Power supply - sanity check
  • Power supply - sanity check
    I'm in the process of designing a power supply for an amp. Most parts are standard stuff, but I have some questions as I'm adding circuitry I normally wouldn't.
    The parallel blue lines are there to show the how the taps are connected internally on the secondary side.
Name:	Power supply.png
    I would appreciate some pointers etc on this design, before I test it.
    Cheers!
    Relay supply looks odd. Why are you using stacked caps? I assume this is low voltage.
    Also you should probably use much higher value caps for a relay supply. Something like 500 - 2000uF seems more reasonable.
    LED supply also wierd. Why stacked caps?
