With a typical 9v single-rail supply you may have a couple of bypassed 100K Ohm resistors connected to the supply and their node feeding the 4.5v input bias via a 1M Ohm resistor, which effectively sets the input impedance. What is the practical limit to this value? I've used 10M Ohm without problems, but does increasing this to 22M Ohm present any issues in an audio circuit?
TL072 bias resistor/input impedance
The full range bias current is 7nA. For an effective 11Meg source that a 77mV offset that so you'd need the same impedance on the other input.
The full range offset current is 2nA i.e 11mV. Whether that is significant depends on the closed loop gain and whether the output goes to something that is is sensitive to DC offsets
At 25C the numbers are a lot loss and 0.2nA and 0.1nA so if your temperature is stable then 2.2mV and 1.1mV are probably not going to be a problem.
A concern is the introduction of poles by virtue of these large impedances and stray capacitance that could lead to poor HF response or instability.
PS: I wonder at the reason behind this. Is it just for power saving? If so the saving would be tiny compare to the TL071. Better to go for a low power amp amp.Last edited by nickb; 05-14-2020, 09:07 PM.Experience is something you get, just after you really needed it.
Do you have the specs of the disk? What frequency response requirement is specified? How much gain? What is the signal output voltage of the disk?
PS: What I'm trying to get to is what is the lowest acceptable resistance that meets the specs. Anything higher that that is just introducing noise.Last edited by nickb; 05-15-2020, 06:46 PM.Experience is something you get, just after you really needed it.
What is the practical limit to this value? I've used 10M Ohm without problems, but does increasing this to 22M Ohm present any issues in an audio circuit?Education is what you're left with after you have forgotten what you have learned.
Originally posted by Mick Bailey View PostWith a typical 9v single-rail supply you may have a couple of bypassed 100K Ohm resistors connected to the supply and their node feeding the 4.5v input bias via a 1M Ohm resistor, which effectively sets the input impedance. What is the practical limit to this value? I've used 10M Ohm without problems, but does increasing this to 22M Ohm present any issues in an audio circuit?
You can get really high input impedances, but there might be a point where it makes sense to bootstrap the input, or bootstrap a buffered input using a FET.
Originally posted by Mick Bailey View PostI was thinking about where you have an input buffer where the bias network appears in parallel with the source impedance (in this case a piezo disk)
High Impedance Input Stages
For audio, you probably don't need to achieve this level for input impedance, but here is an example of a bootstrapped Jfet buffer as an example.
The disc is unknown and part of a circuit I experimented with a very long time ago. It measures 80pf and is bonded to a thick aluminium disk and encapsulated with epoxy. The entire thing is 18mm diameter, so the actual disk is something like 15mm - quite small. I had it originally blocking a strat trem - fitting between the sustain block and the guitar body. The original circuit was just an opamp buffer followed by a simple fixed EQ. The sound was something I wasn't expecting - it sounded like a metal bodied resonator and when I first plugged it in my Wife said "that sounds just like that Dire Straits song", so I immediately learned Romeo and Juliet. I was just having a tidy up and came across the transducer assembly and just got me thinking what the practical limitation is of a simple opamp buffer with its impedance determined by resistance. I understand bootstrapping - I used this in my Ovation and it works very well.
My question isn't that I need to build a high-Z preamp, but what the practical limitation is for a unity gain non-inverting buffer. I never gave it much thought in the past, but with a buffer does resistance noise become more of an issue than the pickup source noise and general EMI?
Ah, in that case there is a great resource you might be interested in. There’s a website based on the A book written called the ‘physics of the electric guitar‘ (or something like that). The text was written in German originally but much of it’s been translated into English and you can download chapters for free. In any case they dedicate a chapter which deals with Piezo transducers and magnetic pick ups in guitar and stringed instrument applications.
I have it bookmarked but I’m on my phone right now so I’ll grab it, and post it tomorrow. Maybe Helmholtz can chime in on this, as he’s the one who introduced the book snd website to me.
edit: I actually found a PDF of the particular chapter.
Physics of the Electric GuitarCh6Piezoelectric Pickups.pdfLast edited by SoulFetish; 05-16-2020, 08:41 AM.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Originally posted by Mick Bailey View PostThe disc is unknown and part of a circuit I experimented with a very long time ago. It measures 80pf and is bonded to a thick aluminium disk and encapsulated with epoxy. The entire thing is 18mm diameter, so the actual disk is something like 15mm - quite small. I had it originally blocking a strat trem - fitting between the sustain block and the guitar body. The original circuit was just an opamp buffer followed by a simple fixed EQ. The sound was something I wasn't expecting - it sounded like a metal bodied resonator and when I first plugged it in my Wife said "that sounds just like that Dire Straits song", so I immediately learned Romeo and Juliet. I was just having a tidy up and came across the transducer assembly and just got me thinking what the practical limitation is of a simple opamp buffer with its impedance determined by resistance. I understand bootstrapping - I used this in my Ovation and it works very well.
So working it though, to get 40meg you'd practically use 2 x 100meg. Each resistor would produce 180uV of noise the two would be 253uV. Guessing at 100mVRMS for the disk output the signal to noise ratio would be -52dB at low frequencies. Now big input resistors' noise will be in parallel with the disk so the noise will roll off about 40Hz so I don't think that will be a problem unless your amplifer has an unusually good low frequency response. A TL072 is 18nV/rt-hz so that's 2.5uV over a 20Khz bandwith. Small compared to the resistors. Assuming a x1 gain the output voltage offset would be 0.45V over the full temperatue range (very conservative). A fresh 9V battery will give you an output range of 3Vpp i.e 2.55v with a 0.45v offset. So if the output is AC coupled that should not be a problem, but rather depends on how much output you get from the disk and that has not been specified. The TL072 will roll off at 3MHz so that gives some measue of EMI protection but best to screen as much as you can. You could add 1k resistor and a 3n3 cap low pas filter on the output.
All in all it will work but the bootstrapped FET buffer is a much better approach, especially for noise.Experience is something you get, just after you really needed it.
Originally posted by Helmholtz View PostI understood that the 2 biasing resistors were AC bypassed, with a single 10M or 22M resistor between the virtual (4.5V) ground and the opamp's input?
What I'm not understanding is the parallels with a condenser mic input where there can be quite a small source capacitance (as little as 6pf) and large (220M to 5G Ohm) input impedance, set mainly by large value resistors. Why isn't noise a factor with those circuits?
My imagined circuit arrangement of the op amp buffer was two large resistors connected to the non-inverting input and with the inverting input connected to the output. This saves one resistor and one capacitor.Experience is something you get, just after you really needed it.
Originally posted by Helmholtz View PostI think it makes more sense to look the actual S/N ratio and not at equivalent input noise alone. A more efficient source/higher signal voltage will allow for more circuit noise.Experience is something you get, just after you really needed it.
Originally posted by nickb View PostAbsolutely. The problem was the only spec given was 80pf so you have to work with the cards you're dealt
What I meant was, when comparing established preamp circuits for different sources, typical signal voltages also should be taken into account. A stronger source will allow for higher input resistance without getting objectionable output noise because it requires less total gain.- Own Opinions Only -
