But looks good and clean.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostThe schematic looks good but hard to see. Do you have a scanner? My printers are also scanners, for example. A pdf scan might be easier to work with. Unless it is the same as the one posted up in post #3?
VM160.pdf
Originally posted by Rhodesplyr View PostWhat looks like a Sprague black tubular capacitor would not be original either if the amp is from the early 1950s.
At this point in history, it's not unusual to be doing a 2nd refurbishment of amps from this era.
