Capacitor Replacement Quick Question
  • Capacitor Replacement Quick Question
    Working on a Marshall Preamp , and I'm replacing all capacitors , regarding the small ceramic ones , some that I'm mounting have very low Volts (as originally designed) and others have very high voltage [1KV,2KV & 3KV] -
    Question is: is it dangerous or risky to mix up low voltage caps with high voltage ones, and is it safe at all to replace low V ceramic caps with very high V ones?
    Yes it's safe but they are often a little larger. It's like unnecssary to replace ALL the caps. Usually just the electrolytics as they do have the shortest life. Wax/paper ones in very old equipment are troublesome. Ceramic, film and mica are usually very reliable.
      Ok thanks for the lightning answer, I was unsure because I heard that replacing a 25V cap with a 3KV one was very dangerous , or that having low caps in series with very high V ones was a no no - I just knew that it's best not to screw around with tantalum caps , thanks man
        Voltage rating is a safety thing. Like weight rating on a step ladder. If you weigh 300 pounds, don't buy a ladder rated for 200 pounds. On the other hand if you weigh a 150 pounds it won't hurt anything to buy a ladder rated for 300 pounds.
          Except when you want to carry more than 150 pounds up that ladder in addition to your own weight. Unless those pounds happen to be British currency. In which case 150 pounds doesn't weight 150 pounds
            I'd give you a ton of credit, if that had made an ounce of sense. But it was a sterling example.
