Page 2 of 2 FirstFirst 12
Results 36 to 63 of 63
Thread: Ampeg VT-120 Restoration / Repair - hum on channel C
  1. #36
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    Hi John,
    I donít think I have the means to test for ripple. But point F is showing a pretty stable 10.6vdc. To be sure I tried another 1000uf cap in there from a different manufacturer - no change to the hum.
    Will try your other suggestions shortly working back from V2 through V1.
    Cheers
    0 Not allowed! Not allowed!
  2. #37
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    Just an update on progress or lack thereof.
    Lifted R48 and hum remained.
    Then lifted R50 (off pin 3 of V2) and hum stopped. I reconnected R50 and hum came back. So thought I’d narrowed it down to something off pin 3 V2.
    Then carefully traced out the path off V2 to identify the components: R50, R51, R52, R53, R54 and R55, C28, C29 and FETs Q8 and Q9. All resistors and caps tested ok. No shorts or open lines and resistors with spec. Not an expert at testing FETs - is there any way to test in circuit? If it’s not the FETs, then stumped as all components off pin 3 of V2 seem ok.
    As an aside - when I was doing some continuity testing to ground I discovered the middle pin of channel C “High” control had intermittent ground continuity ie the test would beep rhythmically (rather than a solid tone). This terminal also connects to the one of the outer pins of the channel C and B gain controls and these show the same behaviour and on the continuity test (not the ground pin side of gain control. Unsure if this is normal or could be related. I note the “high” pot is connected to pin 3 of V2 via the “pull bright” switch on that pot. Probably just incidental.
    Enough for today. Will try some more tomorrow
  3. #38
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    33,427
    Thumbs Up/Down
    Received: 2,517/7
    Given: 0/0
    Rep Power
    57
    Don't use continuity tests, use resistance. Using continuity, yo8u can't tell if continuity means 1/10 of an ohm or 110 ohms.
    R50 opens the current path through the tube, so it is essentially the same as pulling the tube.
    Hum is not going to be caused by an off spec resistor. In other words if a 470k resistor in that circuit is really 560k or even 330k, it may affect the gain a little or maybe the tone, but would not cause hum. Kinda like if your guitar gives you electrical shocks, it won't be because the strings are untuned.
    Carefully traced out from V2? Why not look on the schematic, all those parts are right there showing their relationships.
    JFETs. They can get leaky. You wanna see if one is involved? Either remove them one at a time and see, or lift C28 or C29 to disconnect them from the circuits.
    A leaky JFET can allow DC from the control line into the signal path. The two caps block it, but it can still admit ripple.
  4. #39
    Member Jon Snell's Avatar
    Join Date
    Aug 2015
    Location
    Jurasic Coast, England
    Posts
    152
    Thumbs Up/Down
    Received: 49/0
    Given: 7/0
    Rep Power
    5
    Q7,8 & 9 act like a switch, either on or off and increase the gain of that particular stage.
    Eg; Q9 effectively places a 0.1uF capacitor across the cathode resistor increasing the gain above the CR point so above about 6kHZ there will be a 6dB increase in level. Q8 does the same at a lower frequency.
    JFETS are used as switches in this application and are either on or off. If you use your DMM on Diode test, when powered off they should read open circuit Source to Drain. Don't let them confuse you!
    Ampeg have had a lot of trouble with JFETS failing in the effects loop from dodgy pedals that are not earthed properly killing them, not their fault.
    When removing C27, the signal path is interrupted before that point, if the hum stops, the hum is being picked up before that point, if it doesn't, it is being picked up after that point.
    Be logical, keep a note.
    This is not about testing components, it is about isolating and fixing the cause.
    The cycling beep from the pots is a red herring, I think.
    Check your ground points go to the ground and not just floating.
    Years ago, when I had the odd Television, and colour first entered the UK, I quickly learnt to divide the fault up and that there was only ever one fault plus my saying was, "It's only a telly". If it had a video fault, decide what sort of video fault and go down that path. If it had an audio fault, likewise.
    So many good engineers got lost by trying to look at the whole scenario and that circle on the schematic that contains the fault got much bigger for them.
    So, it's only an amplifier and the hum is to be isolated at the one point and fixed.
    I still reckon it is a bad ground or a faulty valve. Did you replace the ECC83 with another one, to check it?
    Have fun.
    Support for Fender, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
  5. #40
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    Hi Enzo,
    Thanks for the detailed reply. With continuity - I was primarily look for shorts to ground and was looking physically for solder bridges or something connecting to something elsewhere shouldn’t be...
    Understand that the spec of a resistor won’t cause the hum. But I’ve had some luck, mostly with carbon comps, with weeding out noisy resistors that were also out of spec. But acknolwedge this hum is unlikely to be caused by a resistor. I suppose I was just curious to see if everything was in spec and functioning as it should be.
    When I say I traced out the circuit. This was literally using a sharpie to trace the circuit board - using both the schematic and layout. This is more to easily physically identify the parts on the board than anything. The board is hard to access, with components on the underside and no easy means to get to them without have to pull a whole bunch of connectors. So scribbling on the bottom of board helps me locate components easily. By the end of this I’ll probably have all the components on the bottom of the board labelled!
    Thanks for the info on the JFETs -again because of the absolute pain of access the component side of the board, trying to test things in circuit where I can. But understand this can’t always be achieved.
  6. #41
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    Hi John,
    I think I’ve ruled out it being any kind of tube problem as I’ve tried multiple new tubes through everyposition including preamp and power section. So I think tubes are out.
    But like you, I do suspect it is a grounding issue. The hum reminds of previous grounding issues. I just stumbled on this which is essentially a blog of a repair of one of these by an amp repairer from around 9 years ago. It’s an interesting read https://www.google.com.au/amp/s/atom...c-overhaul/amp
    Funnily enough I already completed a lot of the work that he has - seems to be some common issues caused by underated components and resistors burning out.
    However he has a long treatise on hum. Below is a direct quote from the page about the hum and how he dealt with it:
    The biggest deal: the grounding scheme. I read on some forums (yeah, I know, ugh) that the amp had a ground loop, which was what caused the excessive hum. So I traced out the entire ground circuit with a sharpie on the solder side of the PCB. This was miserable and took forever – only to demonstrate conclusively that there is NO ground loop. I messed with rerouting a few things to more local points, but that only made things worse.
    Eventually, I just implemented a version of the Valve Wizard multi-star scheme (which I used in the Atomium Model A, a very quiet amp), with jumper wires and cutting traces. V1 and the entire front panel are grounded to the bottom of C9. This is area A. Area A connects by one jumper wire to Area B, which all the grounds in V2 go to. Area B connects by a jumper wire to Area C, which has SOME of the reverb circuit grounds and V4, and connects by a jumper to Area D, which has the other reverb grounds. The connection point between C and D then runs back to the main star point, which is the center tap of the PT B+ winding (green wire spade connector, J31). I cut the jumper wires between A, B, C, and D, and cut them all off from the main star. I ran separate wires from A and B back to the ground of C8. I connected C and D at their jumper point and ran a wire from there to C8’s ground (C8 supplies V2-4). I used 18-gauge solid-core copper wire
    I still find it difficult to believe they hummed this bad from the factory but I suppose anything is possible. I do have time on my hands and could implement a similar grounding scheme to see if that would improve things.
    I appreciate the advice about eating the elephant one bite at a time. It can certainly initially seem overwhelming with so much stuff to consider and look at. On the up side, I’m in no rush and have some time up my sleeve, so will just be patient with it.
  7. #42
    Join Date
    May 2006
    Location
    Posts
    33,427
    Thumbs Up/Down
    Received: 2,517/7
    Given: 0/0
    Rep Power
    57
    I worry more about JFETs in the gate area. The Source/drain path is a low resistance until turned off by the gate. But the gate can get leaky to the S-D path. And that can inject noise into the system. Easy to determine, and in my view worth a check.
    And did we ever determine if your hum was 60Hz or 120Hz? In my JFET scenario, the control signals run off supply F which in fact is half wave, so ripple there would be 60Hz.
    1 Not allowed! Not allowed!
  8. #43
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    Enzo,
    My little project today is to look at the JFETs and work out whether theyíre the cause.
    Being in Australia I think itís 50 cycle hum. Looking at my Petersen strobe app whilst holding close to the speaker appears to be perfect 50 cycle ..
  9. #44
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    Just lifted C28 and C29 and hum remained ..
  10. #45
    Join Date
    May 2006
    Location
    Posts
    33,427
    Thumbs Up/Down
    Received: 2,517/7
    Given: 0/0
    Rep Power
    57
    50 or 60, equivalent in terms of what we are doing.
    OK lifting those caps clears my JFETs. So much for that. Thanks for checking them.
  11. #46
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    No problems. Appreciate the suggestion! And I learned a bit about JFETs in the process!
  12. #47
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    John - I have the board out again at the moment and though I would test the JFETs (J176s) in the circuit just out of curiosity. I have my DMM set to diode test and am placing probes Source to drain, but none of the JFETs on the board are reading open circuit. Most read 0.05v.. I’m guessing doing something wrong.. does this test work in circuit?
  13. #48
    Join Date
    Feb 2010
    Location
    Posts
    12,612
    Thumbs Up/Down
    Received: 2,172/24
    Given: 5,478/11
    Rep Power
    24
    Jfets are 'on' til you turn them off. So a low resistance reading from source to drain unpowered is normal.
    I think John just made a typo.
  14. #49
    Join Date
    May 2006
    Location
    Posts
    33,427
    Thumbs Up/Down
    Received: 2,517/7
    Given: 0/0
    Rep Power
    57
    That's not how JFETs work. SOurce to drain will be a lowish resistance, UNLESS you turn it off with a gate voltage. What resistance? I don't know, I usually expect something like 50-200 ohms. With a gate voltage they go very high resistance, effectively off.
    On diode test 50 ohms or 100 ohms would indeed read like a very low voltage. But flip over to resistance.
    Remember, it takes voltage to turn them OFF, so unpowered, NONE of them would measure open. Unpowered, your JFETs should measure some low resistance
  15. #50
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    Spent some time doing some tube experimentation.
    If I stick a 12AU7 in V2 the hum drops to bearable levels. The hum is still there. Just no where near as noticeable. With a 12AX7 in V2 the hum is a lot louder. Unsurprising I guess given the much lower gain factor of the 12AU7 - so isn’t amplifying the hum as much as a 12AX7. Also use surprisingly the 12AU7 drops the entire volume of the amp around 30%.
    I tried a 12AU7 in V1 and 12AX7 in V2?but hum was still very loud. So have no doubt the hum is emanating from around V2. As tested previously - pulling pin 2 of V2 made no change to hum, so don’t believe there’s any issues there. I lifted and tested a lot of components around pin 3 of V2 and couldn’t find anything.
    So I guess next step is looking more closely at components off pins 6,7 and 8 of V2?
    I suppose I could leave the 12AU7 as a work around and just live with it..
  16. #51
    Join Date
    Aug 2015
    Location
    Posts
    152
    Thumbs Up/Down
    Received: 49/0
    Given: 7/0
    Rep Power
    5
    Keep it simple and try not to look too deep.
    Connect a link across R41 (pin 7 to ground). Does the hum stop? If yes, the hum is coming in from there, if not the hum is probably caused by a bad ground for R41 or there is an issue with pin 8. Link pin 7 to the actual chassis at the main smoothing capacitor negative point.
    What happens?
  17. #52
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    Checked R41 connections. All seemed fine.
    Linking pin 7 to smoothing capacitor made hum louder - like it was humming in unison.
    Checked / inspected all through pin 8 components and then went back through compoents off pins 2, 3, 7 lifting a whole bunch of components of V2 with no luck. Hum seems to persist and can’t seem to narrow it down to a single component. Starting to think it is “normal” as part of the design.
    I note the damping switch on the back - it makes the hum notably worse when pushed it.. When running it at half power triode mode the hum is not too bad. At full power / pentode mode it’s louder, as would be expected. At full crank in this mode - lots of hum, even with humbucker guitar. Then again it is a 120w high gain amp, so maybe I’m expecting too much.
    Will take a break for a day or so. Do some thinking and reading. Contemplate taking it to a local tech - but if hum is “normal” not sure what else they will do except perhaps mess with the grounding scheme.
    Have certainly appreciated the help and advice to date.
  18. #53
    Join Date
    Aug 2015
    Location
    Posts
    152
    Thumbs Up/Down
    Received: 49/0
    Given: 7/0
    Rep Power
    5
    At this point I would say without a doubt, it is not a faulty resistor or capacitor. It is either a ground in the wrong place, a ground that has lifted somehow or a dodgy valve.
    Do you have less than 120R between either side of the heater pins and ground and is the value equal?
  19. #54
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    John
    No - not less than 120R. Both measuring 156R
  20. #55
    Join Date
    Aug 2015
    Location
    Posts
    152
    Thumbs Up/Down
    Received: 49/0
    Given: 7/0
    Rep Power
    5
    From a 200R pot and 100R resistor, that sounds about right.
    Have you tried adjusting P13 the heater ripple balance control?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Screenshot 2020-03-31 at 09.20.53.png
    Last edited by Jon Snell; 03-31-2020 at 09:22 AM. Reason: Partial schematic added for clarity
  21. #56
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    Hi John
    Yeah - I’ve played with the hum balance pot. At its current setting it is at the “quietest” I can get it, which is roughly the centre of the pot - but is still loud. At either extreme it hums a lot more though. As an aside - this whole pot was missing when I got the amp. So replaced it with a 200r equivalent and seems to work ok. Just doesn’t dial all of the hum out.
    Spent today testing every ground I could find on the schematic and all checked out ok. Couldn’t find anything that had lifted. Also kept an eye out for any solder bridges or trace issues while I was at it but all looks pretty good.
    Tried a bunch a different tubes again thinking I might get lucky, but to no avail.
  22. #57
    Join Date
    Aug 2015
    Location
    Posts
    152
    Thumbs Up/Down
    Received: 49/0
    Given: 7/0
    Rep Power
    5
    Have you thought about removing the ground side of R11 and putting it at a positive potential, something like 50volts DC above ground? Use a 220k and 47k resistor as a potential divider then place a 47u 63v cap across the 47k to ground.
    If you have a problem with one of the 6L6s leaking, that may stop the leak or swap out the 6l6s.
    Without working on it, I don't know what else to suggest.
    Sorry.
    Keep safe and healthy in this difficult time.
  23. #58
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    John
    I sincerely appreciate your time and expertise. I’ve tried three different sets of matched quads in the power section. A set of 6L6 and a two sets of EL34 - all brand new. So pretty confident it’s not emanating from the power tubes.
    I’ll give it a little more time, otherwise will just bite the bullet and take it to a local tech to see what they might come up with.
    You stay safe too!
  24. #59
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    I’ve bitten the bullet and taken it in to a very experienced local amp tech who I have used a few time over past couple of decades. I’ll report back what he comes up with. In talking it through with him at drop off, he suspected it may simply be the design of the amp, but was going to tear it down and take a look anyway.
    I’m happy either way. This amp was dead and completely non functional when I got it, with a multitude of issues. The fact that she is back to life is a great outcome, and as I said at the start of the thread - I can live with him if need be. Will simply use channel b and dial back the hum using the master volume.
  25. #60
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    Just a quick update for anyone interested. Just took a call from my amp tech and he’s opting out of the repair. Said he’s spent hours on it and can’t figure out what’s happening and where the hum is coming from. Recommended I take it to the other very experienced and reputed amp tech in town.
    On the one hand makes me feel better that even a very experienced and well regarded tech couldn’t fix it, but on the other hand frustrated that it remains unresolved. Taking it into the other guy next week. Will see how that goes.
  26. #61
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    80
    Thumbs Up/Down
    Received: 18/0
    Given: 9/0
    Rep Power
    0
    So, just to close this one out, got the amp back from the 2nd tech and all fixed.
    He said it was a complex repair but essentially the hum was coming from the switching circuit and required replacement of multiple components. He did bemoan the design of the amp in terms of not being tech friendly, but ultimately got the job done. Amp is now whisper quiet on all channels and sounds great.
    The VT-120 is a great value amp given the low resale for them these days. You get a whole lot of amp, especially in terms of dollar per watt.. if you are able to work through some of the shortcomings and service the amp it’s a worthwhile beast.
    2 Not allowed! Not allowed!
  27. #62
    Join Date
    Feb 2010
    Location
    Posts
    12,612
    Thumbs Up/Down
    Received: 2,172/24
    Given: 5,478/11
    Rep Power
    24
    If there were any parts listed on the bill, it would be great if you could post them.
  28. #63
    Join Date
    Mar 2008
    Posts
    868
    Thumbs Up/Down
    Received: 110/0
    Given: 240/0
    Rep Power
    13
    Quote Originally Posted by q9522678 View Post
    That’s what I love about this forum. I can labour over something for days with my limited electronics knowledge and then have it clearly and simply explained in a few succinct paragraphs. Thanks for taking the time to explain that. Make sense and demystifies the amp a little.
    I can say it twice
Thread Information
Users Browsing this Thread
  1. very particular Fender amp repair / restoration in Los Angeles (Burbank / NoHo)
    By lexington125 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-17-2015, 05:17 PM
  2. AMPEG ET-1B Restoration
    By Gingertube in forum Vintage Amps
    Last Post: 07-08-2013, 05:07 AM
  3. Ampeg Reverberocket II Restoration
    By RobertS_031 in forum Repair and Restoration
    Last Post: 07-26-2008, 03:18 PM
  4. Ampeg GV-22 1968 vintage restoration
    By Edmund Dantes in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-15-2008, 07:59 AM
  5. Hammond M2 Repair & Restoration--help!
    By 6267 in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-13-2008, 06:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
