and now changed Q4 , Q5, Q6 and Q10.
Most of SS amp repair can be done without any load. DCV at the output without load should be close to zero. The voltage drops across R3 and R4 should be identical and preferably lie between 2mv to 5mv. Any transistor with a base-emitter voltage below 0.45V isn't properly conducting. Doesn't mean it's bad, though.
Also check the remaining electrolytics (like C13, C16) for leakage.
Is there a service manual that specifies the biasing procedure?
Actually I'm hoping someone more experienced in SS amp repair than me will take over. I'm sure there are more methodic and efficient strategies than mine.
