Results 1 to 32 of 32
Thread: Peavey 6505+ DC Heater question
    Nov 2018
    235
    Received: 29/0
    Given: 5/0
    2
    I have a Peavey 6505+ up on the bench with intermittent AC heater supply due to a bad connection in the spade connector. My plan is to replace the spade connectors with turrets for a better connection. I have read that the rectifier for the DC heater supply (in4003 at 1A) is way under spec for the current rating and fail often. Iím looking to replace them with a 3-5A diode that will fit onto the board. Any suggestions?
    I have had a few people recommend using a 10A bridge rectifier mounted to the chassis between the PT and circuit board, but my customer would prefer to keep the cost down so Iím looking for other options. Thanks!!
    Member Jon Snell's Avatar
    Aug 2015
    Jurasic Coast, England
    168
    Received: 55/0
    Given: 7/0
    5
    The rectifier gets hot and fails, a set of 3A 1n540*, (* meaning any of the range), mounted off the board so there is at least an air space between the diodes and the pcb. I usually form a spring shape with the leads, that helps to dissipate the heat.
    Replace the spades with whatever you think but I would recommend, replacing the tags and soldering the wires to them. Something else that is less likely to fail in the future.)
    Support for Fender, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
    Nov 2018
    235
    Received: 29/0
    Given: 5/0
    2
    Quote Originally Posted by Jon Snell View Post
    Can you clarify what you mean by replacing the tags? Do you mean soldering directly to the connector?
    I really like the spring shape idea. Do you have any pics? Interested to know how you get a tight coil on the component leg
    Aug 2015
    168
    Received: 55/0
    Given: 7/0
    5
    Yes, remove the connector on the wire end and solder directly to the tag. I have never had them burn out though.
    I get a component and wrap the leg around a small phillips screwdriver blade.
    I then adjust the turns to the required shape to fit the pcb holes or tag strip.
    1 Not allowed! Not allowed!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,477
    Received: 2,537/7
    57
    The 6vAC heater connectors are under spec and burn up. SOlder the wires directly.
    I never encountered rectifier failure, the load on each supply is just 150ma for tube heaters. Add a few milliamps for the couple relays.
    Nov 2018
    235
    Received: 29/0
    Given: 5/0
    2
    Cool, Iím still trying to figure out if turrets will be the best way, since thereís two pads for each terminal I may drill out one of them on each transformer side and route the wires through Marshall style for strain relief and solder directly through to the pad. Maybe itís not needed. I donít love the idea of soldering directly to the terminals though!
    Nov 2018
    235
    Received: 29/0
    Given: 5/0
    2
    Just ordered some in5408ís for the DC heater supply. I havenít gotten one where the rectifier burnt up but there are plenty of threads with issues like that, so Iím just gonna go ahead and do it, itís less time for me to do it while itís here than to come back later when itís smoked
    Aug 2015
    168
    Received: 55/0
    Given: 7/0
    5
    I have had four in for repair with destroyed diodes and bad contacts on the spade connectors but many more that didn't fail. I replaced the diodes and connectors anyway as I was in there replacing the swollen capacitors, belt and braces.
    Mounting them away from the board also helps and you will never see that amplifier in again for the same fault.
    A 1N4002 is fine but the 1N540* series is more reliable.
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,352/1
    Given: 1,337/2
    8
    With 1N400x diodes in power applications always use the glass-passivated (GP) types. These have much better long time reliability/lower failure rates (FIT values) than the cheaper standard versions.
    In one of my former products (a kind of SMPS) the calculated mean time to failure (MTTF) could be increased by a factor 10 using GP type 1N4007 rectifiers.
    3 Not allowed! Not allowed!
    - Own Opinions Only -
    Aug 2015
    168
    Received: 55/0
    Given: 7/0
    5
    Nothing wrong with soldering to the terminals, as long as the pad on the pcboard has not been damaged.
    It is the poor crimping on the connector that is the problem so new connectors will fix it as well, if you have a professional crimp tool that has a force of a couple of tons that is.
    Jul 2008
    Tulsa, Ok.
    207
    Received: 2/0
    12
    I just had a 6505+ 112 combo on the bench with a bad DC heater circuit... it was a shot rectifier diode...1N4002 diodes I think....I replaced them with 1N4004 diodes and I clipped off the spade space connectors and hard soldered them to the board....no worries now...
  12. #12
    Nov 2018
    235
    Received: 29/0
    Given: 5/0
    2
    I donít have a crimp tool but I should! The stuff I have crimped I did with rounded needle nose pliers strategically. Iíd probably be more confident that I can crimp something better than peavey if I had a better tool 🤔
    Anyway, still waiting on these diodes since itís the end times, Iím glad I could even get them. Good to know the DC heater rectifier is a persistent issue and that IN5408 was the right way to go. I was tempted to find a 10A diode but thereís probably no way to fit them on the board. Would have to be a bridge rectifier mounted to the chassis between the transformer and circuit board.
    Peavey had the right idea with their Classic 212 models, those things never smoke all on their own. PTP output section and everything. Really nice stuff.
  13. #13
    May 2010
    Sioux Falls, SD
    6,927
    Received: 1,694/2
    Given: 1,219/1
    18
    If you don't have a crimp tool, it also works to flow solder into the crimp connector around the wire. I'll often do that, even after crimping, for a little insurance.
    2 Not allowed! Not allowed!
    ďYeah, well, you know, thatís just, like, your opinion, man.Ē
  14. #14
    Nov 2018
    235
    Received: 29/0
    Given: 5/0
    2
    After handwiring everything in, and replacing the DCH rectifier with IN5408, to my amazement: the AC heater supply is still intermittent. Iím reading 3.5v on one lead, 0v on the other. When it does come on, I can see 7v on the winding that is supplying voltage and 0 on the other. A bit confused by this. I guess the PT is faulty? Whatís a way to know for sure? Reading .4ohms between the leads of the AC heater, and the rest of the circuit looks normal. Not getting AC voltage of any kind to either output tubes or the PI, which probably means no current
  15. #15
    Member HaroldBrooks's Avatar
    Mar 2019
    337
    Received: 184/0
    Given: 1,013/0
    2
    Hi Helmoltz,
    Can you explain to me the difference between glass-passivated (GP) types and any other 1N4007 diodes ? How do I spot the differences when someone is selling them over the internet ?
    I didn't realize there was any difference, but I want to be on the lookout for the "Better" type next time I purchase them.
    Thanks for the help.
  16. #16
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,352/1
    Given: 1,337/2
    8
    Only buy from a reputable distributor.They typically specify glass-passivated types and provide the datasheet e.g.:
    https://www2.mouser.com/ProductDetai...roP3EzTqv8Nw==
    https://www2.mouser.com/datasheet/2/...gp-1768051.pdf
    Often the letters GP are silk screened on the plastic case.
  17. #17
    33,477
    Received: 2,537/7
    57
    Well the rectifiers would have no effect on the AC heater supply.
    WHERE are you measuring that voltage? Measure it right on the wires from the transformer. Not on the tube sockets or the circuit board, right on the wires themselves. Transformers do fail, but VERY rarely. Far more likely the 10A fuse HOLDER has gone intermittent.
    Also you need to read voltage from one wire to the other. NOT from each wire to ground.
  18. #18
    Nov 2018
    235
    Received: 29/0
    Given: 5/0
    2
    It may have been a bad connection in the circuit board internally. I disconnected the leads and wired them directly to the tube socket pins and it has worked perfectly without fail. The problem has ONLY been in the AC heater supply. Probably was this problem to begin with but can you elaborate a little more about why to test like that? Maybe thereís something about how those windings work that I donít understand..
  19. #19
    Nov 2018
    235
    Received: 29/0
    Given: 5/0
    2
    I was testing them on the pads that the leads were soldered to. I got a different result after disconnecting them
  20. #20
    33,477
    Received: 2,537/7
    57
    Not sure where I left you, but unlike most amps, there is no ground reference to the heaters, like a center tap. Thus measurements to ground from each wire are meaningless. As to why I specify the wires, when we measure at the tubes, we have not only the transformer, but also the fuse and holder plus all the interconnecting wires. The ribbon from main board to the power board is notorious for burning connector pins.
    You were suspicious of your transformer, so by measuring directly on the transformer wires, we eliminate all those other potential problem areas. If the voltage is still iffy when measured direct, then teh tranny is suspect. If the voltage at the wires is OK and stable, then the other stuff must be the problem.
  21. #21
    Nov 2018
    235
    Received: 29/0
    Given: 5/0
    2
    I see what you mean. The 6505+ Iím working on is one of the newer models. No molex no fuse on the AC heater line and there is a reference to ground with 2 100R to ground at the end of the heater line.
    https://www.thetubestore.com/lib/the...-Schematic.pdf
  22. #22
    33,477
    Received: 2,537/7
    57
    Ah. Well your first post said you had a 6505+. The schematic you just posted is for a 6505+ 112. They are not the same amp.
    So which do you have, the 6505+ head or the 6505+ 112 combo. Then we can all be on the same page.
  23. #23
    May 2010
    Sioux Falls, SD
    6,927
    Received: 1,694/2
    Given: 1,219/1
    18
    ......You were suspicious of your transformer, so by measuring directly on the transformer wires, we eliminate all those other potential problem areas. If the voltage is still iffy when measured direct, then teh tranny is suspect. If the voltage at the wires is OK and stable, then the other stuff must be the problem.
    Regardless of head or combo, ^^^^^ this is still good advice and reason to check right at the transformer wires.
  24. #24
    33,477
    Received: 2,537/7
    57
    Yes, troubleshooting procedure doesn't change, just model-specific details need to be dealt with.
  25. #25
    Nov 2018
    235
    Received: 29/0
    Given: 5/0
    2
    Sorry Enzo! I have a Peavey 6505+ 112, I didnít realize they were different or else I would have specified. That is very good advice, the amp is working perfectly after wiring the leads directly to the tube pins.
  26. #26
    33,477
    Received: 2,537/7
    57
    Yes, they are substantially different.
  27. #27
    Mar 2019
    337
    Received: 184/0
    Given: 1,013/0
    2
    Good, I bought the last batch from Mouser ! Thanks.
    Sorry Steelwitch, this ended up being a short hijack of the post, I am out.
  28. #28
    Aug 2015
    168
    Received: 55/0
    Given: 7/0
    5
    Measure the 32volts AC for the heater wiring from the transformer and follow it up to your bridge rectifier. If it is there when your heaters go out, it is not the transformer. Revert to DC and measure the DC from the bridge rectifier, follow it through to the valve bases.
    R47 and R49 can get dry joints on them and they feed the heaters for.
    I am assuming you mean the FIL 12AX7 heaters and don't forget they get their heaters from the +-24volt supply!
    Or do you mean the Power Valve heaters?
    Yes the 6505plus it totally different.
    Check the AC supply on your bridge rectifier in fault condition, assuming you mean when faulty V1 - V4 go out.
    Check R82 0.68 5W for dry joints and follow the DC path to the valve holders pins 4/5 and 9.
    Where is the break?
    Last edited by Jon Snell; 04-14-2020 at 09:12 AM. Reason: Wrong information given out.
  29. #29
    33,477
    Received: 2,537/7
    57
    It is his AC heaters going out.
  30. #30
    Aug 2015
    168
    Received: 55/0
    Given: 7/0
    5
    Now I have found out that it is the 6505+ 112 Let's try again.
    Assuming you mean the 12AX7 valves, V1 - V4.
    Under fault conditions measure the 6.3v AC supply on the transformer wires, trace the voltage to the bridge rectifier. If all good, check for DC out of your bridge rectifier and through R82 a 0.68 Ohm resistor. Follow the voltage from the negative end of C83 up to pin9 of the valves V1 - V4.
    If OK check the positive side of C83 to pins 4&5 of the valves.
    Finally check across pins 4&5 and 9 of each valve.
    From that method it will be obvious where your fault is.
    If A/C heaters, (output valves etc) there will be a dry joint.
    Last edited by Jon Snell; 04-14-2020 at 11:18 AM. Reason: More info supplied and more info given.
  31. #31
    Aug 2015
    168
    Received: 55/0
    Given: 7/0
    5
    The A/C heaters are the main output valves!
    Why change the bridge rectifier?
    It will be a bad connection.
    I give up.
  32. #32
    Feb 2010
    12,645
    Received: 2,186/24
    Given: 5,514/11
    24
    I give up.
    As far as I can tell, the amp was fixed in post #18. The rest was academic. The bridge issue was ruled out earlier.
    If you don't have the 'linear mode' selected for thread viewing, it can really mess up the order of the posts. Upper right area at top of page, button labelled 'display'. Set for 'linear' and you will see the posts in chronological order.
  1. Peavey Triple X Head Heater (FILA, FILB) Voltage Question
    By marcumh in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-06-2012, 06:37 AM
  2. Peavey 6505 Problems
    By Davidock in forum Guitar Amps
    Last Post: 03-04-2011, 05:40 PM
  3. Peavey 6505+ schematics
    By Anodyne Audio in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-20-2010, 07:00 AM
  4. Peavey 6505 Plus on tour
    By rf7 in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-26-2008, 12:49 PM
  5. Peavey 6505+ problem
    By Conqueror in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-19-2007, 12:32 AM
