Results 1 to 20 of 20
Thread: Framus Mid Control - What can I do with a DPDT?
    Jan 2010
    93
    Received: 9/0
    Given: 4/0
    11
    Hey,
    I am building a small top unit that will only have 3 controls, a gain, tone, and master volume knob. I've got a 250k push-pull pot with a DPDT switch that I want to incorporate as the tone control. Now I am looking for something interesting to do with the DPDT switch.
    I have used the Framus mid control, as described here: http://chasingtone.com/yourguitaramp...tone-controls/ before, with adjusted values (1M pot, 100k resistor, 1n caps) to not load the signal too much:
    Now I would use it with 5n caps, 25k resistor, and 250k pot. If that loads down my signal too much, I can install an IRF-820 MOSFET cathode follower before the tone stack.
    My first idea, which I would really like, is to use the DPDT switch to change the whole tone stack to a Big Muff Pi control (you can also see it on the site linked above):
    What I really like about the Framus mid control is that you can dial in that fender tone on pretty much any guitar, but also get some broader and rawer sounds with the mids not attenuated so much. I figured the Big Muff Pi control would give me something else, with more emphasis on the T/B ratio. Maybe someone got an idea how else the Framus mid control can be mixed up with a DPDT switch if my plan does not work? Maybe some kind of control for mostly the bass, with a fixed high/mid range?
    TL,DR:
    Is this going to effectively switch between the BMP and Framus mid control on a single 250k pot? I put in some Red color to See what happens, when the Framus circuit is activated.
    Any feedback and ideas welcome, and happy building to you all! Cheers, Julius
    Jan 2010
    93
    Received: 9/0
    Given: 4/0
    11
    I See that with the proposed way of switching, I will still have effectively a 10n capacitance across the outside Lugs of the 250k pot when the BMP tone stack is activated. Can someone help me understand what that is going to do?
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    16,439
    Received: 3,075/5
    Given: 3,712/0
    32
    I'm not really sure what your question is.?. But I modeled your circuits on spice. Each shown with the switch elements removed for clarity. Traces are with pot at full, pot at zero and pot at half resistance (since I don't know your pot taper). Honestly, I don't see where the "Fender" tone is for these circuits. Neither looks to be very dynamic with one acting primarily as a weak Big Muff control and the other as a very weak mid control. But they do seem to be relatively low loss as you intended.
ID:	57921   Click image for larger version.
    2 Not allowed! Not allowed!
    Jan 2010
    93
    Received: 9/0
    Given: 4/0
    11
    Thanks for These models! I want to use the dpdt switch to change what my 250k pot does. On one setting, it's supposed to be the big muff pi tone circuit, on the other setting it is supposed to be the framus mid control. I have used the framus mid control before, with 1M pot, 1n caps and a 100k resistor. So I would like to switch between a mid scoop and the T/B thing the big muff pi circuit supposedly does.
    My question therefore is, with my switching setup, whats the effect the ground lifted framus circuit still has on the signal... I think your Simulation Shows that I am doing something wrong.
    Or, maybe I should ask a different question then: I must work out how to increase the responsiveness of these Circuits given that I can only use the 250k pot and dpdt switching.
    May 2007
    62
    Received: 1/0
    14
    Not sure if it's helpful to you but there is a Framus mid control tab @ the online tone-stack-calculator: https://www.guitarscience.net/tsc/framus.htm
    1 Not allowed! Not allowed!
    Jan 2010
    93
    Received: 9/0
    Given: 4/0
    11
    Thanks to both of you! I went ahead and learned how to use ltspice to do the simulations. That is a really nice tool. I compared my result to the online thing, and it checks out:
    So now I will play around with my larger circuit above and see if I can make it work...
    It is still my goal to be able to turn the framus mid control into something very different with the DPDT switch. But the thing is the ground-lift doesnt seem to detach it from my circuit enough.
    Jan 2010
    93
    Received: 9/0
    Given: 4/0
    11
    I love this software. Thanks again for pointing me there!
    So here is what I am getting when I simulate...it looks a bit different from your output:
    I made 2 simulations, one with the switch lifting the ground of the Framus circuit and disconnecting that part from the input, the other one is lifting the ground on the Big Muff Pi circuit and disconnecting that respective input.
    I think I just need to find a way to avoid the strong treble attenuation in the BMP circuit. Will try out some more values now...
    Jan 2010
    93
    Received: 9/0
    Given: 4/0
    11
    Ok, I am getting closer!
    What do you think in terms of responsiveness in this example? I have a bit less maximum scoop and the range is wider on the Framus style mid control. I tried to maximize the effect of both controls without changing the shape too much.
    Do you think I get a fairly decent range and combinations on the BMP side of things? I would set the midrange focus a bit higher but it doesnt work out because then the Framus circuit scoop gets really wide and moves to the wrong range.
    I think I will try this out on the workbench...any words of advice in terms of usability?
    I figured that since I never maxed out the Framus mid control I have anyway, a little less attenuation compared to the original means I can use more range of the pot for precise settings.
    May 2007
    pacific north west
    16,439
    Received: 3,075/5
    Given: 3,712/0
    32
    That's looking pretty good. More range, less loss. You win. I might fudge around and try to get the Framus to where there's less bass cut and still keep the adjustment range you have now. It's a tall order, but there's nothing like a cad program for working things out.
    I think it's interesting that your initial run got results different from mine. I assumed a typical 12ax7 gain stage and plugged in a 38k resistance for my voltage source. You have a different spice program from mine but I think you plugged in 12k? Anyway... My sims show a pronounced HF loss compared to yours.
    Jan 2010
    93
    Received: 9/0
    Given: 4/0
    11
    Ahhh...then I think I was not properly taking into account the source impedance!
    For the simulation of the signal, I just used a 1 V AC source. Would I have to add the value as the series resistance of that voltage source? Because when I add 36k to that, I get a pronounced attenuation of treble frequencies as well. It's under "parasitic properties" of the voltage source settings in my program:
    BUT - I've still got my IRF-820 at hand, and if I plug in a really low series resistance value there, like 1k, my simulation is still close to the previous result:
    I've tried a lot of combinations, but I think this is the best I can do. If I get the mid scoop more narrow in the correct frequency range, it screws up the BMP part. I will now try out this compromise and see how it sounds.
    May 2007
    pacific north west
    16,439
    Received: 3,075/5
    Given: 3,712/0
    32
    Or, if this is a build as yet to happen, you could just feed the tone stack from a cathode follower. Output impedance about 600R according to Duncan TSC. I'm not a silicootie hater or anything. But cathode followers "look" more eloquent in a design and don't require any additional voltage source considerations.
  12. #12
    Jan 2010
    93
    Received: 9/0
    Given: 4/0
    11
    I have actually already built it, all parts except some chassis work and the tone circuit. But you are right on with the cathode follower!
    I tested it - first straight off the plate of my 12ax7 first gain stage - and unsurprisingly, it was too dull. Just a treble cut on both controls. Then I installed the cathode follower (using an IRF-820, since this is a small and tight build in a tiny chassis, with just 4 tubes: 12ax7, 6au6, EL-84 x 2). And man, it works out nicely. Two different options, all on one knob. Pull out the knob, and you got from full flat signal to a nice mid scoop. Push it in and you have a choice of bass/treb seasaw kind of thing going. All in one pot, nothing to fiddle too much with. Although I'm yet to test it on high volumes, since its already past midnight here in Germany, it seems to work really well. I think I am actually able to use the whole range of the knob on both settings. I will report how it goes tomorrow when I test it on higher volumes.
    Just in case anyone is interested, this is the final circuit I went with:
    If you do build it, it is essential you do it after a cathode follower - it wont work as intended otherwise. I also have a thread going with the full circuit where I was contemplating the use of the IRF-820, I will upload the full schematic there once this is done.
  13. #13
    Member walkman's Avatar
    Jan 2007
    Melbourne
    199
    Received: 10/0
    Given: 2/0
    14
    Iíve used the framus mid control on several amps now and with 1M and 1n and 100k. When the control is at zero rotation there is a slight bass and mid boost. It would be great to get some bass cut at zero rotation. Any ideas?
  14. #14
    Jan 2010
    93
    Received: 9/0
    Given: 4/0
    11
    Walkman, I played around with some values but I cant think of a way how you could achieve your goal. It's easy to add some attenuation for the lower frequencies in general, I also did that to my circuit. But only on zero rotation? I have no idea.
    I tweaked the circuit a little more after testing it on louder volumes. There was not enough control for my taste, so I added a couple of components to cut out some bass and increase the attenuation. I increased the amount of attenuation in both variants. I'm getting closer to what I was having in mind.
  15. #15
    Jan 2007
    Melbourne
    199
    Received: 10/0
    Given: 2/0
    14
    I like the look of that lower plot... though Iím not really making sense of your circuit.
    Can you put it in context in a full schematic
    I had been thinking of a stacked pot with a bass cut wired in reverse ... but that may be too lossy
  16. #16
    Jan 2010
    93
    Received: 9/0
    Given: 4/0
    11
    This is the full schematic. The tone circuit as shown in the ltspice diagram above is inserted instead of the single mid control circuit that is still shown in this drawing. I havent updated it yet.
    Ignore the Red line. The tone circuit is inserted on a 250k push pull pot between the right end of the Red line and the volume pot.
  17. #17
    Jan 2010
    93
    Received: 9/0
    Given: 4/0
    11
    I have made another derivative of the Framus mid control, maybe this one is interesting for you @walkman?
    A 100k resistor is added to the mid cut circuit (R1 in the schematic). The DPDT switch is wired so it selects a different coupling cap (47n vs 1n) and jumpers R1 when the 47n cap is selected to give the standard mid cut control. This changes the control to be a both mid and high cut, but due to the higher overall attenuation of bass frequencies it gives you (relatively) a control over how loud the bass is compared to the rest of the frequencies.
    I wired the switch so that the 47n cap is always left in the circuit, to prevent high voltage DC on the switch. The 1n cap is simply switched in series AFTER the 47n cap. In series, the capacitance is still close to 1n when it is switched in (a little bit lower), but the 47n cap always blocks the dc from the switch for when the 1n is bypassed.
    I thought this up for an amp of mine where I just didnt have the control over the relative level of treble and bass that I wanted, so I added the DPDT switch to be able to change the bass response. At the same time, the pot now also controls the treble frequencies. Overall, this is a more lossy control now, so you get a drop in volume when you use the 1n/100k setting. I like it, because it gives a different flavor to my amp at the flick of the DPDT switch. I especially like this for lower level practicing volumes in my room.
    I use this in a 6V6, sort of 5f11 style amplifier right after the first gain stage.
  18. #18
    Dec 2009
    Devon, UK
    3,811
    Received: 941/1
    Given: 693/1
    14
    Good to see you getting to grip with LtSpice so well
    Can I make a suggestion that I think will help to communicate your idea? Create sub circuits for the potentiometer and switch. You can then parameterize them and drop them into your schematic. I think it makes it easier to simulate and to see what is intended. Attached all files as zip.
    fmc.zip
    3 Not allowed! Not allowed!
  19. #19
    Jan 2007
    Melbourne
    199
    Received: 10/0
    Given: 2/0
    14
    That last set of curves looks good as well.... I’d really like to try it out. I have a build in mind and hope fully can get this into it, and let you know.
  20. #20
    Junior Member
    Jun 2019
    12
    Received: 9/0
    Given: 11/0
    0
    In case you're interested, I've played with a similar mid control circuit I found in Merlin's book (of course) that has an adjustable center frequency. I found it pretty useful once you tune the sweep properly - gives you an approximation of some Fender and Marshall mid sounds. Note R1+R2 comprise a 1M pot, and R4+R5 comprise a 100K pot:
Name:	Screen Shot 2020-05-25 at 9.58.54 PM.png
  1. Additional mid control - with drawing, ala Framus Cobra
    By Guitarist in forum Mods & Tweaks
    Last Post: 11-25-2011, 03:05 AM
  2. I need help with my Framus Cobra, it's buzzing weird
    By paintyoursky in forum Guitar Amps
    Last Post: 04-04-2010, 05:14 PM
  3. Framus Dragon Schematic
    By kylendm in forum Schematic Requests
    Last Post: 10-11-2009, 12:12 AM
  4. question on a Framus Dragon Amp 100watt
    By titan7 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-16-2008, 07:07 PM
  5. framus ruby riot help
    By nick in forum Guitar Amps
    Last Post: 02-14-2008, 11:30 PM
