Results 1 to 6 of 6
Thread: weird ARS capacitor
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    2,547
    Received: 604/0
    Given: 107/0
    10
    weird ARS capacitor
    I have a Blues Deluxe in that was absolutely hacked to death, burnt off pads everywhere. I got it operating, but it still has a slight buzz and 3 Vac on the B+. I am reluctant to pull the board much more in fear of the ribbon cables I had to strip and reinstall (what a nightmare) being disturbed and causing further problems, so I am going to try to sell the idea that a small buzz is not worth the risk of flexing those ribbons any more than really necessary.
    But I wonder about these two ARS electrolytics, they have the positive indentation on both ends like a nonpolarized cap, except they have the negative arrow pointing to one end as well. I have no experience with ARS axial caps, and have never seen a cap designated like this before. Anyone have any insight. The other axial filter caps are ARS as well, but with normal designations.
    Also, the underside of the board is pretty burnt up where the cement resistors are, someone had done a crude job of replacing them and fixing the damaged traces. I wonder if the buzz may be stray voltages from the carbon, but as I said I think living with some buzz is the answer here.
    Supporting Member
    Dec 2009
    UK
    3,744
    Received: 434/0
    Given: 80/0
    14
    3 Vac is about right for the first node. Check the ripple at the 1st preamp tube - it should be around 3 or 4mv.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,930
    Received: 2,249/7
    55
    3vAC on the first node? That is less than 1% and sounds pretty good to me.
    Is your hum 60Hz or 120Hz?
    Have we tried to isolate the hum source? Hum is not generic. DO ANY of the controls affect the hum in ANY way?
    Hum can easily come from unbalanced power stage, so make sure EVERY power tube has screen B+ present.
    Also, Fender in this series was notorious for cracked solder on the octal sockets, so resolder all those pins.
    Jan 2013
    Cape Coral, FL
    2,547
    Received: 604/0
    Given: 107/0
    10
    Customer came for his amp this morning, but I can tell you the tubes are closely matched, sockets had all been re-soldered, and no control affected it. I didn't look into 60 vs. 120Hz, I suppose I should have. He is happy with how it now is, therefore so am I!
    Sep 2011
    Pace, FL
    3,395
    Received: 1,205/102
    Given: 172/36
    12
    Quote Originally Posted by Randall View Post
    Doesnt 120hz hum signify a failed failing filter cap where the dc is not being filtered enough?
    nosaj
    32,930
    Received: 2,249/7
    55
    Not exactly. It tells us the hum is RELATED to the power supply ripple. Grounding could be the problem, if circuits share copper in the ground returns for filter caps. Caps themselves might be great, but there is a ripple charging current spike at 120Hz, and it can get into sensitive circuits.
  1. SVT-CL - another weird one.
    By TimmyP1955 in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-01-2019, 04:47 AM
  2. Replies: 9
    Last Post: 09-06-2017, 02:43 PM
  3. Weird, Weird stuff with the PT of a Twin, Secondary Voltage.
    By wizard333 in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-11-2013, 07:58 AM
  4. Here's a weird one...
    By ninjadave7 in forum Music Electronics
    Last Post: 12-12-2011, 04:03 PM
  5. Weird amp hum
    By Doctor Jeff in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-24-2010, 05:08 AM
