How do the mini-hb mounting rings work?
  • How do the mini-hb mounting rings work?
    These look like the ones that fit into a P-90 rout like on a 70's LP Deluxe. Allparts sells them, but I have no idea how you are supposed to secure them to the guitar. (I had made my own, cutting P-90 covers with my Dremel, but to mount them in the guitar I used hot melt glue- not exactly the best solution if you were to tour in Arizona! LOL)
    Here's a link to the page:
    http://www.allparts.com/store/pickup...28,Product.asp
    Thanks!
    Steve Ahola
    The Blue Guitar
    www.blueguitar.org
    Some recordings:
    the pickup and ring are assembled as one unit. The 'height' adjustment screws do not adjust the pickup in the ring, but adjust the whole ring/pickup assembly by raising/lowering into/out of the guitar body, kinda like P-90 soapbars. the adjustment screws thread into body mounted inserts, or into a plate mounted at the bottom of the pickup rout.
    The mini-hum is kept at a predetermined height within the ring by the use of a standoff, and is permanently mounted in the ring by the use of a soldered nut on the bottom of the pickup legs.
      Thanks for a very clear explanation! Now I guess I can retire my hot melt glue gun...
      Steve Ahola
      EDIT The rings from Allparts do not include the backing plate so I guess you would want to sink a threaded insert (or nut) into the wood under the ring. Or maybe one of the boutique winders makes the plates...?
      The Blue Guitar
      www.blueguitar.org
      Some recordings:
        I've pondered this meself, but I just can't discard the 90's. Even though I'd love to
        have a Firebird thing goin' on.
