Results 1 to 22 of 22
Thread: Repurposing Computer Power Supply Wiring
    Jan 2014
    Chicago
    123
    Received: 52/2
    Given: 91/2
    7
    When talking to a tech a number of years ago he shared how he used this wire. I quizzed him about it due to the conductors appearing to be plain steel, and he asserted that it's tinned copper. Following various stripping, scraping, scratching, shearing attempts I haven't seen a glimpse of any coppery shine to the conductors.
    Would one be advised to not use wire, with no copper content, in an amp?
    I'm one of these people who likes to reuse stuff or find new uses for stuff instead of binning it.
    Most of the stuff I have here is around 16-22 AWG, rated at 300V, 80-90 deg C. Obviously dc voltages in most amps exceed 300V.
    Anybody care to comment that'd be lovely.
    1 Not allowed! Not allowed!
    Supporting Member
    Mar 2018
    Germany
    3,228
    Received: 2,358/1
    Given: 1,337/2
    8
    You can test for steel using a Neo magnet. And of course steel is much more sturdy and resilient than copper.
    Apart from silver, copper is the best conductor available. Steel is a rather poor conductor, producing increased losses and possible ground loop problems in an amp.
    2 Not allowed! Not allowed!
    - Own Opinions Only -
    Lifetime Member
    4,474
    Received: 460/1
    Given: 3/0
    22
    It would be very unusual for the wiring to be steel, but I guess it's possible. More likely it's tinned copper. As Helmholz notes, a magnet tells the tale.
    Solder plated steel has been used for some component leads, notably for resistors, as I found in one of my own early magnet tests. There's no particular problem with using low-carbon steel as wiring, if you take into account:
    > it rusts, so it has to be completely coated; this is one reason it's unlikely that what you saw was steel
    > it is higher resistance than copper; this is no problem if you are aware of it and take the right design measures; all wires are low value resistors
    > it has different structural properties than copper, including faster work hardening and cracking.
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,475
    Received: 340/2
    Given: 126/3
    16
    wouldn't computer PS wire be expected to be aluminum? Its way cheaper than copper and conducts enough for the short runs present in the PS.
    When $0.30 per unit is the difference between profit and loss the beancounters downgrade everything they can get their spreadsheet on.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,482
    Received: 2,539/7
    57
    HAve you soldered much to aluminum lately?
    Supporting Member
    Mar 2018
    Germany
    3,228
    Received: 2,358/1
    Given: 1,337/2
    8
    Quote Originally Posted by tedmich View Post
    Al would pose a major soldering problem.
    Sorry, crossposting.
    Oct 2015
    NEPA
    884
    Received: 223/2
    Given: 159/0
    5
    All those Chinese LED Christmas light strings are steel, they rust. More garbage. I lucked out and got 2 full boxes of teflon wire of assorted gauges. You want a good supply, get one of those free organs in the newspaper or Craigslist.
    Apr 2008
    Sonoma CA
    3,475
    Received: 340/2
    Given: 126/3
    16
    While its true silver colored cheap wire is usually steel, copper clad aluminum (CCA) is quite common, try finding a car amp installation kit or jumper cables that don't have these innocent 3 letter tucked somewhere in the fine print. All of HF's cheap jumper cables are this stuff I believe. The density is way off real copper but the silver core can be hard to see in the tiny gauges used in many rope type cables. A little dilute HCl will show the characteristic H2 evolution from the cut ends when Zn or Al are present (as in US pennies)
    Feb 2010
    12,651
    Received: 2,188/24
    Given: 5,516/11
    24
    Wasn't there a big deal about mixing copper and aluminum wiring in house electrical? How does CCA get around this?
    Jan 2014
    Chicago
    123
    Received: 52/2
    Given: 91/2
    7
    Having done a bit of reading, it seems it's not a problem if there's no electrolyte present. Some uses may require that the cable is sealed sufficiently from contaminants, or in the case of jumper cables, use is intermittent? Or perhaps the clamps are sealed well to the cable.
    Either way, probably not a good idea in long-term fixed applications such as house wiring and I'm buggered if I want it in my house.
    My computer cables here aren't attracted to a magnet at all. I don't think there's copper in it. More likely nickel or zinc or somesuch. I'll play it safe and scrap it.
    Dec 2009
    Canada
    380
    Received: 203/1
    Given: 9/0
    11
    As I remember it the problem with aluminum wire is that it is too soft, will squash under a screw and loosen easily, then arc over and burn your house down, whereas copper has a bit of springyness which helps keep it tight.
  12. #12
    Supporting Member bsco's Avatar
    Jan 2012
    Eastern Canada
    1,798
    Received: 157/0
    Given: 203/0
    10
    Quote Originally Posted by dmeek View Post
    A friend of mine had bought a house years ago......when he had everything approved and had moved in, he discovered that the electrical wiring was aluminum....and it all had to be ripped out and completely re-wired....Aluminum was used for awhile in house wiring but it was discovered that it generated too much heat in the wiring and houses would catch fire.....so it was banned......
  13. #13
    Old Timer olddawg's Avatar
    Dec 2007
    La Jolla CA, Kapaa Kauai
    3,312
    Received: 489/6
    Given: 56/1
    16
    Your ubiquitous “clear” wire speaker has stranded copper and stranded (stainless) steel wire...
  14. #14
    Jan 2012
    Eastern Canada
    1,798
    Received: 157/0
    Given: 203/0
    10
    Quote Originally Posted by olddawg View Post
    I did not know that...and I really never put much thought into the composition of various types of wire to be quite honest........
    Cheers
  15. #15
    33,482
    Received: 2,539/7
    57
    That would surprise me. I'd be quicker to believe the clear speaker zip cord was copper and tinned copper. Why bother with a whole different wire than copper JUST for color contrast? You can also note many if not most zip cord, clear or not, differentiates by feel. One side is smooth, the other side ribbed.
  16. #16
    Sep 2011
    Pace, FL
    3,641
    Received: 1,324/102
    Given: 183/36
    12
    Well that explains why some older stuff the one wire shows green through the insulation.
    nosaj
  17. #17
    Supporting Member
    Dec 2009
    UK
    3,828
    Received: 507/1
    Given: 102/0
    14
    Some of the speaker cable I have has some of the strands silver plated over copper. Van Damme also does this on instrument cables, where a number of the centre conductor cores are plated.
  18. #18
    Supporting Member
    Mar 2018
    Germany
    3,228
    Received: 2,358/1
    Given: 1,337/2
    8
    Especially for speaker wire you wouldn't want steel because the currents are high and low impedance wire is required. Steel would noticeably increase DCR (resulting in power loss and reduced speaker damping) but also inductance and skin effect (resulting in treble loss).
  19. #19
    Dec 2007
    3,312
    Received: 489/6
    Given: 56/1
    16
    Not all clear speaker wire.. but much of it from the last 30 years has one side stranded copper alloy one one side stranded stainless steel. Iíve taken it apart and used strands of it for specific uses. I also was involved in the first field test and comparisons of Monster Cable which I compared with everything from Romex to claymore mine (which is also stranded stainless) cable. There was no measurable differences at audio frequencies at sane lengths. But that didnít stop Monster
  20. #20
    Supporting Member
    Apr 2007
    1,072
    Received: 66/0
    Given: 50/2
    15
    Aluminum house wiring got a bad rap, but it wasn't the wire that was the problem. The connections were copper/brass in the outlets and switches that expanded at a different rate that the aluminum when a load heated the wire. My father in law's house starting having problems with outlets, and lighting, and I found the fixtures were't rated for aluminum. I replaced all with type CO/AL, and for the next 20 years the mother in law lived in it, there were no problems. I also used "Penetrox" on the connections like the linemen do on all the aluminum overhead lines at connections.
    (Being from a county with 2 copper mines, there was no love lost when aluminum house wiring was discontinued, but many electricians felt it was unfairly targeted due to improper installations!)
  21. #21
    Dec 2007
    3,312
    Received: 489/6
    Given: 56/1
    16
    We tested a bunch of it. And like I said, at sane lengths in the audio spectrum there was no measurable difference. I’m sure some “golden ears” audiophile can “hear” the difference. But we couldn’t measure any appreciable difference. I got several large rolls of stainless steel Claymore mine wire from my Seal Team buddy at the time. I gave most of it away to people to use for speaker wire. It didn’t corrode and it didn’t break. Got no complaints.
  22. #22
    Supporting Member
    Mar 2017
    Massachusetts, USA
    1,495
    Received: 168/0
    Given: 2,651/0
    5
    Our house power panel has detailed instructions on aluminum wiring the main service. They have the torque specified and dire warnings if you don't torque correctly. That said, I checked the two big connections coming from the main service to the distribution box, and they are crushed to s**t. I actually want to get a good electrician in to redo those connections and retorque them properly.
    The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
  1. Replies: 4
    Last Post: 11-21-2015, 08:40 PM
  2. Repurposing Multiple (independent) Primaries
    By NateS in forum Theory & Design
    Last Post: 03-12-2014, 06:12 PM
  3. KLDguitar PGA 18H power soak speaker emulation DI connecting with computer
    By kldguitar in forum Plug Your Product/Service
    Last Post: 08-12-2013, 12:29 PM
  4. 1961 Reverberocket - DC power supply wiring question
    By NeilG1203 in forum Repair and Restoration
    Last Post: 05-24-2013, 07:09 PM
  5. Replies: 0
    Last Post: 05-30-2010, 05:33 AM
