If I am close (with my hand) to the pots with volume open, then it is giving much more hum.
Pro Jr Point-to-point hum issue
Originally posted by klooon View Post[ATTACH=CONFIG]57604[/ATTACH]
If your chassis is actually coated, make sure that all chassis connections make good contact.- Own Opinions Only -
Is that one of the Fenders that comes with ashielded back panel & is known to make lots of noise if the panel is off but it goes away with the panel on, normally?
I didn't see you mention if it hums in the cab with the panel on & I know it's a long shot, but can't hurt to try... Given there's a precedent for that. Otherwise I'm iut of ideas.
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
It seems to work fine now! I rewired and rewired it, put shielded wire to both grids of V1. Shaved some coating off. Put the 100R at the tube socket with shielded wire and put underneath the board.
Was still a bit picking up noise, and the put the cover on like suggested above... And then: fine!!
Thanks so much for the input!
A couple of suggestions.
Does the setting of the volume control affect the hum level?
I don't see a connection between signal ground and the chassis. On the original layout this was done at the input and speaker jacks. It looks like you have insulated jacks in both locations so try connecting the chassis to signal ground and see if it helps.
I would be inclined to use a screened cable from the volume control to V1. I notice you did make some improvements to that wire. Connect the shield to signal ground at the volume pot only with the 100R at the V1 end ( as you now have).
Your spectrum plot does have a fundamental of 50Hz but the 100Hz line is higher. Therefore I think you have both 50Hz (heater or other 50Hz AC source) and power supply 100Hz issues.
PS: Oh I see kloom posted while I was writing this...oh well!Experience is something you get, just after you really needed it.
I am still not happy. I moved around the wires again and it still gives too much hum to my taste.
Yes. Very clearly. Volume at 1 and the hum is very bad. Turning the volume past 9 and it is gone.
Originally posted by nickb View PostI don't see a connection between signal ground and the chassis. On the original layout this was done at the input and speaker jacks. It looks like you have insulated jacks in both locations so try connecting the chassis to signal ground and see if it helps.
Originally posted by nickb View PostI would be inclined to use a screened cable from the volume control to V1. I notice you did make some improvements to that wire. Connect the shield to signal ground at the volume pot only with the 100R at the V1 end ( as you now have).
Originally posted by nickb View PostYour spectrum plot does have a fundamental of 50Hz but the 100Hz line is higher. Therefore I think you have both 50Hz (heater or other 50Hz AC source) and power supply 100Hz issues.
mmm. what to do?
What happens if you break the connection between the two 47 ohm resistors to ground off your heater wires (puesdo ground), and take that connection directly to chassis at/near the power xfmr mtg screw? I'd also try using a 100 ohm/2W or greater linear pot as hum balance in place of the two resistors, and tweak the balance to minimize hum. We see in your frequency spectrum plot the third harmonic (150Hz) is highest, while also seeing high power supply harmonics, as nickb pointed out.
In spite the problems encountered, I do love your rebuild form factor!
What are the two rear panel switches? One looks to be a power output select switch (15W/3W), but don't see what the adjacent switch is/does.Last edited by nevetslab; 04-10-2020, 09:46 PM.Logic is an organized way of going wrong with confidence
Originally posted by klooon View PostI am still not happy. I moved around the wires again and it still gives too much hum to my taste.
I have one central ground point - close to the input, so it should ground "everything". Also what you mean by the signal ground?? Please, could you explain?
Yes, I have improved this now. Still moving this shielded wire is changing the "sensitivity" to noise a bit...
And that's related to the above?!
mmm. what to do?
Let's concentrate on the hum at volume on 1. I take it that "1" is zero volume and it's more of a buzz than hum. It might be that the wire from the common ground on the board to the volume pot is picking up noise. As a test disconnect the screened wire that goes to the wiper and connect it directly to the common ground. If the hum / buzz is gone or much reduced then try soldering pin 3 of the volume pot directly to the metal body instead of the wire that currently goes to pin 3 of the pot or use a short wire if need be and put the screened wire back on the volume pot.
And do try what nevestlab suggested. Right now the mid point of the two 47 ohm resistors is connected to a rather noisy place and could inject noise everywhere via the heater wiring.Experience is something you get, just after you really needed it.
Thanks for your help!
Originally posted by nevetslab View PostWhat happens if you break the connection between the two 47 ohm resistors to ground off your heater wires (puesdo ground), and take that connection directly to chassis at/near the power xfmr mtg screw?
Originally posted by nevetslab View PostI'd also try using a 100 ohm/2W or greater linear pot as hum balance in place of the two resistors, and tweak the balance to minimize hum. We see in your frequency spectrum plot the third harmonic (150Hz) is highest, while also seeing high power supply harmonics, as nickb pointed out.
Originally posted by nevetslab View PostIn spite the problems encountered, I do love your rebuild form factor!
Originally posted by nevetslab View PostWhat are the two rear panel switches? One looks to be a power output select switch (15W/3W), but don't see what the adjacent switch is/does.
Originally posted by klooon View PostLet's concentrate on the hum at volume on 1. I take it that "1" is zero volume and it's more of a buzz than hum.
Originally posted by nickb View PostIt might be that the wire from the common ground on the board to the volume pot is picking up noise. As a test disconnect the screened wire that goes to the wiper and connect it directly to the common ground. If the hum / buzz is gone or much reduced then try soldering pin 3 of the volume pot directly to the metal body instead of the wire that currently goes to pin 3 of the pot or use a short wire if need be and put the screened wire back on the volume pot.
Originally posted by nickb View PostAnd do try what nevestlab suggested. Right now the mid point of the two 47 ohm resistors is connected to a rather noisy place and could inject noise everywhere via the heater wiring.
What I just noticed, is that when I plug into a wall socket that has no ground, you feel the "electricity/voltage" on the chassis. Is this normal??? What could be the cause of this??
Originally posted by klooon View PostYes, volume "1" is zero volume. No it's more a humming noise. Higher frequency buzz is also there at higher volume settings and changes with moving the grid wire to the volume pot around.
I just tried this and no changes to the hum and buzz.
I just tried this and does not change the hum.
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
First, never, ever use an ungrounded socket. If it's just a slight sensation likely it's just stray capacitance between the windings. Using an ohm meter to check that the earth from the plug has a low resistance to the chassis. Also check that live goes to the power switch and fuse. Don't just look at wires. Assume that the wire colours can't be trusted so measure from the plug. Check the neutral does not connect to the chassis
You hum issue is elusive. Disconnect the grid from the screened wire and 100 ohm grid stopper that goes to the volume control wiper and short the grid to the cathode using as direct a connection as you can manage. What happens to the hum?Experience is something you get, just after you really needed it.
Originally posted by nosaj View PostTurn the plug around. scratch that, I'd suggest you have a serious wiring error and need to find this with the amp unplugged. What you describe is common with a transformerless amp or a amp with a failed deathcap. Neither of which I see in your layout. Stop! and find the issue before continuing on
nosaj
