Electrolytic caps can have a number of different things wrong with them. DC leakage at working voltage is only one of them.
It's possible for a capacitor to have high ESR or even to look like an open circuit with no DC leakage. Years ago, I had distortion in a HiFi preamp that would only go away when I removed one cap completely from the circuit. It tested OK with the equipment I had back then, but something was wrong with it.
It's not common, but people do occasionally get a bad brand-new capacitor. I have both an ESR meter and and old impedance bridge, plus an old Heathkit Condenser Checker that will check for leakage at full voltage. If you don't have this kind of gear, checking a cap for problems is going to be very difficult. I've gotten into the habit of running some quick checks when I install new caps just to save myself headaches down the road.
And it's going to be pretty much impossible to prove to a vendor that a cap is bad by running crude resistance tests at low voltage.
