Hard time finding a replacement transistor from part #
  • Hard time finding a replacement transistor from part #
    I had a hard time finding a replacement transistor part for my washer MCU board. I cant seem to any info on the part # I decided to check on here . The part says KOGNGO GBF513 on it. Thanks for any info
    Are you sure it’s a transistor and not an SCR or a TRIAC or something? If it’s an in house number identifying a replacement may be difficult. Normally appliances are “board level” servicing. Plug the model number into a appliance parts store website and search for the board. It may be cost less than your time. You will not find a schematic.. just a block diagram..
      Could this be it?
      https://pdf1.alldatasheet.co.kr/data.../datasheet.pdf
        Here it is, those G's are 6's. It's an IGBT
        https://music-electronics-forum.com/...1&d=1586126654
