Help reading the scale on my Heathkit IG-18 Signal Generator
You set the amplitude control for max. voltage the range can produce. It will be a multiple of 3 or 10. Then you use the appropriate scale (3 or 10) adjusting the decimal place as required.
So, for example, on the .3V range, you would read the top scale (3), and a '2' reading would be .2VOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostYou set the amplitude control for max. voltage the range can produce. It will be a multiple of 3 or 10. Then you use the appropriate scale (3 or 10) adjusting the decimal place as required.
Originally posted by Enzo View PostI tend to use 100Hz for the same reason. But way more than sine waves, I just use music - like from a CD player.
And yes, these lower frequencies are a lot easier on the ears.This isn't the future I signed up for.
Originally posted by g1 View PostI've been using 400Hz forever, mostly I find it much less annoying than 1K.
Regardless, I still use it as a default for signal testingIf I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Originally posted by SoulFetish View PostIkHz make mathematical sense as a mid band freq., but it is NOT what you'd consider mids if you listen to it.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
