I think you should be able to get around 10VAC
Low Power from Cathode Biased 2x6V6 Magnatone
B+ voltage at the OT center tap at the start of clipping are essentially the same as at idle, maybe 1 volt higher. From that point on the voltage goes up as clipping increases.
There is a possibility that the amp actually runs in class A, which is very inefficient and not really desirable (from a technical POV) for PP stages. If the amp runs in class A will be determined by the idle currents and OT primary impedance (being very high). In class A current demand essentially stays constant with output.
What is known about the OT, is it original? Does that 150R cathode resistor look original?
Still I doubt that B+ could increase as clipping increases.Last edited by Helmholtz; 03-19-2020, 09:13 PM.- Own Opinions Only -
Originally posted by Helmholtz View PostThat's very unusual. In a class AB amp current demand increases with output causing B+ to drop.
B+ definitely increases as clipping occurs. I assume current flow through tubes decreases as clipping occurs, causing the increase in B+.
Originally posted by g1 View PostHave you tried it with a 250 ohm instead of the 150 ?
If B+ increases with clipping, cathode voltage should decrease.- Own Opinions Only -
Looky looky what I found hidden in the bottom of a drawer:
(ETA: well that's not a very clear picture. It is a 250 ohm 5 watt resistor)
So, with the new cathode resistor I rechecked all voltages (note mains are slightly higher today)
A/C HT at the rectifier = 315/317
B+ = 332
C+ = 326
Power tube plates = 325
Screens = 323
Cathode = 20.3
A/C at 4 ohm load resistor at start of clipping = 4.43
B+ at start of clipping = 332
As I increase the clipping beyond that point the B+ immediately starts to climb, up to a high point of 342. At the same time K voltage decreases, to a low point of 17.8 (at the same time as max B+).
Could it just be that the OT is too small to produce any more output, that it's just saturating, causing the clipping in the output?
I think it's like this: The power stage operates in full class A (very unusual with PP amps). In cathode biased class A amps cathode voltage essentially stays constant in the linear range. As clipping occurs and the output signal gets squared, tube dissipation reduces because the tubes are now essentially switching between 2 states of low dissipation. Consequently B+ rises.
The class A operation is due to the high idle current (is the 20.3V with a 250R cathode resistor?) and most probably an unusually high OT primary impedance (>>10k?, actual primary impedance can be calculated from voltage measurements at the disconnected OT). The reason for the high (reflected) primary impedance could be that the OT was rated for a load impedance below 4 Ohm. A high load impedance would also explain the high voltage gain of the power tubes showing in the low grid drive required for output clipping.
Output clipping is no sign of core saturation. Rather saturation typically shows as something like crossover distortion at zero crossings without limiting voltage peaks.
Could you post a scope picture of the clipped output?
What is screen voltage at full output?
I would also check grid coupling caps for leakage.
It should be possible to get around 12W of clean power from this amp with an appropriate OT.Last edited by Helmholtz; 03-21-2020, 08:24 PM.- Own Opinions Only -
