Hi,i'm new in the forum. Just got an old marshall lead 100 ( jmp 2098) than was in an horrible condition. It got al the electrolytic capacitors damaged, 2 output transistors blown up, output transformer disconnected and almost every transistor in the pcb was damaged. I managed to change everything that was damaged (that was almost everything), but the amp doesn't sound well. I get a distorted sound in the output and it doesn't let me adjust the bias current. Every information that can be given to me will be appreciated thanks
Marshall 2098 lead 100 repair
When you plug guitar into Return jack, do you get clean or distorted sound?
Bias current is measured by connecting DC mA meter (range 200 mA) in series with emitter resisistor 0.33.
Bias current adjust with 1k in BC184 circuit.
If bias current doesn't adjust check transistor BC184 and passive components in BC184 circuit.
https://drtube.com/schematics/marshall/2200-pwr.gif
https://drtube.com/schematics/marshall/2200-pre.gifIt's All Over Now
Are the the rail voltages correct?
You can more easily measure bias by measuring the voltage across the emitter resistor and use Ohm's law to give you the current V/R=I
Just a note that the output autotransformer has to be connected to a speaker load in these amps, otherwise a large flyback voltage is produced causing extensive damage. SS amps are usually fine with no load, but not this model. As well as the output transistors, did you check the power amp diodes?
Or is it rather an instability of this amp causing oscillation with an inductive load?- Own Opinions Only -
Originally posted by Mick Bailey View PostYou can more easily measure bias by measuring the voltage across the emitter resistor and use Ohm's law to give you the current V/R=I
Just a note that the output autotransformer ... ...
Ohm's law says it is 3.3 mV. With analog Vmeter can hard to measure, but DVM has walking on display +/- 1 digit.
Autotransformer enables that amplifier has approx same power regardless of speaker load impedance.
If you suspect on flyback voltage, repair can also be done without autotransformer.It's All Over Now
Originally posted by Luisflores View Postthe amp doesn't sound well. I get a distorted sound in the output and it doesn't let me adjust the bias current.
Why did we break into the collector lead of the MJ2501 instead of just checking voltage across one of the 0.33 ohm resistors?
Look at the DC base voltages of the MJ2501 and MJ3001. Are they the same? As in they seem shorted together? And in fact I am concerned the BC184 bias transistor might be. If it is shorted, you get maximum crossover distortion.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Helmholtz View PostBeing curious, under what circumstances did you see the large flyback voltage as this would require a sudden decrease/disruption of inductor current?
Originally posted by Mick Bailey View PostI think it's perhaps instability, but I just looked back through my notes and saw that the 220n cap in the output network can go open and the inductor solder joints crack so maybe the circuit is OK if everything else is good.- Own Opinions Only -
