Results 1 to 8 of 8
Thread: Tube mic - capacitor off mic element increase
    Senior Member Guitarist's Avatar
    Jul 2006
    579
    Received: 8/0
    Given: 11/0
    14
    Last night, I took out the 1000pF ceramic cap and swapped in a .0033uF [edit] orange drop which fit fine. Cathode cap is upgrade to hi-grade semiac? type. Can't recall the exact name again but it still electrolytic. Was this ok?
    I might swap in a 1.2 V rechargeable AAA battery yet as I love this sound.
    I forgot to write down the plate voltage but it is likely 50V too high as I'm using an Apex 460 power supply. But the tube seems fine still...a 6ZH1P.
    The transformer sure seems big/robust.
    Question:
    If I were to add a pre-transformer-Send— via drilling a small hole in the mic's-case rear and add a "mini" jack maybe like 1/8"—would this net a purer sound option? So basically a Send right from the tube.
    I have an extra wire, I think, along the long Muti-wire cable but I was fearing cross-talk.
Name:	Oktava tube MKL 2500 Ev.jpg
ID:	57576   Click image for larger version.
Name:	Oktava ibside.JPG
    Jul 2006
    579
    Received: 8/0
    Given: 11/0
    14
    Are these 6ZH1P tubes very high quality? Is there a better substitution (even though I am pretty happy here?
    I see the 5654 now, so that might be good one to phase in later.
    Feb 2010
    12,650
    Received: 2,187/24
    Given: 5,515/11
    24
    Quote Originally Posted by Guitarist View Post
    Last night, I took out the 1000pF ceramic cap and swapped in a .033uF orange drop which fit fine.
    Your schematic shows .0033uF, big difference to .033uF. Which did you use?
    I would think the transformer is built in to the design, so I doubt it would sound better bypassing it. Could actually sound poorer.
    Jul 2006
    579
    Received: 8/0
    Given: 11/0
    14
    Oops, yes just .0033. A that impedance I'm not sure if that will extend the lows some or, as you imply, just saturate that transformer.
    Feb 2010
    12,650
    Received: 2,187/24
    Given: 5,515/11
    24
    I was referring to 'bypassing' the transformer by using a pre-transformer send.
    As far as increasing that cap value, it sounds like you got a low end boost which you like. I don't know about saturation, but you might have issues with 'pop' depending on the user and proximity.
    Jul 2006
    579
    Received: 8/0
    Given: 11/0
    14
    Aha, right I didn't yet consider pop.
    Well, I don't have the extra parts for that Send right now anyways so, that can wait.
    These Oktave mics sure sound sweet!
    thanks for your insights!
    Supporting Member
    Mar 2018
    Germany
    3,228
    Received: 2,358/1
    Given: 1,337/2
    8
    The cut-off frequency with a 1nF coupling cap and 1G input resistance is 0.16Hz. Do you need lower?
    The cathode network of 3.6k and 22F means a corner frequency of 2Hz, same question.
    - Own Opinions Only -
    Jul 2006
    579
    Received: 8/0
    Given: 11/0
    14
    Ahhh, well that might suffice. I don't want the studio to vanish hitting a 0Hz wave!
    That answer as I was wondering— what those values might be—thanks so much.
    OT aside, .1 to 400KHz is pretty good!
    Should I leave the pentode schematic alone? The screen grid, G2, is simply tied to the plate. There is some free, untapped gain here but I read that pentodes prefer lower voltages and this power supply is way high, like 200V.
    At the plate resistor is now 200k, perhaps a 100k from B+ and a .1uF to ground to revert to pentode mode?
Name:	Screen Shot 2020-03-29 at 6.14.14 PM.png
  1. Out of my Element
    By ron45 in forum Guitar Tech
    Last Post: 04-27-2018, 10:17 AM
  2. Piezo element sources?
    By mycle in forum Pickup Makers
    Last Post: 01-27-2012, 09:41 PM
  3. Laerge Diaphragm Mic Element... point which way?
    By FunkNotPunk in forum Music Electronics
    Last Post: 12-12-2011, 09:27 PM
  4. Capacitor limits after tube rect ?
    By Rattler66 in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-03-2007, 02:12 AM
  5. Testing mic element
    By JC@ in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-15-2006, 10:13 AM
