I'm after the schematic for a Marshall-built Vox AC15 from the late-90s that I'm trying to remotely diagnose with the owner.
Vox (Marshall) AC15
Thanks. I found it here;
https://drtube.com/en/library/schematics/65-vox-schemas
It's the one listed as AC15 reissue. The drawings and part numbers have the Marshall house-style and the amp internals are very 90s Marshall.
Failing solder joints were a problem on the couple of these I've worked on.
It seems rather misleading to describe this model as a reissueMy band:- http://www.youtube.com/user/RedwingBand
Agreed - on the same basis you could describe any 2xEL84 as an AC15 reissue. I established yesterday that this one had lost it's heater supply and one T4A fuse is open. I've had this particular amp in for repair about 4 years ago and couldn't remember if it had a rectified heater supply as per some 90s Marshalls. Luckily not, so maybe just a fatigued fuse.
Originally posted by Mick Bailey View Postmaybe just a fatigued fuse.
Happy to finally find something as I think that was why it came in the first time, just must have connected again for awhile.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
