Looking at a Fender Twin Reverb AA769, I've got no bias voltage. The bias supply feeds the vibrato section, which is now disconnected from the bias circuit. I've disconnected the coupling caps from the driver stage. I've disconnected the power transformer leads, and the B+ and bias tap are OK, 332 and 55 VAC. Nothing is shorted to the chassis. I have replaced all the filter caps. Any thoughts appreciated.
Red Glowing tubes, Fender Twin Reverb
Originally posted by billwjr View PostLooking at a Fender Twin Reverb AA769, I've got no bias voltage. The bias supply feeds the vibrato section, which is now disconnected from the bias circuit. I've disconnected the coupling caps from the driver stage. I've disconnected the power transformer leads, and the B+ and bias tap are OK, 332 and 55 VAC. Nothing is shorted to the chassis. I have replaced all the filter caps. Any thoughts appreciated.
