JBL 2408H-2 specs/upgrade
  • JBL 2408H-2 specs/upgrade
    Howdy
    I have a fellow who has brought me 4x PRX815w speakers. I had preciously replaced each of the JBL2408H-2 drivers with a fresh set of genuine 2408H-2 from JBL, and guess what, all of them are blown again.
    I suggested possibly replacing them with some HF drivers from eminence or another reputable brand. Is there a spec sheet for the 2408H-2 available? JBL's description of the PRX815w's having a HF amp that outputs 750w to such a puny driver makes me think they may have exaggerated some numbers a tad.....
    2408H-2 (JBL P/N 5020337X)
    Neodymium compression driver
    Diameter: 37.5mm (1.5")
    D.C. Resistance: 4.8 Ω
    Crossover Frequency: 1.8KHz
    Used in: PRX-712/715/725/735, PRX-812W/815W/825W/835W
    First of all you need to check if you HF amp is intact.
