Large format scanner (12x17 inch bed) under $700!
  • Large format scanner (12x17 inch bed) under $700!
    Large format scanner with 12x17 scan bed under $700:
    http://www.plustek.com/product/a320.asp
    I just called Kinko's to see if they had a large format scanner there to scan album jackets. Yes, they do but since the album jacket is copyrighted material you would need a signed release for them to copy it. And it would be $5 per square foot... Geez, they are no fun at all!
    It sure would be nice to be able to scan an album jacket with a single push of the button! What I've been doing is rotating the jacket and making separate scans that I piece together in Photoshop Elements- what a hassle! Especially having to free up enough RAM to fire up such a memory hog!
    Steve Ahola
    P.S. Here is a link I found to the only source for that scanner:
    http://www.pcmall.com/pcmall/shop/de...no~7304970.asp
    P.P.S. Now I just need to go down to the freeway offramp with my "Will Work For Food" sign to scrape up enough money to buy that sucker!
    The Blue Guitar
    www.blueguitar.org
    Some recordings:
    Wouldn't it be easier or at least cheaper to take photos of them with a digital camera? $700 would get you a pretty reasonable camera with suitable accessories for this, and it could be used for other things as well.
      Hey Steve,
      I'm curious to ask, why scan an album cover? Are you going to do an album cover slide show on your DVD player for MP3's or PC?
      Dave
        Why don't you just copy the pic that comes up on CDDB, or go to someplace like Amazon.com, and right-click to save as a JPEG?
        http://www.amazon.com/Partridge-Fami.../dp/B000002VGR
        Or, do you also need the back? And/or, you have out of print ones? (May be able to find pics of those by searching).
        Brad1
          Enzo:
          I do have a digital camera and have used it for low-res pix of album covers. However, the image is always skewed and you usually cannot read the text on the back.
          Dave N.:
          You may have noticed my threads on ripping vinyl albums. Along with the musical content I do like to archive the record jacket as well. My main concern is preserving content which may become extinct.
          Brad1:
          I have gotten low-res pix of album art off the internet, usually for records that have been reissued on CD. I am interested in higher resolution pictures, in particular with legible text from the backs. And for many of these albums I have not been able to find anything on-line. Here are a few of the links I have used for album art:
          http://www.allcdcovers.com/
          http://www.cdcovers.cc/
          http://tralfaz-archives.com/coverart/coverartlinks.html
          The previous link is very buggy- you can access the content with the following link:
          To all:
          $700 is kinda rich for my blood (I had bookmarked a similar model a few years back which sold for about $350- I shoulda jumped on that one!)
          In any case, I do have a system which works fairly well with my Epson Perfection V100 Photo scanner: I start off with the upper left corner in the "hot" corner, do a preview to establish the automatic settings and then take 4 scans, rotating the jacket 90 degrees clockwise after each scan. The trick here is to do just a single preview, and that will keep the settings the same for all 4 scans, so you should be able to stitch them together better. And it saves time, to boot...
          Although I usually scan CD artwork at 600dpi, it's probably better to do the LP scans at 300dpi, to save on time, RAM and disk space- both in the scan process and in post-processing with a graphics program. (I probably should look into Paint Shop Pro- at least in the past it used a lot less memory than Photoshop Elements.)
          Here is my own collection of album art:
          http://s179.photobucket.com/albums/w299/steeve_a/
          Thanks!
          Steve Ahola
          P.S. I'm still pissed off at Kinko's policy of not copying material which is copyrighted without a signed release. Geez, isn't that what people usually get copied? Articles from magazines or newspapers, pictures from books... Yes, I realize that there is a lot of business material that is copied- but even much of that is copyrighted. Of course, when you use the self-service machines, it is harder for them to enforce that policy...
          The Blue Guitar
          www.blueguitar.org
          Some recordings:
            Actually it might not be a bad idea to make up a rig specifically for taking digital photographs of album covers... with a fixed distance I should be able to figure out some settings which produce a decent picture.
            Thanks for your suggestions!
            Steve Ahola
            The Blue Guitar
            www.blueguitar.org
            Some recordings:
              Two suggestions, Mr A -
              1 - your camera - can you get it to do any uncompressed formats? TIFF, GIF, RAW?
              2 - your software - have you tried the GIMP?
              it's FREE, powerful and (theoretically) able to run on modest hardware.
              Hope this helps!
