Results 1 to 12 of 12
Thread: Selmer TV6 from 1964 for repair
    Member Jon Snell's Avatar
    Aug 2015
    Jurasic Coast, England
    171
    Received: 55/0
    Given: 7/0
    5
    I was sent this amplifier from a person in the UK that as he wasn't confident enough to get this amplifier going, I undertook the repair at the cost of parts only. It is too valuble to get destroyed or lost.
    The story was that it went wrong back in the early 70s and was stored away in the loft until a few weeks ago.
    I suggested it was not powered up as the electrolitycs will need reforming. That was a slow process. I removed the valves except the rectifier, checked for any electrical issues and then fitted a 100k resistor between the output of the EZ80 rectifier and the first tank capacitor. This is very important as it stops any inrush of current that will damage any old electrolyte until it has been reformed, a lot like an old lead acid battery with a similar process but usually more success with electrolitycs.
    The whole process took about 24hours before the leakage current was reduced to uAmps and then I check and replace the faulty components.
    There was a few components that were out of tollerance and were replaced. The original fault was a faulty EL84. Intermittant Screen grid short to Supressor grid. Not that unusual but the valve looked original, so I forgive Mr Mullard.
    I enclose a few photographs for interest and still carry out 'hospital jobs' at cost. Another interesting part of our history.
    Thank you for looking and hope you find this interesting.
Name:	Multi cell capacitor.jpeg
ID:	57620   Click image for larger version.
Name:	After 1hour reforming almost complete.jpeg
ID:	57621   Click image for larger version.
Name:	Testing a NOS EL84.jpeg
ID:	57622   Click image for larger version.
Name:	Showing the 1200R that measures 178R.jpeg
ID:	57623   Click image for larger version.
Name:	Happy heaters.jpeg
ID:	57624   Click image for larger version.
Name:	Old parts.jpeg
ID:	57625   Click image for larger version.
Name:	All now working.jpeg
    4 Not allowed! Not allowed!
    Support for Fender, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
    Jun 2006
    Norristown state hospital
    2,392
    Received: 215/4
    Given: 1/0
    17
    Cool old amp!
    A friend just picked up a Selmer Zodiac Twin that belonged to Eric Bazilian of the Hooters.(semi famous Philly band)
    Aug 2015
    171
    Received: 55/0
    Given: 7/0
    5
    Nice!
    Look after it, there are not many left.
    Oct 2015
    NEPA
    883
    Received: 222/2
    Given: 159/0
    5
    Who made those white resistors with the orange ends?
    Old Timer
    Chill-Ville, VA
    3,455
    Received: 856/6
    Given: 1,765/10
    19
    Sweet old amp! I scored a couple EF86s like that in an old projector from a school. Along with a Telefunken & Seimens EL84 each. Couple Mullard ECC81s also.
    Justin
    Aug 2015
    171
    Received: 55/0
    Given: 7/0
    5
    Probably Mullard, long time ago, I just remember them as 'Carbon Drifters'.
    Supporting Member
    Dec 2009
    UK
    3,828
    Received: 507/1
    Given: 102/0
    14
    Quote Originally Posted by mozz View Post
    They're made by Erie in the UK. They were the most common resistors here up until maybe the early to mid '60s. Because they're formed inside a ceramic tube it makes them quite bulky for their power rating.
    1 Not allowed! Not allowed!
    Oct 2015
    NEPA
    883
    Received: 222/2
    Given: 159/0
    5
    Friend has a old fuzzface, original I think, that had those resistors. He wanted me to find some but if they are known to be bad could be a moot point. Maybe he's just trying to get it back to stock looks to increase collector value.
    Aug 2015
    171
    Received: 55/0
    Given: 7/0
    5
    They are not 'bad' but merely old and getting a little unreliable. Most were rated at 1/4 Watt and driven a bit harder, anode load resistors come instantly to mind, they change value under load.
    If you look at older equipment, as I do, it is good to remember the old resistor chart, Body, Tip Dot.
    I still have my Radio Spares resistor kit complete with most values of carbon drifters.
    The case dates back to the early 70s but cannot remember the cost at the time.
Name:	Screenshot 2020-04-02 at 14.04.51.png
    Supporting Member
    Dec 2009
    UK
    3,828
    Received: 507/1
    Given: 102/0
    14
    I sometimes get older AC30s which are populated with Erie resistors. They do drift, but I don't replace them unless there's a problem. The same with Rangemasters and Fuzz faces - they can drift in a way that gives a pedal a desirable sound. the higher value resistors drift more and plate load resistors can be noisy, so that can be a problem if excessive. It's worth remembering though that Erie made hi-stab versions using the same ceramic body construction. Rather than carbon these are metal film and are an excellent replacement where noise and stability are key. At one time B&W TV sets were a good source of these as 'pulls'.
    Erie was founded in the USA - did the factory there make the same component style as the UK? I can't recall seeing American equipment with these installed.
    Aug 2015
    171
    Received: 55/0
    Given: 7/0
    5
    The High Stability resistors had the pink band on them and mostly they were 10% tolerance, sometimes 5% with the gold band as well.
    Cannot speak for USA though but I remember most chassis built in the 60s had those resistors fitted.
    I still get the early AC30s in for refurb with those in and as you do, only replace the faulty ones. I found a source of the 8u - 8u twin pack electrolytics, nice to fit the correct value and look components.
    Good to hear from you and keep safe and well.
  12. #12
    Oct 2015
    NEPA
    883
    Received: 222/2
    Given: 159/0
    5
    I've got a bunch of 2.7meg, i think these are Erie, if UK made i don't know how they got over here. They all measure exactly 3.4meg which seems odd but they were all stored in the same container since the 70's.Click image for larger version.
  1. 1964 Ampeg Jet Questions
    By Triocd in forum Vintage Amps
    Last Post: 08-31-2015, 01:26 AM
  2. 1964 Deluxe Reverb
    By Doc Stitches in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-14-2014, 02:04 AM
  3. 1964 Revererocket
    By doog in forum Repair and Restoration
    Last Post: 04-19-2013, 09:22 AM
  4. 1964 Fender Vibroverb
    By futureblues in forum Vintage Amps
    Last Post: 09-01-2012, 07:42 AM
  5. 1964-65 Formvar?
    By voodoochild in forum Pickup Makers
    Last Post: 10-04-2010, 09:04 PM
