Tape motor won't turn...
  • Tape motor won't turn...
    ...clockwise, but will turn counter clockwise.
    Unfortunately it needs to run clockwise to move the tape.
    Got a Rexer RTE3000, similar to a Roland Space Echo supposedly.
    motor is getting proper -15 volts, but is not turning.
    I disconnected the wiring to it, reversed the polarity of the voltage and it turns just fine, in the other direction.
    You ever see a motor work in one direction, but not the other?
    I'm going to take it out, take it apart and see what I can do. And/or try and find a replacement.
    Thanks.
    Thanks.
    Some motors reversing polarity changes direction of travel.
    nosaj
    maybe this will offer some insight
    https://medium.com/luos/how-to-stop-...s-7afcbf3dbf1d
      nosaj
      To follow up on this use a current limitied DC power supply and test the motor independantly.
      nosaj
        Yes, I realize changing polarity of a DC motor changes direction.
        Current draw fine, it just won't rotate in the direction it's supposed to.
        The other way, fine.
        Weird.
          Weird.
          Is that with an independant power source suppling the motor?
          nosaj
            If the DC motor has a speed control built in, a lot did and do, if that fails there is a back EMF diode strapped across the control components.
            That is why it runs backwards and not forwards.
            Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
            If you can't fix it, I probably can.
              nosaj
              Yes
              Using a power supply the motor will not spin with -15 v supplied to it as it gets from the unit.
              Switch polarity of power supply and it turns the opposite direction.
              The motor does have two other leads which go to a pot.
                Yes
                The regulator, as I suggested earlier, has failed. Replace the motor or repair the regulator that is internal to the motor, if the pot wires come from the motor casing.
                What size is the shaft and does the spindle come off?
                  Great, I'll see what I can do.
                  Thanks.
