Results 1 to 21 of 21
Thread: Tweeter not working with acoustic 405 cab
  1. #1
    New Member
    Join Date
    Feb 2020
    Posts
    6
    Thumbs Up/Down
    Received: 0/0
    Given: 6/0
    Rep Power
    0
    https://imgur.com/a/a1QEXky
    The tweeters on my acoustic 405 stopped working, this is the crossover. Any advice on troubleshooting what part is broken and what good replacements would be? Any advice would be appreciated, thanks.
    0 Not allowed! Not allowed!
  2. #2
    Supporting Member The Dude's Avatar
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,717
    Thumbs Up/Down
    Received: 1,515/1
    Given: 1,122/1
    Rep Power
    17
    The most likely suspect is dirty switch contacts on the high level selector switch. I'd first check continuity on the switch from the input to each output. Try cleaning the switch with some contact cleaner. It could also be open drivers- again check with meter. Then, on to crossover caps- they could have dried out. if everything else checks good either check or replace caps. Resistors could be open, but it's unlikely.
    2 Not allowed! Not allowed!
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  3. #3
    New Member
    Join Date
    Feb 2020
    Posts
    6
    Thumbs Up/Down
    Received: 0/0
    Given: 6/0
    Rep Power
    0
    Thanks for the response! i was able to pinpoint it to one of the capacitors being dead. Im going to swap them both. Is this fine https://www.taydaelectronics.com/10u...or-6x11mm.html or should i go for an exact replacement https://www.alliedelec.com/product/v...407/70079235/?
  4. #4
    Supporting Member TomCarlos's Avatar
    Join Date
    Oct 2009
    Location
    Roseville, Ca.
    Posts
    894
    Thumbs Up/Down
    Received: 181/0
    Given: 309/0
    Rep Power
    11
    It is recommended to get "Non-Polarized" capacitors. Look at the ones you have. Do you see a Plus or Minus symbol? If not, that is a good sign it is a Non-Polar cap. Did you confirm that your caps 10 microfarad? And the voltage rating?
  5. #5
    New Member
    Join Date
    Feb 2020
    Posts
    6
    Thumbs Up/Down
    Received: 0/0
    Given: 6/0
    Rep Power
    0
    It has a positve sign and although i cant find an exact model later models with the marking "1407" are 100v. Im going to go for https://www.alliedelec.com/product/v...1407/70079235/ as they are the closest ive found.
  6. #6
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,717
    Thumbs Up/Down
    Received: 1,515/1
    Given: 1,122/1
    Rep Power
    17
    I agree with Tom. You should use a bipolar cap in crossover applications. Here are some, but I'm sure there are plenty of other places that have them. They are not Axial, but that doesn't matter.
    https://www.digikey.com/product-deta...141-ND/2539603
    Edit: Also, your link says you need to order a minimum quantity of 510. It could get quite expensive.
  7. #7
    New Member
    Join Date
    Feb 2020
    Posts
    6
    Thumbs Up/Down
    Received: 0/0
    Given: 6/0
    Rep Power
    0
    Ok great good to know, so as long as they are 100v and 10uf ill be good?
    Edit: ill probably just get them off tayda or ebay
  8. #8
    Join Date
    Oct 2009
    Location
    Roseville, Ca.
    Posts
    894
    Thumbs Up/Down
    Received: 181/0
    Given: 309/0
    Rep Power
    11
    There are two things you need to consider. One is the "value" of the cap. So if it shows 10uf, that means it is a 10 microfarad. You want that value. The second is the voltage rating. So if it says 100v, that is the minimum you want.
    Parts Express - 10uF 100V Electrolytic Non-Polarized Crossover Capacitor
    These caps should not be expensive. While you are at it, replace them both.
  9. #9
    Join Date
    Dec 2009
    Location
    Canada
    Posts
    342
    Thumbs Up/Down
    Received: 180/0
    Given: 6/0
    Rep Power
    11
    Here it is in schematic form. I'm not sure we know the value of the caps yet. Whatever they are, the bipolar cap should be half the value marked on one of the originals Or just use 2 caps back-to-back like it is now.
    https://music-electronics-forum.com/...1&d=1580830072
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  10. #10
    Join Date
    Oct 2009
    Location
    Roseville, Ca.
    Posts
    894
    Thumbs Up/Down
    Received: 181/0
    Given: 309/0
    Rep Power
    11
    Interesting configuration... I guess Acoustic got a great deal on caps so they used two +- -+ to create a non-polar cap?
  11. #11
    Join Date
    Dec 2009
    Location
    Canada
    Posts
    342
    Thumbs Up/Down
    Received: 180/0
    Given: 6/0
    Rep Power
    11
    Maybe Bipolars were more expensive. The thing to remember is that two caps in series of equal value will become half the value of one. The voltage rating will be unchanged.
    Somehow there must be a better way to express this but I can't think of it right now. C + C in series = 1/2 C ?
  12. #12
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,976
    Thumbs Up/Down
    Received: 2,189/1
    Given: 1,250/2
    Rep Power
    7
    Impedances add in series wiring. The impedance of a cap is proportional to 1/C. So 1/Cseries = 1/C + 1/C = 2/C or Cseries = C/2.
  13. #13
    Join Date
    Dec 2009
    Location
    Canada
    Posts
    342
    Thumbs Up/Down
    Received: 180/0
    Given: 6/0
    Rep Power
    11
    Yes, that's a more accurate way to put it. My equation only applies when both capacitors are the same value as they are in this case.
    1 Not allowed! Not allowed!
  14. #14
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,976
    Thumbs Up/Down
    Received: 2,189/1
    Given: 1,250/2
    Rep Power
    7
    So does mine .
    With 2 different caps the formula is slightly more complicated. But the principle is the same:
    1/Cser = 1/C1 +1/C2 = (C1 +C2)/ C1*C2 and Cser = C1*C2/( C1 +C2).
  15. #15
    Old Timer Leo_Gnardo's Avatar
    Join Date
    Sep 2012
    Location
    Dogpatch-on-Hudson
    Posts
    6,686
    Thumbs Up/Down
    Received: 1,653/21
    Given: 1,367/0
    Rep Power
    14
    Quote Originally Posted by dmeek View Post
    Even though "theoretically" one can create a non polar cap by running two electrolytics in series, "back to back," I find it a cheap and nasty solution. You can get hi quality film caps rated 250V - a rating which would never fail in any reasonable circumstance - from Parts Express, for coffee break money. I've found their house brand "Dayton" to be perfectly functional. Why not skip the potential hazards of using electrolytics in this application. Install reliability instead.
    Disclaimer: I have no business interest in Parts Express. Just a very satisfied user of their Dayton film caps.
    4 Not allowed! Not allowed!
    Enjoy. Every. Sandwich.
  16. #16
    Old Timer olddawg's Avatar
    Join Date
    Dec 2007
    Location
    La Jolla CA, Hanalei, Kauai
    Posts
    3,164
    Thumbs Up/Down
    Received: 395/2
    Given: 45/1
    Rep Power
    16
    Quote Originally Posted by Leo_Gnardo View Post
    I’ve had very good experiences using Express Parts. I’ve gotten great deals on big L Pads, horn drivers, knockoff speakers (mostly for stereo or PA use), and usually pick up crossover caps, etc at the same time. Very fast processing and shipping too.
  17. #17
    New Member
    Join Date
    Feb 2020
    Posts
    6
    Thumbs Up/Down
    Received: 0/0
    Given: 6/0
    Rep Power
    0
    I couldn't find any 5uf caps, should i get two of these https://www.parts-express.com/dayton...itor--027-428?
  18. #18
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,976
    Thumbs Up/Down
    Received: 2,189/1
    Given: 1,250/2
    Rep Power
    7
    Quote Originally Posted by andvgeo42 View Post
    You can use 5.1µF or 4.7µF.
  19. #19
    New Member
    Join Date
    Feb 2020
    Posts
    6
    Thumbs Up/Down
    Received: 0/0
    Given: 6/0
    Rep Power
    0
    Thanks, ill end up getting one of these https://www.parts-express.com/dayton...citor--027-423
    I appreciate all the responses!
  20. #20
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,717
    Thumbs Up/Down
    Received: 1,515/1
    Given: 1,122/1
    Rep Power
    17
    I'm with Leo on using a film cap. Here's a good example. And, as mentioned and since the caps are in series, just use one to replace both.
    https://www.digikey.com/product-deta...F2475-ND/56516
    Edit: I was typing while you replied. The one you linked is good, too.
  21. #21
    Join Date
    Sep 2012
    Location
    Dogpatch-on-Hudson
    Posts
    6,686
    Thumbs Up/Down
    Received: 1,653/21
    Given: 1,367/0
    Rep Power
    14
    What Helmholtz said ^^^. Also keep in mind, these are thumb-size caps, not rinky-dink miniatures. They will need some sort of support when mounting them. A large cable clamp or a big glob of RTV,, epoxy, or similar adhesive will do.
Thread Information
Users Browsing this Thread
  1. JBL 2418H tweeter repair
    By dmeek in forum Music Electronics
    Last Post: 05-16-2019, 06:47 PM
  2. Acoustic B410 mkII tweeter
    By Randall in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-23-2016, 07:12 AM
  3. Acoustic Model 115 - Reverb Not Working
    By Gahoo in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-30-2015, 10:43 PM
  4. Replies: 0
    Last Post: 12-23-2008, 03:38 AM
  5. Piezo Tweeter - Rumble 100
    By lowell in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-09-2008, 03:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
