Originally posted by mikepukmel
View Post
Mod to prevent cathode follower arcing on startup
the cathode follower has a tendency to arc.
I think arcing at a "lowish" voltage of 450V or so would mean poor vacuum. Which tube brands are concerned?
I re-read Nick's thread on DCCF failures and found no indication of arcing between any electrodes. (Hope Nick will chime in).- Own Opinions Only -
