Results 1 to 13 of 13
Thread: Peavey Bandit 112
    Supporting Member bsco's Avatar
    Jan 2012
    Eastern Canada
    1,798
    Received: 157/0
    Given: 203/0
    10
    Peavey Bandit 112
    I had started a thread on this before but couldn't find it.....anyway, this amp uses a quad switch..actually two of them....NJU211.....I had ordered a DG211D but it isn't compatible....anyway, the one on the power amp board is actually part of the pre-amp ckt...and that is where the problem seems to be....Pin 11 has 15V on it.....it should be zero...I have it installed in a socket...so I should be able to remove the chip, and going by the schematic, use jumper wires to wire up the switching configuration to get the amp to produce sound... I can scope the signal all the way up to pin 2 but nothing on Pin 3 and pin 3 feeds one of the jacks at the rear of the chassis....and I believe pin 7 does the same thing......there are no signals coming out.....the chip does have the proper voltages at pins 4, 12 and 13......and I also noticed that the op-amps, U2 and U3 have DC voltage at pin 7....over 1 volt actually.....pin 1 on these chips checks fine.....so it looks like I have multiple issues?? I will do some more testing and post the schematic later this evening as it is over to the shop.....
    Cheers
    Dec 2008
    Wernersville, PA
    13,106
    Received: 629/3
    Given: 331/0
    28
    It sounds like you have the 'Red Stripe' Bandit 112.
    The parts list shows DG211 for the switch ic.
    https://datasheets.maximintegrated.c...201A-DG211.pdf
    I have no idea what a UJN211 is.
    " I can scope the signal all the way up to pin 2 but nothing on Pin 3"
    Is Pin #1 going Lo?
    Pin #1 must go Lo to turn on pin 2/3 connection.
    Feb 2010
    12,650
    Received: 2,187/24
    Given: 5,514/11
    24
    Quote Originally Posted by Jazz P Bass View Post
    Not UJN but NJU
    Attached Files Attached Files
    Jan 2012
    Eastern Canada
    1,798
    Received: 157/0
    Given: 203/0
    10
    Not UJN but NJU
    You are right g1.....I had posted the wrong part number.....I jumped pin 2 to pin 3 and everything worked....so either the chip is bad, or something is preventing it from activating..I do have some DG211's, but they don't seem to want to work....I will re-check them after the weekend and post back......stay safe everybody...
    cheers
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,481
    Received: 2,539/7
    57
    So monitor its control pins and see if they toggle when you channel switch.
    Jan 2012
    Eastern Canada
    1,798
    Received: 157/0
    Given: 203/0
    10
    will do....You are up early..it is 6 AM here and I am ahead of you by 1.5 hrs...
    33,481
    Received: 2,539/7
    57
    I am old, I have no schedule. I might sleep all afternoon. Tomorrow might be opposite.
    1.5 hours? So you are in that Labrador zone?
    Jan 2012
    Eastern Canada
    1,798
    Received: 157/0
    Given: 203/0
    10
    No. I am on the edge of St. John's, NL actually...Labrador is an hour ahead of you...I am 1.5 hours....
    Dec 2008
    Wernersville, PA
    13,106
    Received: 629/3
    Given: 331/0
    28
    Red Stripe schematic: Red Stripe Schematic Parts.pdf
    Jan 2012
    Eastern Canada
    1,798
    Received: 157/0
    Given: 203/0
    10
    I'm not sure if the one I have is the red stripe model...I will have to check on Monday....
    Cheers
    Nov 2013
    345
    Received: 130/11
    Given: 45/0
    7
    just got a MIC recent Bandit,service manual is the one from 2007,same problem,channel chip is stuck in clean mode
  12. #12
    Jan 2012
    Eastern Canada
    1,798
    Received: 157/0
    Given: 203/0
    10
    Quote Originally Posted by alexradium View Post
    My problem is not quite the same...I am getting 15V out of the chip and it is sending that voltage to the send./return jacks......I also have 1.2 volts on pin 7 of all three op.chips...(4560's)....I do have a couple of DG211's here which I am going to try again when I get over to the shop......should be later today or tomorrow for sure........let me know if you solve your issue...
    Cheers
  13. #13
    Nov 2013
    345
    Received: 130/11
    Given: 45/0
    7
    just got it sorted out right now,it was a broken path from the s3 switch to the chip, pins 9 and 16,too many vias,replaced with a straight wire directly.
  1. peavey bandit 112 II
    By metalmike in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-01-2015, 01:07 AM
  2. Peavey Bandit 65 Guitar Amp help
    By Jimmydoo92 in forum Guitar Amps
    Last Post: 04-15-2011, 12:52 PM
  3. Peavey Bandit 65
    By Sock Puppet in forum Schematic Requests
    Last Post: 01-05-2010, 10:53 PM
  4. Peavey Bandit 112 low volume
    By porman in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-30-2008, 08:36 AM
