Results 1 to 29 of 29
Thread: Odd Shure mic connector
  1. #1
    Supporting Member Randall's Avatar
    Join Date
    Jan 2013
    Location
    Cape Coral, FL
    Posts
    2,569
    Thumbs Up/Down
    Received: 607/0
    Given: 109/0
    Rep Power
    10
    I'm trying to wire up this four pin XLR to a mic cable for an EV model 664 mic. Problem is, I can't seem to get the rubber sheath off. It doesn't want to slide off, and if I peel it back it appears to go inside two slots in the metal. Does anyone have any insight into this connector and how to use it? I have never seen one like it, and I don't want to damage it.
ID:	57048Click image for larger version.
    0 Not allowed! Not allowed!
  2. #2
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    32,986
    Thumbs Up/Down
    Received: 2,274/7
    Given: 0/0
    Rep Power
    55
    It is a four pin, but not an XLR, but that doesn't help you.
    I might heat the sheath with a heat gun, staying back far enough not to melt it. I might wedge small screwdrivers under the edge or even hardwood toothpicks, to lift the edge over the grooves.
    Unless it is molded to the cord.
  3. #3
    Supporting Member The Dude's Avatar
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,717
    Thumbs Up/Down
    Received: 1,517/1
    Given: 1,123/1
    Rep Power
    17
    Is there a set screw on the side of the connector that allows the pin part to come out like the connector in a microphone? Maybe the rubber sleeve part stays put? It's a Shure connector and most all of their male XLR's have the same plastic/pin thingy with the set screw on the side.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  4. #4
    Join Date
    Feb 2010
    Location
    Posts
    12,380
    Thumbs Up/Down
    Received: 2,032/24
    Given: 5,182/11
    Rep Power
    24
    Is the rubber stopping the threaded ring from you pushing it down? Agree with The Dude that there is probably a set screw under that ring. I think if you can push the rubber back a bit so the ring moves down, you may see a set screw.
  5. #5
    Join Date
    Jan 2013
    Location
    Cape Coral, FL
    Posts
    2,569
    Thumbs Up/Down
    Received: 607/0
    Given: 109/0
    Rep Power
    10
    "Maybe the rubber sleeve part stays put?"
    I'm starting to believe that. Where you'd expect to find a set screw there is an indentation that looks like it was stamped in, causing it to bulge out on the inside over the top of the 4 pin plug, holding it in place. Is it possible this connector was never meant to come apart?
  6. #6
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,717
    Thumbs Up/Down
    Received: 1,517/1
    Given: 1,123/1
    Rep Power
    17
    It might be under that threaded collar. Is there a way to thread it off or forward enough to look under it?
    This is a typical Shure XLR male connector showing where the set screw would be if there was one.
    Edit: FWIW, if you do find a hole with the set screw, they are reverse threaded.
    1 Not allowed! Not allowed!
  7. #7
    Join Date
    Jan 2013
    Location
    Cape Coral, FL
    Posts
    2,569
    Thumbs Up/Down
    Received: 607/0
    Given: 109/0
    Rep Power
    10
    Here it is with the rubber forced back and the ring out of the way. I have made hundreds of XLR cables in my time, there is no set screw on this one.
  8. #8
    Join Date
    Dec 2009
    Location
    Canada
    Posts
    342
    Thumbs Up/Down
    Received: 180/0
    Given: 6/0
    Rep Power
    11
    I haven't seen one like that but would the plastic part unscrew like the all-metal ones?
    https://music-electronics-forum.com/...1&d=1582249522
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  9. #9
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,717
    Thumbs Up/Down
    Received: 1,517/1
    Given: 1,123/1
    Rep Power
    17
    Well, it was worth a shot. I haven't seen one without a set screw.
  10. #10
    Join Date
    Jan 2013
    Location
    Cape Coral, FL
    Posts
    2,569
    Thumbs Up/Down
    Received: 607/0
    Given: 109/0
    Rep Power
    10
    I don't think it does unscrew. I will correct myself as Enzo said, it is not XLR, but an Amphenol MC4M. I think I'm getter warmer here, I found this:
    https://www.adorama.com/shc11c.html
    It looks right. I wonder if this a Shure branded connector in name only since it is a Shure cable, not meant to be serviced?
  11. #11
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,717
    Thumbs Up/Down
    Received: 1,517/1
    Given: 1,123/1
    Rep Power
    17
    Very possible. If no set screw, I'd try to carefully remove the rubber, maybe with some heat like Enzo suggested. If you destroy it, you could maybe make something out of heat shrink and left over parts.
  12. #12
    Join Date
    Jan 2013
    Location
    Cape Coral, FL
    Posts
    2,569
    Thumbs Up/Down
    Received: 607/0
    Given: 109/0
    Rep Power
    10
    Yeah, but even if I do get the rubber off, it sure doesn't look like those four pins are ever coming out of the shell, since it looks to me to be stamped shut. I think this is a lost cause.
  13. #13
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,717
    Thumbs Up/Down
    Received: 1,517/1
    Given: 1,123/1
    Rep Power
    17
  14. #14
    Join Date
    Jan 2013
    Location
    Cape Coral, FL
    Posts
    2,569
    Thumbs Up/Down
    Received: 607/0
    Given: 109/0
    Rep Power
    10
    Exactly. Customer apparently got bilked on this one, thinking he was avoiding the cost of the alternative.
  15. #15
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,717
    Thumbs Up/Down
    Received: 1,517/1
    Given: 1,123/1
    Rep Power
    17
    At least the one I linked comes apart for repairs. Let me guess- a $30 connector for a $20 mic?
  16. #16
    Join Date
    Jan 2013
    Location
    Cape Coral, FL
    Posts
    2,569
    Thumbs Up/Down
    Received: 607/0
    Given: 109/0
    Rep Power
    10
    It appears it was clipped from a handheld police/fire/cab mic with an on switch. This manual shows in spare parts as "cable and plug assembly", which is still being sold. It was never meant to come apart.
    http://www.radiomanual.info/schemi/A..._418A_user.pdf
  17. #17
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,717
    Thumbs Up/Down
    Received: 1,517/1
    Given: 1,123/1
    Rep Power
    17
    What is the intended use? Could you just use a standard 3 pin XLR? Is it possible to change the connector in the microphone?
  18. #18
    Old Timer Leo_Gnardo's Avatar
    Join Date
    Sep 2012
    Location
    Dogpatch-on-Hudson
    Posts
    6,688
    Thumbs Up/Down
    Received: 1,654/21
    Given: 1,369/0
    Rep Power
    14
    Quote Originally Posted by The Dude View Post
    I see the same connector is spec'd for Shure 545D. Good thing mine is still working! The ol' pistol-grip hi school stage mic has been my fave snare mic for decades - I stuck it back together numerous times, the most recent just a couple weeks ago. The mic looks like Frankenstein with all its patches. But that connector - still rockin' !
    There's something nice about the EV 664/5/6 series too, an old fashioned "warm" tone worth having in any mic collection. Heck if it took a $30 connector to make it work, I wouldn't think twice, just do it.
    Enjoy. Every. Sandwich.
  19. #19
    Join Date
    Jan 2013
    Location
    Cape Coral, FL
    Posts
    2,569
    Thumbs Up/Down
    Received: 607/0
    Given: 109/0
    Rep Power
    10
    "What is the intended use? Could you just use a standard 3 pin XLR? Is it possible to change the connector in the microphone? "
    It is intended to be used in a recording studio, and probably a music video or two. It might be possible to change out the mic to XLR, but I doubt that would be easy. PLus, I never want to change a vintage mic in nice shape. Leave it alone and make a cable for it.
    2 Not allowed! Not allowed!
  20. #20
    Supporting Member Jazz P Bass's Avatar
    Join Date
    Dec 2008
    Location
    Wernersville, PA
    Posts
    13,074
    Thumbs Up/Down
    Received: 609/3
    Given: 314/0
    Rep Power
    28
    You may be correct that 'they were not made to come apart'
    I think the wires where soldered into the pins (like a Fender reverb/ footswitch connector) and then the shell was crimped to lock it.
    The only replacement wire with plug that I could find was a coiled wire type.
    Shure C14C.
  21. #21
    Supporting Member nevetslab's Avatar
    Join Date
    Apr 2010
    Location
    Burbank, CA
    Posts
    1,993
    Thumbs Up/Down
    Received: 733/1
    Given: 1,734/1
    Rep Power
    11
    Switchcraft L(x)MN Retrofit Connector for replacing Amphenol MC4F mic output connector
    Quote Originally Posted by Randall View Post
    It's been a few years since I've bought the Switchcraft L3MN Male XLR connectors, but these were made to directly retrofit into any of the microphones that used these Amphenol MC4F connectors, which accepted the 4-pin male mating connector, which had horrible stain reliefs, always requiring repairs. I had changed all my Shure 545 mics that used them with the L3MN, so it turned the mic into a standard XLR Male output as we're used to working with. I've attached the data sheet.
    Switchcraft L3MN Replacement 91-MC4F.pdf
    These came equipped with the knurled locking ring as used with the original mating Amphenol cable connector.
    3 Not allowed! Not allowed!
  22. #22
    Join Date
    Sep 2012
    Location
    Dogpatch-on-Hudson
    Posts
    6,688
    Thumbs Up/Down
    Received: 1,654/21
    Given: 1,369/0
    Rep Power
    14
    Quote Originally Posted by nevetslab View Post
    Leave it to you to come up with the miracle solution Nevets! I'm impressed !!!
  23. #23
    Join Date
    Apr 2010
    Location
    Burbank, CA
    Posts
    1,993
    Thumbs Up/Down
    Received: 733/1
    Given: 1,734/1
    Rep Power
    11
    Quote Originally Posted by Leo_Gnardo View Post
    Now, the hard part is finding who still has them available for sale. I seem to recall that was an issue when I had tracked down the four pieces I bought. I don't think you can find them at Switchcraft anymore. I just checked, and I have just these two left, having installed the other two on an EV 644 and an EV 676 mic.
Name:	Switchcraft L3MN Connector-1.jpg
ID:	57059 Click image for larger version.
Name:	Switchcraft L3MN Connector-2.jpg
ID:	57060 Click image for larger version.
ID:	57063 Click image for larger version.
Name:	Output Conn-1.jpg
ID:	57065 Click image for larger version.
  24. #24
    Join Date
    Jan 2013
    Location
    Cape Coral, FL
    Posts
    2,569
    Thumbs Up/Down
    Received: 607/0
    Given: 109/0
    Rep Power
    10
    I just had an exchange with an engineer at Shure, sent him pics. He said they have not used that connector for about 40 years, and they have no info on how it might come apart. I am at peace with the belief that it does not.
  25. #25
    Supporting Member mozz's Avatar
    Join Date
    Oct 2015
    Location
    NEPA
    Posts
    867
    Thumbs Up/Down
    Received: 213/2
    Given: 149/0
    Rep Power
    5
    These guys would know for sure. Post a wanted to the classified.
    https://antiqueradios.com/forums/vie...2716e7cc1bb7af
  26. #26
    Master Destroyer nosaj's Avatar
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,433
    Thumbs Up/Down
    Received: 1,225/102
    Given: 172/36
    Rep Power
    12
    Quote Originally Posted by mozz View Post
    Looks an awful lot like a 4 pin CB connector to me. Any chance you have an old cb radio you could test the mating pattern with?
    nosaj
    Binkie McFartnuggets‏:If we really wanted to know the meaning of life we would have fed Stephen Hawking shrooms a long time ago.
  27. #27
    Join Date
    May 2006
    Location
    Posts
    32,986
    Thumbs Up/Down
    Received: 2,274/7
    Given: 0/0
    Rep Power
    55
    I think the CB connector is about 30% smaller.
    Suggest: CALL Rapco/Horizon, and ASK them if they still have the four pin screw-on connector for old EV mics like your 664. If so they might sell you connectors or they would make up a cable. I used to sell their cables, and at first I bought connectors and made cables, but they charge the same for materials or made up cables. And any special ones, like RCA to XLR or something were no extra charge, though it might take an extra day or two.
    https://www.rapcohorizon.com/topic/support
  28. #28
    Join Date
    May 2006
    Location
    Posts
    32,986
    Thumbs Up/Down
    Received: 2,274/7
    Given: 0/0
    Rep Power
    55
    And for that matter, SHure made your cable, but your mic is an EV, I think I might call EV and ask after connectors.
  29. #29
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,717
    Thumbs Up/Down
    Received: 1,517/1
    Given: 1,123/1
    Rep Power
    17
    Good stuff Nevets! IMO, that doesn't effect the "vintageness" at all. I don't see it as effecting value any more than clipping out a death cap and adding a grounded cable to an amp.
Thread Information
Users Browsing this Thread
  1. Shure Beta 58a
    By m1989jmp in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-15-2018, 11:01 AM
  2. Shure SM 81
    By bramley in forum Schematic Requests
    Last Post: 10-06-2017, 06:52 PM
  3. Mod/repair vintage Shure mic?
    By Justin Thomas in forum Music Electronics
    Last Post: 02-11-2013, 09:52 PM
  4. shure in-ears
    By lowell in forum Music Electronics
    Last Post: 12-28-2012, 08:42 PM
  5. SHURE LEVEL LOC diy build
    By methodofcontrol in forum Music Electronics
    Last Post: 01-26-2007, 05:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
