Results 1 to 25 of 25
Thread: Mesa Boogie Studio 22 Phase Inverter
    Aug 2016
    Sydney, Australia
    229
    Received: 40/0
    Given: 111/0
    4
    Greetings from the recently burning, now flooding Australia. At least the fires have stopped.
    22_cal.pdf
    I have a Boogie Studio 22 (non EQ). This may eventually escalate to the Troubleshooting forum, but I haven't given up on the repair yet. This is more in the "What the hell was Randall Smith possibly thinking" category. My initial thought is that it was some cheap-skate LTP, but no. I have been staring at the PI, drawing equivalent circuits, calculating currents and I am pretty sure its a Paraphase PI. And if I'm right, its way way wackier design than an old Fender Paraphase.
    The inverting triode is normal, but the input for the non-inverting (the lower triode in the schematic) is coming from the feedback loop. That sounds like a bizarre version of the "Einstein Chicken and Egg conundrum" to me. How can you feedback what has not yet been created, so as to create it by running it through a triode, then the output tubes, then the primary, then secondary stage of the O/P transformer and then feed a portion of it back to the non-inverting triode of the PI so you can see what you have just fed back? Surely the signal coming into the non-inverting triode would bear little resemblance to what's coming out f the inverting triode.
    I thought in any PI you ideally wanted the 2 phases to be identical but 180 deg out of phase. In this design the 2 phases will be 5th cousins...at best. Then there's a presence control draining some of that high frequency signal to ground. I just don't get it.
    Have I totally misunderstood the design? Opinions and mockery welcomed. (Enzo: This is where you would insert a comment about the phases actually being 180deg the other way to what I've stated because I'm from the Land Down Under! )
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,983
    Received: 2,274/7
    55
    Hey, don't stomp on my joke, it's all I have...
    Everything must be in context. Yes the one side takes its signal "later" than the other. But remember, electricity moves at the speed of light. (Please no arguments about electrons moving) And that can go all the way around the earth seven and a half times in a second. That means the delay for the lower side signal from the first is on the order of a billionth of a second. And at audio, that is about as close to exactly the same time as it gets. So your signal has to go through the inverting triode, then from that plate, it must go through the power tubes, the transformer and the NFB to get to the other triode. 15-20cm maybe?
    US NAval Admiral Grace Hopper is famous for her nanoseconds. She used to demonstrate nanoseconds to her classes. She handed out a bunch of 30cm pieces of wire, one for each student. "Here are your nanoseconds." She went on "this is how far electricity goes in a nanosecond. One billionth of a second.
    Hopper worked in the world of computing, and in that world, that nanosecond was a limiting factor in computer speed. If the memory was two feet away from the CPU, that computer would be slower than one with the memory only 6 inches from the CPU.
    Grace Hopper was an interesting old bird, and sharp as a tack. I wish she was still with us, she could give a much livelier explanation of all this than I could.
    https://en.wikipedia.org/wiki/Grace_Hopper
    We work in the world of guitar amps, and a nanosecond? Well, not so much of an issue.
    1 Not allowed! Not allowed!
    Nov 2013
    336
    Received: 130/11
    Given: 44/0
    7
    the first triode passes on the signal to the second one through the cathode connection,which comes out in phase to the plate,that's your inversion of the first triode,then you have the feedback insert in the grid,only difference from the fender is that it doesn't pass also through the tail resistor.
    i don't know what's your problem,i guess you don't have a scope...
    Cheshire, UK
    2,307
    Received: 614/4
    Given: 314/0
    16
    It's looks like a LTP to me but with a negative supply to the tail and grids referenced to ground. The negative feedback isn't bootstrapped to the tail which makes the outputs unbalanced. They have compensated for this by having different value plate resistors.
    5 Not allowed! Not allowed!
    Supporting Member
    Mar 2018
    Germany
    2,976
    Received: 2,189/1
    Given: 1,250/2
    7
    Yes, it's definitely a differential amplifier (LTPI). Note coupled cathodes.
    With a scope you should be able to see equal but out-of phase signals at both plates - even if you disconnect the NFB.
    2 Not allowed! Not allowed!
    - Own Opinions Only -
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    16,088
    Received: 2,881/4
    Given: 3,378/0
    31
    FWIW this was a popular PI for Mesa. They actually use it in a lot of amp models designed over a span of more than a decade. So it must be working for them and their customers. In my experience it works very well. In fact, with the dozens of changes I made to a couple of Mesa amps with this inverter, the inverter was one thing I didn't change.
    Feb 2010
    12,380
    Received: 2,032/24
    Given: 5,182/11
    24
    The question reminds me of that EL34 100/100 Marshall power amp we were discussing the other day. I had the same 'chicken/egg conundrum' reaction.
    V2a grid gets signal only from OT secondary tap.
    Attached Files Attached Files
    Supporting Member
    Mar 2018
    Germany
    2,976
    Received: 2,189/1
    Given: 1,250/2
    7
    But that's typical for the non-inverting triode in a LTPI. However the tube has 2 inputs, cathode (non-inverting) and grid (inverting).
    Feb 2010
    12,380
    Received: 2,032/24
    Given: 5,182/11
    24
    Yes, this is the case for both the Mesa and the Marshall, correct? My big problem is that Marshall, in their usual modern schematic 'brilliance' has decided to go against all schematic and even normal reading convention; signal flow is from right to left instead of the well established norm (left to right).
    Their modern 'service hostile' schematics always make me wish they would go broke.
    Anyway, I guess my point is that for both myself and the OP, the difficulty is probably more due to the non-conventional drawing style, rather than the concepts. Ironically, both companies were established based on Fender designs, which they always seem so keen to avoid acknowledging in their drawings.
    32,983
    Received: 2,274/7
    55
    Fair is fair, Fender got their designs a lot straight from RCA.
    Seems to me Mesa drew schematics going the wrong way too.
    MArshall draws what I call (perhaps incorrectly) engineering drawings. They seem to draw a schematic for just a board. So we wind up with things like orphaned volume controls or tubes lacking loads...or whatever. I had a long conversation with an engineer at PV once about this. I was asking if there existed system circuit drawings for certain products, like the 5150. The 5150 is one of those disjointed things, but somewhere SOMEONE must have had a drawing of the whole circuit to put the existing stuff together. It took me a long while to get him to understand my point. He was telling me they reuse snippets of circuits and all that. I finally told him to look at page 2 of the 5150 file. Upper left is a single triode cathode follower with the signal NEXT4 coming in and NEXT% leaving. I finally got across that I believe they will reuse that circuit, but I doubt the 5150 team started out with "I think I will stick a CF stage somewhere." We left with him sat least understanding my beef. We both agreed it might not change.
    But then the 5150-2 came along et voila the schematic was entire...except for the power tube board.
    Aug 2016
    Sydney, Australia
    229
    Received: 40/0
    Given: 111/0
    4
    Hey, don't stomp on my joke, it's all I have....
    NO!! It's never boring when you say it, Enzo.
    And yes, I may have got a bit wound up in the time delay....
  12. #12
    Aug 2016
    Sydney, Australia
    229
    Received: 40/0
    Given: 111/0
    4
    Quote Originally Posted by alexradium View Post
    My first thought was a LTP, and then I went into the rabbit hole. On a LTPI, I would expect to see a much higher voltage than 2V at the common cathode junction. I have a scope, and I confess to not using it to see what's on the cathodes. If we add the -16v to the 15K "tail resistor" R112, it still only is 18V compared to the grid. I should really find a way of disconnecting the NFB loop and see if the non-inverting lower triode still functions.
  13. #13
    Aug 2016
    Sydney, Australia
    229
    Received: 40/0
    Given: 111/0
    4
    I know Randall would prefer us to buy Mesa valves than biasing his amps.
    Why is there a whacking big 2.2M resistor (R202 and R201) to ground at the grids of the EL84s? Is it to suppress any oscillations? Those 2M2's set up a huge potential divider with micro-amps. Any idea on how to effect a bias change? The 33K R111 would be ineffectual compared to the 2M2 for a global bias change, and it may upset the PI cathode +2vDC level. Have you ever rebiased one of these PI & Bias configurations, Chuck? Is there a better way?
  14. #14
    Aug 2016
    Sydney, Australia
    229
    Received: 40/0
    Given: 111/0
    4
    You gotta love consistency, G1. For this Studio amp, Mesa go right to left on the preamp schematic, and then go Left to Right for the PI and power stage.
  15. #15
    Aug 2016
    Sydney, Australia
    229
    Received: 40/0
    Given: 111/0
    4
    Thank you, Helmholtz. Yes those coupled cathode originally made me think LTPI, but the +2v stumped me. Seeing the grids referenced to earth instead of the bias/tail resistor then set me onto my Paraphase theory. I will disconnect the NFB. It may help get it through my skull.
  16. #16
    Cheshire, UK
    2,307
    Received: 614/4
    Given: 314/0
    16
    Quote Originally Posted by christarak View Post
    The 2M2 and 330k are a potential divider to reduce the EL84 bias voltage to -11.6V. I don;t know why they didn't just split the 330k. They could have saved two whole resistors that way. I'd adjust the value of the 220k resistors to change the bias. R112 (15k) sets the tail current. The +2V at the cathodes is the bias voltage needed by the tubes to pass that current i.e. -2V at the grids wrt the cathodes.
  17. #17
    May 2007
    pacific north west
    16,088
    Received: 2,881/4
    Given: 3,378/0
    31
    As far as I know the "whacking big" 2.2M resistors (high impedance for this circuit) and the reference to a relatively high impedance -V supply via a relatively high 550k (220k grid stop series with 330k bias feed/grid load resistor) where the 2.2M is basically parallel to the 550k for a grid load, but again through relatively high impedance paths,... Is part of Mesa's "Dynawatt" system.
    As I recall I did away with 2.2M resistors. I just snipped them out. I replaced the 220k grid resistors with 10k value and that was that. At 400+Vp the amp was better off with the additional bias volts anyway and in fact sounded better for the change. There's probably undocumented circuits or errors in the Mesa schematic, but this isn't uncommon.
  18. #18
    Aug 2016
    Sydney, Australia
    229
    Received: 40/0
    Given: 111/0
    4
    Thank you Chuck. I will definitely try what you suggested. It sounds way more practical. I might keep an eye out for oscillations with the 'scope and supply the power through the bulb limiter while experimenting...just in case.
  19. #19
    Aug 2016
    Sydney, Australia
    229
    Received: 40/0
    Given: 111/0
    4
    Thanks Dave. I think my "Plan E" was to change that 2M2 to adjust the bias, but I couldn't see the practicality in playing with such high impedances. I will try Chucks theory of removing the 2M2.s. If I end up with 50MHz oscillations I'll come running back!! Thanks mate.
  20. #20
    Aug 2016
    Sydney, Australia
    229
    Received: 40/0
    Given: 111/0
    4
    Can I please thank you all for your knowledge and insights into this annoyingly, unneccarily different Mesa Boogie design of PI and power valve biasing? You have expanded my knowledge and I now have a couple of great suggestions on how to bias the unbiasable. Thank you.
  21. #21
    Supporting Member
    Mar 2018
    Germany
    2,976
    Received: 2,189/1
    Given: 1,250/2
    7
    There seems to be a misconception. While a grid (series) stopper resistor (1k to 10k is sufficient) can avoid oscillation, a large grid (shunt) resistor does not.
  22. #22
    Aug 2016
    Sydney, Australia
    229
    Received: 40/0
    Given: 111/0
    4
    Thanks Helmholtz. Yes, I would normally insert a Leo-approved 1K5 series resistor for oscillation suppression, but I can't see any reason for such a large value resistor. Chuck H said he has even removed the 2M2's in the past. If it is to act as a potential divider, then I expect that any changes made to earlier resistors would be ineffective for bias changes.
  23. #23
    Supporting Member
    Mar 2018
    Germany
    2,976
    Received: 2,189/1
    Given: 1,250/2
    7
    Well, the mod suggested by Chuck results in 10k grid stoppers - and the original circuit effectively has 220k grid stoppers.
  24. #24
    May 2007
    pacific north west
    16,088
    Received: 2,881/4
    Given: 3,378/0
    31
    el84's seem to behave better with larger grid stops. Notice the value chosen by Vox! I can't speak to the technical reasons, but I think it's because of their higher gain. I chose 10k arbitrarily on this premise and the amp sounded great so I had no reason to try anything different.
  25. #25
    Aug 2016
    Sydney, Australia
    229
    Received: 40/0
    Given: 111/0
    4
    17 February 2020: Another new bit of knowledge learned. Thank you, Mr H.
  1. Mesa Boogie F30 - Phase Inverter drawing voltages down
    By stereomonostereo in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-14-2019, 06:46 PM
  2. Mesa Boogie High Phase Inverter Plate Voltage and Blocking Distortion
    By Fred2202 in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-11-2015, 06:38 PM
  3. Phase inverter, Mesa Boogie SOB
    By Enrico in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-02-2013, 06:26 PM
  4. Help debugging my mesa boogie studio preamp
    By Digamma in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-11-2011, 06:10 AM
  5. What output transformer for Mesa Boogie Studio .22 +
    By signalpaths in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-02-2008, 10:48 PM
