I found this design and was wondering if maybe some element of the design is usable for a guitar amp. An odd B+ for C-1 (bias) and C-2 , looks clever though.
CFollowers direct coupled into output grids?
Nothing is unusual in the design and there have been guitar amps that have incorporated all of the elements 'cept that strange "standby" feature with then neon light (I assume that is the purpose of the feature). Ray is our "AB2 guru" and may have more specific comments - I could probably respond to more specific questions if you have such.
Rob
Do you know the manufacturer of this amp? It looks somewhat similar to a Fisher design I've seen... I wouldn't be surprised if it would make a pretty good guitar amp as-is, maybe revoiced with the addition of some Ck's... and of course that 1M resistor at the very top would have to go...
It looks pretty cool to me - extensive direct-coupling (hence the C-2 voltage), AC balancing, lots of gain; I think the 150K Rk on the Schmitt stage may be a schematic error, though.
Ray
Originally posted by Ray Ivers View PostDo you know the manufacturer of this amp? It looks somewhat similar to a Fisher design I've seen... I wouldn't be surprised if it would make a pretty good guitar amp as-is, maybe revoiced with the addition of some Ck's... and of course that 1M resistor at the very top would have to go...
Originally posted by Ray Ivers View PostIt looks pretty cool to me - extensive direct-coupling (hence the C-2 voltage), AC balancing, lots of gain; I think the 150K Rk on the Schmitt stage may be a schematic error, though.
Ray
I found the design At http://www.triodeel.com/schindex.htm but the the amp is a homebrew model listed down aways. It's interesting how some of those amps have a PI then a driver prior to the output tubes. I was weaned on having those both in one tube like most guitar amps are.
Ah, a homebrew - that explains that freezing-cold-biased Schmitt splitter (800uA per side!). A 12AX7 would have been fine there; looks like they may have copied the ECC83-based direct-coupled Schmitt PI used in both the 10W and 20W Mullard designs, and increased the values for use with a 12AT7 when they should have decreased them (the 10W/20W amps use pentode input stages, too). It's a cool, simple design, and an excellent platform to tweak from IMO.
Ray
