It looks like from the pictures that this guitar had the cavity shielded. I don’t think that scheme is stock.
Restoring 70s STRAT low pickup volume
In vintage strats the tone control does not work on the bridge PU.
I am pretty sure your middle and neck PUs have broken coils. That's why they read open on the meter. You still geat some thin sound because of the capacitive coupling between the disrupted winding parts. Had the same problem with my '68 strat.- Own Opinions Only -
I think the verdict is in: open coils on mid & neck. You can choose to have them rewound. Or buy new - or used. 78-79 isn't in the time span where folks practically worship the pickups. If it was my guitar, I'd select a new set from a reputable builder. Maybe one of the guys here on MEF. Or Seymour Duncan, Lindy Fralin, etc. The pickups Fender has to offer should not be neglected. Overall, plenty of good choices. You could throw a dart, hit any of 'em, and come up with good pickups. Choose to rewind? Once again there's an excellent choice of MEFsters right here that could do it, or you could send 'em off to Lindy who has an excellent reputation. Might opt to send all 3 so he can create a balanced set.
What I recommend to my customers, when it comes to buying pickups, speakers too, is listen to live bands. If you hear something that grabs your ears in the right place, find out what it is & get that. These days when live shows are all on hold, either you have to use your memory, or hope you can get some idea from recordings as to what you'd like. Personally, I've always been a fan of Robin Trower. He uses a mixed kit of Fender pickups, one's a Texas Special, I don't know the others offhand. But there's a YT video interview where he explains it all. There may be some Strat player whose sound you like & can find out thru YT or other means just what they've got in theirs.This isn't the future I signed up for.
Could you please update your profile for your location?
When it comes to parts and having things worked on, it makes it easier for us all to help you, if we know where you are?
Thanks,
TLast edited by big_teee; 04-30-2020, 07:06 AM."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Thanks for the location update.
If you were US stateside I would offer to rewind.
You need to find someone in EU, or attempt to rewird them yourself.
The reason for the low output, is probably this.
The coil start lead is against the magnet, moisture corrosion will eat the wire up at the start lead, making it non grounded.
The output is connected to the finish lead, and the signal goes around the whole coil without terminating to ground.
You get some sound and signal, but without the ground, no full signal!
That is a pretty common thing with old fender single coil pickups.
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
With the pickup out on the table, inspect the eyelets.
The start lead should have the black wire soldered to it.
The finish lead should have the white or yellow wire soldered to it.
The start wire will go from the eyelet under the coil, to the magnets.
If the finish lead is broke, it is on top, and you can reterminate it.
If the start lead is broke, and resoldering doesn't fix it, then a rewind is in order.
GL,
Before going near the pickups with a solder iron, I'd first check the pickup DCR right at the pickup wires to eliminate the possibility of a bad selector switch."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View PostBefore going near the pickups with a solder iron, I'd first check the pickup DCR right at the pickup wires to eliminate the possibility of a bad selector switch."Take two placebos, works twice as well." Enzo
Not necessarily. Switch contacts can become corroded and have some resistance rather than being a dead short. This will also lower the output level. It could be a few different things. It's certainly worth the couple of minutes spent checking pickup resistance right at the pickup wires to be sure."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View PostIt's certainly worth the couple of minutes spent checking pickup resistance right at the pickup wires to be sure."Take two placebos, works twice as well." Enzo
