Chassis? Cheap chassis?
  • Chassis? Cheap chassis?
    Hi everybody!
    Well, i know i can mod, i know i can build. I have all sorts of skills, and i was born in a metalwork factory, plus i've done engineering at school before turning to woodworking and guitarmaking.
    In making amps, i have two things which drag me.
    One is the eyelet/turet/circuitboard thing.
    The second is the chassis. I have the skils but not realy the adapted tools. I have punches thought.
    I like the style of marshall, sound city or hiwatt chassis. Where do i find cheap, extremely cheap ones? Not drilled is fine. I have pilar drill, stepped drill and punches. Or DIYers, what's your take on a cheap and quickly made chassis?
    Bye and thanks.
    Max.
    Ask a local welding shop or metal shop what it would cost to make one up for you. Perhaps even a cardoard mock-up to show not only the dimenesions, but also how you want it made, like flaps at the corners tack welded as opposed to seams, or something like that. I surely know little about the process. And they might have some advice too. After all, it is just a rectangular box with an open side.
      Originally posted by Satamax View Post
      Hi everybody!
      Bye and thanks.
      Max.
      In the past, when trying to do this, I found that the local sheet metal shops would do a one off chassis for me but it always cost an absurdly high price... like anywhere from $75.00 to $125 each.
      What they want is a min 50 to 100 piece project and only then did the price come down to a reasonable amount.
      Even now, my chassis costs (at 100 piece pricing) is about 50% higher then it was 4 years ago!
      It has become very expensive to do this.
      Because of that, I'd say just buy a generic JTM45/Marshall style chassis from someone who is already selling kits, such as MOJO or WeberVST.
      Bruce
      Mission Amps
      Denver, CO. 80022
      www.missionamps.com
      303-955-2412
        hi max, i make them myself, its easy if you dont want to win a beauty contest with it: (usually the thing will hide behind a wooden case anyway)
        - buy a rectangular piece of sheetmetal (Aluminum 5 Euros) and a square timber(planed, 2Euros) with the edge lenght of the depht that Your Chassis is going to have
        - Cut the timber to the lenght of Your Sheet metal
        - Clamp the Timber to the edge of one side of the sheet metal with two or three screw clamps
        - Cut the sheet metal along the timber as far as Your Edge lenght is on both sides
        - now You can easily bend one long side of Your chasis to a perfect 90 ° angle.
        - do this to the other side and to the short sides
        - ears you have left over you can bend first and hide behind the small sides
        -at last you drill holes and stabilize it with screws
        - purist will not like this but ive build four chasis like this and they did not fall
        apart or conduct bad or anything
          It's a shame. right before I got into this whole amp thing I was running a machine shop for a company I worked for doing CAD and drawing out boxes of all shapes and sizes for the turret press, maintaining the press etc.
          I could have ran off a bunch of chassis in no time at all!
            Hi everybody!
            Bye and thanks.
            Max.
            Hi Max,
            I get chassis from KomboKing at http://www.komboking.worldbreak.com/index.html, when it isn't practicle to make my own. I have a nice box brake but can't weld the ends right now. He makes custom sizes and he usually has a stock Marshall style chassis on hand. His are heavy Aluminum and have welded ends very nice quality stuff, and very reasonable prices (IMHO).
            As far as the Turret board thing goes there is some information in these two links that may (or may not) be helpful for you.
            Text File:
            http://briefcase.yahoo.com/bc/casey4...ase.yahoo.com/
            Photos for the Text File:
            http://s238.photobucket.com/albums/f...&paginator=top
            DIY Links
            Tolex Tutorial
            http://www.guitarkitbuilder.com/cont...lifier-cabinet
            Chassis:
            http://www.guitarkitbuilder.com/cont...lifier-chassis
            Turret board:
            http://www.guitarkitbuilder.com/cont...d-construction
              Originally posted by Casey4s View Post
              Hi Max,
              Text File:
              Hey Casey4S!
              Cool description and pics as usual. I'm still going back every now and then to your tolex tutorial. I need to buy myself the litle brake for doing chassis. Welding i can do no prob i think. Something like this one.
              http://www.axminster.co.uk/product-A...rker-23170.htm
              Thanks a lot.
              Max.
                Hey Casey4S!
                Thanks a lot.
                Max.
                The metal machine in that add looks like a winner, just make sure it has different size removeable "teeth" to do chassis (boxes) with.
                DIY Links
                Tolex Tutorial
                Chassis:
                Turret board:
                  "Mike", the person behind komboking, has apparently come upon some pretty
                  hard times and is no longer making chassis. His service was pretty unique
                  and I would have liked to do business with him. I wish him the best.
                  Paul P
                    Paul P
                    yes, I know about his misfortune. I talked (email) with him a few weeks ago and I got the impression he was back into business, but maybe not.
                    He has my best wishes and prayers as well.
                    DIY Links
                    Tolex Tutorial
                    Chassis:
                    Turret board:
                      I wouldn't mind having a tool like that but this particular one only "Handles
                      sheet metal up to 22 gauge". This doesn't seem enough, especially for an
                      aluminum chassis. The Hammond steel chassis I just bought is 20 gauge
                      and they go to 18.
                      Paul P
                        and they go to 18.
                        Paul P
                        Yes i know Paul, i wonder why they say only 22G i wonder if that can be used on tougher steel or Al. Steelwise i think i would not consider anything under 1.5mm thick!
                        Guys, i have that pilar drill
                        And i was wondering, afixing the outer part of the punch onto the sloted table, and using the inner part of the punch on the quill, which is pretty hefty, do you think i could use my drill as a punching press?
                        Thanks a lot.
                        Max.
                          He had some 18 watt chassis for sale on 18watt.com a few weeks ago but they may have been old stock
                          http://www.18watt.com/modules.php?na...wtopic&t=18509
                            Thanks a lot.
                            Max.
                            No I doubt it.
                            I think you'll break the threads off the arms trying to develop enough leverage to punch through anything short of super thin and soft metal like copper foil.
                            Bruce
                            Mission Amps
                            Denver, CO. 80022
                            www.missionamps.com
                            303-955-2412
                              There's an ebay seller that makes aluminum chassis with welded corners at reasonable prices
                              http://search.ebay.com/_W0QQsassZdawnpacobell
