Extending primary leads on OT?
    Originally posted by glebert View Post
    This is all really helpful to me. My splice game has always been weak because I would do it so infrequently and was never shown different ways to splice. I definitely used the term pigtail improperly above because to me the pigtail was the section of wire that was added, not the wire joint itself.
    I would think, semantically, that if the added wire is the 'pigtail', then the splice used to join the pigtail to the rest of the wire would be the 'pigtail splice'.
      Well I learned something too.
      Pig-tail splice is also known as rat-tail splice, like this: https://en.wikipedia.org/wiki/Rat-tail_splice
        Trying to "describe" a splice in my post above seemed clumsy. I found a couple of examples on line and grabbed the photo's from one. Can't seem to find a name for this splice but I think the term "inline splice" was used a couple of times.
          An inline splice just means it is more or less just an extension of the wire in linear shape. Which your is. I would call a Western Union splice inline as well. As opposed to a pigtail where two wires are placed parallel and twisted together.
            Update on this and two more silly questions. Extended the wire, cased it in heat shrink, and did a test with only two power tubes and a 16 ohm speaker and it worked good. Did have to reverse the speaker leads to prevent feedback oscillation.
            Question 1: Is this transformer supposed to bolt down flush to the chassis, ie remove the nuts that are shown in the above photo and use those to secure it, or should those nuts sit on top of the chassis. Note: turns out the transformer is not really from a SVT CL, which stood up vertical on brackets, but for an SVT VR or maybe SVT II non-Pro, where they go down into the chassis (this actually is better for me btw). I would think sitting down flush would be better for strength and thermal, I just always feel weird unscrewing nuts covered in varnish.
            Question 2: This transformer is a bit bigger than the previous one, so sits a little closer to the 6550 power tubes, with maybe 3/4" clearance to the closest tube. Should I put a heat shield in that gap, or is it OK? I'm planning on increasing the size of the fan.
            TIA,
            Greg
              It's an OT which doesn't get very hot by itself. And because of its mass, the tube's heat radiation won't heat it up significantly. So no need for a heat shield.
                No, do not remove the existing nuts that hold it together.
