Hi - been checking the forum, can't find this specific problem.
Ok - I have a 4101 JCM 900 112 combo 100W (w/ el34s) - I bought it from a friend - maybe 8 months ago - I noticed about 3 months ago - that rarely, it would start quitely popping, it would almost be like a crescendo, up to really loud popping - and then it would just stop. Though it's got worse recently - took it back to my friend who knows a good deal about audio amps in general and we eventually noticed that two of the tubes in the back of the amp were glowing cherry red (2,3) - and the others were not (1,4). So thinking it was simply in need of new valves, I bought 4 el34s from Watford (both measured at 44ma but one pair was at 5.4V the other pair at 5.6V) and replaced - all fine - however after 20 mins - same thing happened - two valves started glowing (after some popping) - I swapped 1,2 and 3,4 - and again after some time the same two valves started glowing.
THis is where i think it gets quite confusing because i don't see how it could be just a mis match - not only because watford are pretty renown at getting that sort of thing right, but surely the mismatch would happen immediately not after 20 mins and so suddenly glow red like they have been. Also at no point does the amp (so far) go dead - it always plays, the volume just goes up and down.
The only ideas i have are to check for components that are delosdering themselves when it gets hot - or an CAP that's arcing - has anyone expericed this before - your help would be much appreciated.
Thanks,
Will
incidentially i will be testing values or componsnents and checking again for any burns etc... although recently i checked and saw none.
Thanks,
Will
