I have a replacement power transformer for a 50W Marshall that I'm planning to use for a completely different project. It's rated 690VCT/150mA and 6.3V/5A, are these "conservative" ratings? The circuit will not draw more than 150mA B+, probably closer to 100mA, but I need 5.5A for the heaters. The wire gauge on the heater winding certainly looks up to the task, but will a 10% increase be safe? How much leeway do I have?
Marshall PT current ratings
Originally posted by Roffe View PostI have a replacement power transformer for a 50W Marshall
But how are you drawing that much filament current? The way I count you'll have a maximum of 3A for the power tubes and preamp tubes only draw 300mA @ 6.3V. At 5A you have enough spec left over for 6.6 preamp tubes. Let's call it 7 'cause, ya know. So that would seem like plenty."Take two placebos, works twice as well." Enzo
I think it's the "new" style (JCM800-type) transformer. I'm building Pete Millett's low-mu preamp, so the heater winding will power a 6AS7/6080 tube that draws 2.5A, in addition to two EL34s. I think I'll just go for it and keep an eye on the temperature. I do have an extra 6.3V/3A filament transformer in case this doesn't work out, but I'd really like to save some space...Last edited by Roffe; 04-24-2020, 11:30 PM.
If you're building anyway, just power it up with the Marshall PT and see what you have for filament voltage. If the filament winding drops way below 6.3V, you'll know it's being stressed too much."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View PostIf you're building anyway, just power it up with the Marshall PT and see what you have for filament voltage. If the filament winding drops way below 6.3V, you'll know it's being stressed too much."Take two placebos, works twice as well." Enzo
Originally posted by Enzo View PostAnd a 5A rating means the thing can sit there making 5A all day, so I'd wager the extra 10% won't kill it.
resistance-method-explained1.pdfLogic is an organized way of going wrong with confidence
- Likes 1
Originally posted by nevetslab View Postif you have a DMM that can measure 10 mOhms."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostYep. If you were Helmholtz or Juan you'd probably even calculate the wire gauge using the winding resistance and the voltage drop figures Indeed The Dude has it. If the wire gauge is small and that 5A spec is a tight ceiling you'll probably get a filament voltage below spec. Otherwise I'd bet you're alright.Last edited by Roffe; 04-25-2020, 07:36 AM.
Hammond replacement for 50W JCM800:
https://www.hammfg.com/files/parts/pdf/290GX.pdf
Note max. heater rating of 5.43A.
PT specified in the project schematic:
https://www.hammfg.com/files/parts/pdf/270FX.pdf
Note 5A heater rating.- Own Opinions Only -
Originally posted by Roffe View PostEven better, I measured the wire gauge I took off the end bells when I painted them and got access with my calipers. It’s about 1.65 sq.mm (around 15 awg). That should be enough for over 6A if I’m reading things right?"Take two placebos, works twice as well." Enzo
Originally posted by Helmholtz View PostWhere do you get the 5V heater voltage for the tube rectifier?
I have a separate 5V filament transformer for the rectifier.
I think you can use your PT provided it runs cooler than in the original Marshall amp.
The main safety parameter (apart from hipot testing) for a PT is wire temperature. The method described by nevetslab gives an average temperature increase for the whole winding. But it's actually the hot spot temperature that matters. As inner layers will have a higher temperature some extra safety margin has to be added.
In my company we used specially prepared transformer samples with buried thermocouples for evaluation/certification.- Own Opinions Only -
Originally posted by Helmholtz View PostBut it's actually the hot spot temperature that matters. As inner layers will have a higher temperature some extra safety margin has to be added.
In my company we used specially prepared transformer samples with buried thermocouples for evaluation/certification.Logic is an organized way of going wrong with confidence
