Nope!
Originally posted by SoulFetish View PostDear GAWD, what have they done??This isn't the future I signed up for.
Is this too close or sensitive an issue to get a back story? How did this happen? Who did it?
EDIT: And... Not saying it's wrong, but do you always clamp your AC cords in a vice!?!
Last edited by Chuck H; 03-06-2020, 02:18 AM."Take two placebos, works twice as well." Enzo
What the Crap-Toaster...
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Originally posted by stokes View PostWell,it aint right but as long as the other end of the wire is connected the same,i.e. the black wire is connected to the chassis ground,nobody is gonna get killed or injured and you wouldnt even know about it if you didnt open it up."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostMaybe not just noodling at home. But what about a circuit failure causes a hot chassis? Or you're at a gig holding your guitar and touch the PA that some pucknuckle plugged into an extension cord without a ground pin?
For example if a well-meaning tech were to come along and rewire the plug correctly, without checking the other end, there could of course be catastrophic results.
Originally posted by minim View PostWell what he means is if everything is oriented correctly at both ends the unit will still operate safely in practical terms: they are just colors after all. Having said that it's not a practice I would condone.
For example if a well-meaning tech were to come along and rewire the plug correctly, without checking the other end, there could of course be catastrophic results."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostGood point. I hope SoulFetish will report on that. And post #5
So, let me give you the back story..
I found this, just as you see it, installed on the power cord of a Hotrod Deluxe amp that came in for routine maintainance.
(I check all amps that come in with these replacement plugs to make sure that they are safe).
This is exactly the reason why I open these up to inspect the wiring.
To be clear, the other end of the cable was wired with the original wiring.. This was NOT safe. I mean, this is 0-3. Not one of these go to the correct terminal. He, and who knows who else, were just lucky he didn't attach the green wire to the live plug end, or he'd probably be tits up now.
So, yeah, this was one for the agesIf I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Originally posted by Justin Thomas View PostWhat the Crap-Toaster...
Justin
So much for his knowledge. Dangerous assumption. Never assume your youngsters on the technical staff know all they need to know.
BTW, I also lightly hold AC Mains cables or Speaker Cables in the small vise I have clamped to the bench. Just tight enough to hold it, NOT tight enough to do any damage.
Originally posted by SoulFetish View PostI found this, just as you see it, installed on the power cord of a Hotrod Deluxe amp that came in for routine maintainance.
This is exactly the reason why I open these up to inspect the wiring.This isn't the future I signed up for.
