A friend of mine has a shitty 5 string bass guitar that has a split coil pu in the neck position and a jazz bass type pu in the bridge position. I don't know who was the imbecile who made it but all the pickups are for a four string bass guitar. Naturally, the thing sounds awful what with most of the pole pieces misaligned with the strings. I am being requested to wind the correct pickups. The problem is with the neck pu. How do I go about doing split coils for a five string bass guitar? I remember somebody posting this same question before. I don't recall what the advise he got and am too lazy to look for the particular thread. Will appreciate it if somebody can give me suggestions.
Split coil bass pickups
It's easy, you just put 3 sets of A5s in the treble side and 2 sets in the bass side + a third set of inert slugs those goes under the middle string. You wind = turns around both. You also need to split the J into 3+ 2 if you want to use both PUs together or 1/2 of the strings will be out of phase. # of turns on the J per side is different because the coils are different sizes. That's a big PIA and I don't know the formula.
