Hi, I'm new here and am desperate for help!!!
It all started at a gig last week in which I popped the mains fuse. Putting the amp on my bench today I noticed one of my power tubes was bad and was the culprit. I put in a new set of Winged C's and biased 'er up.
After getting the bias all set (these tubes are matched really tight, 16.42W and 16.48W) and the amp warmed up, I ran 1k into it and checked the output on my scope. With the signal applied to ch.1 I can barely crack the volume knob before the signal clips horribly, with a high pitched squeal emitted from around the tube area. Putting the signal into ch. 2 gives me a damn good signal on the scope, and I'm able to turn the vol. up to a good level before clipping.
I've replaced V1 in hopes that V1B was suspect, but no dice.
Removed the bright cap tried it with a 390pF cap on the vol. 1 pot, as soon as I turned up the knob just a hair the signal clipped, I heard the oscillation, I measured 59W across the load and the 1k input signal was magically changed to 10k on the output.
Turned off the signal generator, left it plugged into ch. 1, turned up the vol. on the amp and still saw/heard oscliiation, clipping etc...
Plugged in my strat and banged a few chords, could hear the oscillation happening as I hit the strings harder. Vol. on ch. 1 around 9:00. My theory is that this is what caused me to blow the tube at the gig Saturday, I was plugged in and hit a few chords when the amp just died. The oscillation must've redplated the tube and it finally quit.
Removed the cap, and I was able to turn the vol. 1 knob to around 9:00 before it clipped, no oscillation heard, measured approx 55W across the output, output was 1khz.
Ch. 2 showed none of these problems.
I've always run this amp into an attenuator, jumpered channels with both volumes at approx. 1:00. I wonder if I have damaged it by doing that???
Sorry for the long post, any ideas or suggestions?
