Vacuum Tube Harp Amps!
  • Vacuum Tube Harp Amps!
    I've built a bunch, I'm sure others have too.
    Let's get some threads running here as most stock guitar amps are not that great for a pure greasy, papery, down and dirty harp amp.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
    Ok!
    About >98% of my customers do play guitar but I do voice amps especially for harp when requested.
    As probably mentioned before on various website and Ampage;
    - lower voltages
    - big coupling- and cathodebypass-caps
    - (sometimes) a higher input-Z
    Anyone got some suggestions for modding reïssue Bassman amps (stock speakers) for harp? I've done a couple of blackfaces and tweed deluxes but I'm looking for some harp-ideas for "this beast"
    tia!
    Chris
    Love, peace & loudness,
    Chris
    http://www.CMWamps.com
      Lower voltages and lower gain in the first and second stages.
      Most of my pro player customers like no more then a 12AY7 in the first two stages and some like the 12AU7 with 33K plate load resistors and 510 to 820 ohm cathode resistor.
      Another good mod is to use a 12DW7, where one channel is the low low gain triode and the other triode is like the 12AX7.
      But on the the high gain triode use a split load pair of plate resistors.
      Two 56K resistors and the big .1uF to .22uF coupling cap coming from between the two.
      And of course very light NFB.
      Bruce
      Mission Amps
      Denver, CO. 80022
      www.missionamps.com
      303-955-2412
        I've never done any harp amps, however, I'm an archivist. Some of these changes may help with a Bassman. I think they're intended for a BF circuit. From one of the former good guys of Ampage:
        1) replace the 1M on the 1st input jack with a 5M resistor
        2) pick a channel and replace that channel's 100k plate resistor with a 470k
        3) replace the 1k5 cathode resistor with a 2k7 (the 25uF/25V cap stays in place)
        4) decouple that stage with a 0.047uF cap
        5) decrease the slope resistor from 100k to 56k
        6) replace the phase inverter tube with a 12ax7
        7) if there's a tube rectifier, use a 5u4
        8) replace 6L6's with 6v6's
        9) install a dropping resistor to lower the screen voltage: 500 ohm, 10W
        10) bias at 27mA/tube
          Hi Jay
          I've used the tweaks you mentioned in the past in some bf Fenders (together with some other needed "custom" tweaks) and it does work very well. Fat harpsound and less feedback, it's a good starting-point for such amps imho.
          Over here it seems most harp players do use those reïssue tweed Bassman amps and I do need to design a harp mod for it; I'm not asking for a 100% ready/tested circuit (altough... ) but some good starting points to start tweaking.
          As mentioned before: the posted notes for bf-amps are pretty good.
          Chris
          Chris
            It's not what many would expect, but I usually find I end up with around 500v B+ on 5F6As set up for harp. I nearly always end up with solid state rectification, occasionally 5AR4. Run the Sovtek 5881 & fit a bias trim pot (10K & 6.8K fixed resistor) in place of the 22K bias supply dropper, try 8mA upwards.
            Double the filtering at the screen supply.
            As Bruce suggests, dropping preamp voltages is a good move, it also prevents the amp from being too harsh/spanky with the tighter rectification. Typically, I start with 82K-100K as the preamp dropping resistor.
            As for preamp tubes, that'll depend to a large degree on what mic is being used, I always prefer a 12AX7 in the PI. You don't want to drop gain too far or low end & dynamics suffer. The EH 6072A is a killer.
            The 6.8K tail resistor in the PI is too small, try 10K or 22K.
            Larger preamp coupling caps @ .1uf.
            I tend to leave the tone stack values stock, but remove the bright cap from the bright channel. Then you can play with V1B...grid leak bias, differing impedance loads for different mics (most like 5Meg +, except 520DX), 12DW7 in V1 etc...?
            Doubling the size of the 220K grid return resistors will make the amp a little more touch sensitive & thicker.
            Switch in/out a second 220uf cap at V2, 3?
              Most of my serious harp player customers laugh at the popularity of the 5-12watt guitar amps used for harp and if they're playing out, always use at least a 30-50 watt amp.
              My 3x10 5E7 Harp-Bandmaster with cathode biasing and a 50 watt Super Reverb OT is VERY popular.
              Bruce
              Bruce
              Mission Amps
              Denver, CO. 80022
              www.missionamps.com
              303-955-2412
                Can any of these things help with a 5e3 deluxe.I want to tweek one for Harp,
                Cheers
                Watto
                  I'm not crazy about 5E3s for harp, points 1 & 10 can certainly be utilized on a 5E3. You might find that you don't neeed the 6V6s to run as much current for harp applications. Keep an eye on your B+ voltage when raising cathode resistor value, with respect to tube & cap voltage limits.
                  Other areas I would look at are:
                  100-220uf cathode bypass caps in the preamp, perhaps no bypass cap on V2 at all?
                  Rewire pots as voltage dividers or Bruce's tone/vol mod.
                  I'd think about adding a negative feedback loop (either 6G2 or SF Champ style), experiment with feedback resistor values, you might find that smaller values (more feedback) than found in the guitar amps work well?
                  Try all the preamp tube swaps you can get your hands on, but don't rule out the possibility of running 2x12AX7.
                  Speaker selection will play a big part, you need a speaker that is not too lively with regards to feedback, but is efficient with good low end. Many of the more popular 12" guitar speakers may not be such a good choice for harp. The best 12" speakers I have heard for harp have been rather flat sounding when used for guitar (the stock Eminences found in Blues Jrs and Blues Deluxes, Alpha 12?).
                  Increase the value of the 22K preamp dropping resistor and listen to a few different voltages, say 90-150v on a 12AX7 (then try tube subs, adjust voltage and repeat).
                  If your PT will take the extra heater current, maybe try 6L6 or KT66?
                  Never tried to mod a 5E3 for harp, it doesn't strike me as the basis of a good harp amp, so suggestions here are just offered in the spirit of experimentation.
                    Maybe OK,
                    BUT, if you put a .05uF cap in front of the grid load resistor, and then get the grid resistor up real high +4M7, that preamp will try and run in what is called contact bias... that does sound different and a little fluffier to me.
                    I'd say no
                    I'd say no
                    I'd say no
                    There is none
                    The PI already uses one of the 12AX7 triodes for push pull adn that section has ZERO gain.
                    I'd say no
                    The amp already uses 6V6s.
                    The voltage node that feeds the screen's their voltage , with respect to the plate supply is already 5000 ohms and only 2 watts or so!! Why would you need a 10 watter even if you did use 500 ohms.... somebody not using any math.
                    Seperate screen resistors of 2K7@2W or even higher resistance will give the PA a little more compressed sound. Maybe OK
                    I'd say no...
                    and why pick an odd number like 27ma? That has nothing to do with what the tube is doing unless you know the tube and the B+ voltage, so don't follow any rules regarding ma of idle current without checking the other parameters.
                    Why to I say no to:
                    2,3,4,7 and 10
                    2., The only reason players do this is because many tweakers do not understand what the plate load resistor does.
                    If there is enough plate voltage delivered to the tube, a larger one can actually increase the gain.
                    Loosely put, gain is a function of absolute voltage drop across the impedance of the tube, and the ratio of the cathode resistance to the plate resistance, but using a way larger plate load resistor does lower the B+ delivered to the preamp tube which can make it less gainy because there isn't any B+ to work with but it will clip poorly, faster and with less tone too...
                    that is the wrong way to do it if you are looking for less gain.
                    A dead stock 5E3 has only about 105v-125v on the plate in the first place so lowering it below 85v-90v is really just silly.
                    3., That will bias the tube colder and can make the preamp slightly harsher sounding with more odd harmonics then if the tube is biased right in the middle of it's class A space with higher current.... yes it will have a wee bit less gain because of the lack of B+, but there other ways to get that without this method which changes the warm tone of a free running first preamp.
                    4., Lower impedances like to have larger coupling caps to fully pass the audio at lower frequencies so this is ass backwards.
                    7., Does not apply to a 5E3 with 6V6s as the amp is a lower voltage B+ amp and the 5U4 will be so lightly loaded with this topology that the B+ will be much higher... ass backwards again.
                    10., (Except to tweak for personal taste or specific guiatrs, pickups, etc.) a higher idling current PA, especially in a cathode biassed amps like a 5E3, will sound fat and greasy compared to low idle currents where the amp sounds too polite adn there is the possibilty of odd harmonic crossover distortion.
                    Bruce
                    Mission Amps
                    Denver, CO. 80022
                    www.missionamps.com
                    303-955-2412
                      Hi Bruce,
                      I agree with virtually everything you say here except...
                      1. Converting an input to grid leak, as you say, can make the amp sound fluffier and, to my ear, rounder. However, it works best with crystal and ceramic mics, sounds a bit gutless with CM/CR & dynamic mics. Of course, with a 5E3 type circuit you can remove the 500pf cap from the tone pot, thus making both channels the same ("Normal/Mic"), and then have one cathode biased preamp and a grid leak biased preamp. In your scenario are you keeping the cathode resistor or grounding the grid-leak biased triode's cathode?
                      10. Indeed, higher currents will sound greasier, but it's worth investigating slightly lower currents too. Higher currents generally also mean more feedback (especially with a 12" speaker) and more mids/highs. A slightly drier tone may be preferable for some, as well as making the amp a little easier to live with? In a couple of single ended amps running around 400v (plate to cathode) I've consistently ended up with 1K cathode resistors after listening tests, running a 6V6 at around 30mA. Equally, in a single ended EL84 amp, the more current I could throw at it the better it sounded...so all I'm saying is try it both ways.
                        I am very interested in this thread. I just ordered a 5E3 kit from Bruce with the harp mods. I have two harp players that want this amp and we will send it through the paces to get voiced like they want. I am going to follow the mods that Bruce has suggested along with his choice of speaker. I update as the build progresses. I would like to post some clips, but I'm not sure how to do a recording. Any suggestions would be welcomed.
                        Greg
                          Maybe OK,
                          I'd say no
                          I'd say no
                          I'd say no
                          There is none
                          I'd say no
                          I'd say no...
                          Why to I say no to:
                          2,3,4,7 and 10
                          Bruce
                          This mod is mentioned on a German website (url: don't know) and maybe from Dr.Z. (Mike Zaite) AND....
                          for blackface or silverface Fenders!!!
                          I've used most tweaks AND some others (for better voicing and way less feedback) several times with great results.
                          Chris
                            I guess I should be spending more time with a spelling checker! ha ha ha...
                            Howver,
                            Regarding #1 and #10,
                            That's why I should be prefacing everything by saying "except to tweak to taste".
                            And I forgot to mention that the mic elements makes as much difference as the kind of pickups a guitar player uses.
                            With respect to the contact or grid leak bias, I assumed a builder/tweaker would ground the cathodes.
                            I know quite a few guitar players who like contact bias in their old amps and they don't have any special pickups.
                            There weren't many hot guitar pickups in the early to mid 50s and those amp guitar combos worked OK anyhow but I suspect it would sound better/different with a mic element that suits it.
                            By the way,... the input jacks on the old Fender tweed amps did not always say bright and normal, they frequently said something like:
                            instrument and MIC!
                            One thing is that for my pro harp player customers, no matter what I do they always want it to sound like this but ten times louder! ha ha.
                            Bruce
                            Mission Amps
                            Denver, CO. 80022
                            www.missionamps.com
                            303-955-2412
                              Hey Bruce, instead of using split plate loads to drop gain, have you tried using lower than usual plate loads? Or lower than usual grid resistors in the following stages?
                              The reason that plate loads for triodes are normally ~2x the tube's plate resistance or higher is that lower plate loads make a lot of second harmonic distortion. That's not necessarily a bad thing, though...
                              You'd have to closely watch the B+ voltage and plate current.
