Results 1 to 22 of 22
Thread: Sessionette - highly sensitive to EMI
    Supporting Member
    Dec 2009
    UK
    3,831
    Received: 508/1
    Given: 102/0
    14
    This is a late model (but early production) reissue Sessionette guitar amp that's come to me with noise issues. It's really sensitive to any interference from mobile phones and in particular my DECT cordless phone, but the owner says it's only recently been doing this. Otherwise the amp is working fine.
    I've isolated the problem down to one area; The output of IC6a is coupled via C44 and if I ground the negative side of the cap all is fine - complete noise immunity. If I ground the positive side of the cap the noise is back in full. I changed the cap. What the schematic doesn't show is that the signal path from that cap is via lengthy PCB tracks and then unshielded wiring to the rear PCB 'send' and then back the to the 'return' opamp buffer.
    What I can't comprehend is how this worked OK previously. I can't see any failure. IC6 is fine, no DC offset. No unusual voltages and the amp is quiet apart from the interference. As a test I removed C44, detached the leads to the rear PCB and wired IC6a pin 1 directly to C15 with screened cable. A slight improvement, but not much.
    This is driving me nuts. Does anyone have any ideas? Maybe I'm missing something really obvious. Just like a pantomime character where the audience is shouting 'He's behind you!"
    Supporting Member
    Mar 2018
    Germany
    3,233
    Received: 2,358/1
    Given: 1,342/2
    8
    I would wonder how/where the high frequency EMI gets inside. Is the amp well shielded? If yes, the EMI might still enter via the mains lead and spread/travel along the power supply wiring.
    If e.g. the HF carrier rides on the +/- 16V supply, it might get demodulated/detected by D2/D4.
    - Own Opinions Only -
    Supporting Member
    Staffordshire UK
    3,876
    Received: 599/1
    Given: 553/2
    19
    I donít trust an opamp (potentiality) feeding the outside world without a series resistor, even just 100 ohms. That at least helps to maintain stability if there was a much of a capacitive load on the send jack, eg a cable
    Iíd consider replacing IC6, the output could have shorted, overheated and been left walking wounded.
    1 Not allowed! Not allowed!
    Supporting Member
    Dec 2009
    UK
    3,831
    Received: 508/1
    Given: 102/0
    14
    The opamp is removed right now for testing purposes so I'll install a socket and replace it. There's also a convenient 0R jumper that can be replaced with a series resistor. The amp is well screened with grounded foil to the top and sides. There are a few cables exiting - speaker leads, reverb send/return and a three-core plus screen for channel switching. I've eliminate the reverb and channel switching cabling but the amp is certainly more sensitive where the leads exit. I did even wonder if the speaker leads were radiating noise.
    There are a few unrelated deficiencies with this amp; the elevated ground comprises a 100v/1u cap in parallel with a 1/4W carbon comp resistor. No anti-parallel diodes and therefore no current capability. There's also no Zobel network, though the schematic shows this as a 100n cap in series with a 4R7 3W resistor (this is fitted to earlier amps). Later on 100n film caps were added to the main PSU filter caps and these are absent in this version.
    Supporting Member
    Mar 2018
    Germany
    3,233
    Received: 2,358/1
    Given: 1,342/2
    8
    Did you try a folding ferrite on the mains or speaker cables?
    Supporting Member
    Mar 2018
    Germany
    3,233
    Received: 2,358/1
    Given: 1,342/2
    8
    If it's aluminum you surely know that it self-passivates (oxidizes) and not necessary makes good contacts.
    Feb 2010
    12,652
    Received: 2,189/24
    Given: 5,518/11
    24
    Since you mentioned 'something obvious', any chance the Aux. in jack is not grounding?
    edit: never mind, C44 test should have eliminated that.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,492
    Received: 2,542/7
    57
    Idle thinking. Look other side of C15 to R7. D2,4 clamps protect IC1. Any chance one of the diodes is open or leaky and allowing either some DC to IC1 or allowing a diode to "detect" - in the radio sense - the local EMI. ALternatively, you grounded neg end C14 and it kills noise, presumably grounding neg end of C15 would as well? But then does grounding the POS end of C15 do anything?
    Supporting Member
    Dec 2009
    UK
    3,831
    Received: 508/1
    Given: 102/0
    14
    It's all been replaced and meters through. I was thinking of adding ferrites, mains filters etc. But the owner says it only recently started to do this, so I'm looking for a component/circuit fault rather than a modification at this stage. The recent development of this problem was confirmed today with another band member. They're pretty reliable, pro musicians I do a lot of work for so I think it really is the case that it used to be OK. It's getting late but with a fresh look tomorrow I'll Replace IC6 and take a look at the checks Enzo suggests. I've tried my DECT phone with every other amp I have here (including my own MK1 Sessionette) and there's next to no noise with any even with the phone held right against the amps.
    It's interesting that even with grounding the + end of C44 the signal is so damn loud. Not just some background noise.
    Supporting Member
    Mar 2018
    Germany
    3,233
    Received: 2,358/1
    Given: 1,342/2
    8
    My proposal referring to folding ferrites was primarily meant as a means to identify the main "gateway" for EMI. This might be helpful for troubleshooting.
    I completely understand that you are looking for something that changed, failed, deteriorated.
    33,492
    Received: 2,542/7
    57
    That right there is the key to the whole process. We need to do anything we can to isolate the problem. Once we know WHERE the problem is, we can determine the cause.
  12. #12
    Supporting Member
    Dec 2009
    UK
    3,831
    Received: 508/1
    Given: 102/0
    14
    I don't have any clip-on ferrites but made up a replacement speaker cable wrapped around a ferrite ring. It took a few experiments and needs 8 turns of hookup wire but this almost kills off the noise. I have the ring right inside the chassis at the entry point and minimal external wiring. I did also discover that the reverb send cable was contributing some noise (though oddly, not the return) and replacing the cables with high-quality cables has fixed that.
    Revisiting the board; grounding either side of C15 kills the noise and lifting the diode clamp has no effect. I've been able to more accurately pinpoint the most sensitive part of the circuit and it's from C44 onwards to C15. It looks like the speaker leads radiate noise into the can of C44 and the PCB tracks that run the length of the board from C44 to C15.
  13. #13
    Supporting Member
    Mar 2018
    Germany
    3,233
    Received: 2,358/1
    Given: 1,342/2
    8
    You might try to ground the speaker frame.
    As the carrier frequency is very high, a few pF wired to ground in the "right" place might suffice to attenuate it. That is before demodulation by some semiconductor.
  14. #14
    Supporting Member
    Dec 2009
    UK
    3,831
    Received: 508/1
    Given: 102/0
    14
    I rerouted the speaker wires away from the preamp and this has the same effect in reducing the noise as the toroid. The noise is certainly being radiated internally by the speaker leads and also being picked up via the plastic phono plugs on the reverb tray.
    All of the solder joints between C44 and the power amp input have been reflowed just to make sure i don't have a rectifying joint. I experimented with some 47pf caps at various points but no improvement. It;s almost there, but not quite good enough and I still have not identified a clear fault. Certainly grounding anywhere from the negative end of C44 onwards kills the noise, but wiring a separate cap and a screened lead from IC6a directly to IC1b doesn't fix it. I'm wondering if IC1b is the problem?
  15. #15
    Supporting Member
    Dec 2009
    UK
    3,831
    Received: 508/1
    Given: 102/0
    14
    I replaced IC1 and no change. I got the amp to where I thought it was good enough and at gigging volume there was just a little bit of noise with a phone held right against the amp, but nothing noticeable when playing and with my phone in my pocket. So, I had the amp set up and the owner called by to collect and my heart sank - he didn't even get through the door and the amp was picking up his phone super-loud from 30 feet away.
  16. #16
    1,314
    Received: 2/0
    Given: 1/0
    16
    (sorry, just a non-expert guess) loose (something changed so possibly a nut loosened over time) RV 10 (A250k) pot body becoming a significant impedance over which RF is C coupling into the feedback loop?
  17. #17
    Supporting Member
    Dec 2009
    UK
    3,831
    Received: 508/1
    Given: 102/0
    14
    The pots ground fine. With IC6 removed and pin 1 grounded the noise is still there, so the problem is after this. I've had to park it to get some other repairs done, but it still doesn't make sense to me.
  18. #18
    Supporting Member
    Mar 2018
    Germany
    3,233
    Received: 2,358/1
    Given: 1,342/2
    8
    Is C44 good (low ESR)? Wondering why only grounding its negative end stops the noise.
    2 Not allowed! Not allowed!
  19. #19
    Dec 2009
    Devon, UK
    3,815
    Received: 945/1
    Given: 693/1
    14
    Mick removed and bypassed that cap in the first post so it can't be that.
    I see the focus in on the signal path but I wonder if the noise is getting in the ground side of things. If that is the case then I would expect the noise to come and go dependent on where you ground the negative end of C44 to. That process might lead you to a point in the ground path that had gone high impedance, at least at high frequencies.
  20. #20
    Supporting Member
    Mar 2018
    Germany
    3,233
    Received: 2,358/1
    Given: 1,342/2
    8
    Sorry, missed that info. Still I would try a tantalum cap in this position to see if it makes a difference.
    Good point!
  21. #21
    1,314
    Received: 2/0
    Given: 1/0
    16
    Quote Originally Posted by Mick Bailey View Post
    Ah well. Been reading about RFI/EMI issues but only understand it in general terms (avenues of ingress, countering with filtering, shielding, device/topology susceptibility, etc.) without much real life experience solving problems.
    Quote Originally Posted by nickb View Post
    Was thinking a bit of that (some AC/DC ground connection went open or iffy). Also, I gather it has insulated jacks and no high frequency AC shunts (capacitors) immediately at IN/OUT points to chassis (I understand this could mean higher susceptibility via the (significant at RF) ground impedance of cabling).
    (sorry for the interruption, carry on...)
  22. #22
    Supporting Member
    Dec 2009
    UK
    3,831
    Received: 508/1
    Given: 102/0
    14
    Further investigation shows noise is also getting picked up by the screen of the reverb cables. With my original phones used for testing I though this was a problem fixed and there was insufficient screening, but not so with the new test phone. I think nickb has identified something I'd overlooked.
    This reminds me very much of noise on a digital ignition system I designed where I thought noise was propogated by a switching IGBT. It took me months to identify the noise was the ground reference being pulled up - something called 'ground bounce'. Because my scope was always referenced to ground I was always looking at what the probe was seeing relative to ground. Time for a different approach.
    Changing the cap for low ESR made no difference, neither did a tantalum.
  1. Sessionette 75 ILP 'brick'
    By Mick Bailey in forum Music Electronics
    Last Post: 04-02-2019, 11:59 PM
  2. Sessionette 75 - fault
    By TheUnWiseOne in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-01-2016, 03:07 PM
  3. Light sensitive stuff
    By Enzo in forum Music Electronics
    Last Post: 12-31-2010, 03:32 AM
  4. Storage of EDS Sensitive Parts
    By defaced in forum Music Electronics
    Last Post: 11-09-2010, 02:48 PM
