Results 1 to 5 of 5
Thread: Peavey Valveking 112
    Feb 2007
    241
    Received: 3/0
    Given: 2/0
    14
    I have this peavey valveking that sounds weak and distorted. I've replaced the preamp tubes, phase inverter tube, power tubes, and check for opened resistors. I didn't find anything. I've noticed a defective 4560 IC and replaced it, but it didn't resolve the issue. What could be causing this?
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,480
    Received: 2,538/7
    57
    Isolate the problem, is it the power amp or the preamp that is bad?
    Apply a signal to the input and trace it through the amp, find out where it doesn't make the jumpe from stage to stage.
    Feb 2007
    241
    Received: 3/0
    Given: 2/0
    14
    It looks like it's in both. There's distortion coming out the main speaker and distortion on the preamp: going from the send on the effects loop to the input jack of another amp.
    33,480
    Received: 2,538/7
    57
    Well, if the distortion is present at the preamp out, it won't disappear going to the power amp. APply a clean test signal from somewhere else to the power amp input.
    As to the preamp, as I said, apply a clean signal at the input and trace it through stage by stage.
    Feb 2007
    241
    Received: 3/0
    Given: 2/0
    14
    Thanks! I'll give it a shot.
  1. Peavey Valveking 112 Mod ?
    By msclford in forum Mods & Tweaks
    Last Post: 09-18-2008, 02:07 AM
  2. valveking 112
    By JC@ in forum Mods & Tweaks
    Last Post: 05-03-2007, 01:03 PM
  3. Weird noise on Peavey Valveking head
    By tenrousei in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-09-2007, 02:08 AM
