"Half Power" switch problem
  • "Half Power" switch problem
    Have a JTM Marshall clone with 2 -KT66 / GZ34 that is popping the Mains fuse . This amp doesnt have a HT fuse. It works great in Triode mode , but when switched to Pentode it fries the mains fuse instantly . Ive swapped out the power tubes and it still blew in Pentode mode.
    this one has 2 , 820 ohm between the switch and grids . Those test good . I cant find any of the pins or switch contacts shorting to ground . Would the rectifier tube have any play in this ? I dont have a spare here . B+ is 474v
    Fired it up with all tubes in on my bulb limiter and B+ is 223v and the bulb doesnt show a problem in either mode .
    Any ideas ?
    Schematic?
      Does the switch do this with ALL power tubes removed?
        Dont have a scem
        .....its a boutique amp.....JTM 45 Bluesbreaker clone ..should be the same besides the preamp as a Marshall....made by Louis Electric
        probably very close to this ---
        https://drtube.com/schematics/fender...-schematic.gif
          no--only with power tubes in...and it wont act up on the bulb limiter
            Did the amp ever work, or is it a new build? In other words, is it possible something could be wired incorrectly?
              The part of the schematic I'm interested in is the half power switch. If there is no schematic, you need to know if it's wired up right, or if it ever worked right, like The Dude mentioned.
                ill have to ask the owner, he bought it used . Not sure if the switch is factory
                I can draw up a diagram here in a minute
                  I agree, g1. Since the amp works in triode mode, presumably with screens connected to plate, I can't think of a reason you would draw more current in pentode mode with screen resistors in circuit and a screen supply. If the screen supply was missing or low in that mode, there would be less current- not more. That is, unless there is a wiring error.
                    crude drawing.....
                      Are you switching pentode/triode mode with the amp running? What is the mains fuse value?
                        Amp off when switching . It came to me with a blown 8 amp...i assume it takes a 3 or 4 amp being a 2 power tube Marshall type ??? so thats what i put in ...a 3a slo blo. Blew that one. Im out of 4a fuses . Popped 2 of the 3A slo-blo .
                        I just tried a 5a fast blo and the amp isnt popping it...either mode . Tried several times . Is this maybe an in-rush current thing ? No standby ....Or it needs a 4 or 5 amp fuse ? The chassis is not labeled (its a $2600 amp...fuse rating not labeled)
                          Originally posted by Valvehead View Post
                          crude drawing.....
                          I assume the line that's common to the unused Pin 6's of the two KT66 power tubes go to a power supply tap on the PCB, probably after a choke where one would usually find the screens being fed from. In the Triode Mode, those 820 ohm resistors connect to the plates of each tube's plate connection, similar to that stated by Enzo, but with the resistors. I don't see anything obvious here, unless the PCB connection is other than what I assumed here. It only works in 'Triode' mode, right?
                            So put the unit on a current meter. What is the mains current draw. Is it a steady highish current just waiting for a "straw that broke the camel's back" to pop a fuse? or is it sitting at a reasonable common lowish reading and spikes hard when switch is thrown.
                            COuld be something about the switch. It may not MEASURE shorted, but it could have a flake of something inside so it arcs in one position. You could take the wires off the switch and either tack in a different switch or just simply tack solder the resistors to the pin 6 wire to hard wire pentode mode. Does it still behave this way?
                              I also wonder where pin 6 goes.
                              Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
                              If you can't fix it, I probably can.
